Question about Sony Playstation 3 (PS3) Console
My ps3 will turn on and go to the main menu but it wont take any discs
  • 7 Answers
If, when you say "any discs", you mean CD, DVD, BD,PS2, PS1 & PS3; then that means that your "Blu-Ray Diode" is out. You would need to get this replaced.
If you are under warranty, then no big deal. Send it in to Sony and get a new one.
I repair PS3's as a hobby and have repaired many with this issue.
I hope this gives you a place to start.
Posted on Dec 30, 2008
Ps3 disc wont eject at all. have tried holding it in horizontal, vertical, diagonal and upside down positions but still wont eject.
Hi, i'm assuming you have a phatty PS3. Let's try this:
  • - turn off the ps3 with the main switch, behind the console
  • - press the EJECT touch-key on the front, HOLD on it while you turn on the console with the main switch... keep holding the eject key, if it'll work you'll get your disc out.
  • - If it won't work just try a couple of times more then if you don't succeed please advise me with more information about your PS3 model and I'll try to bring you other solutions :)
Regards, Peter
Aug 08, 2010 | Sony Playstation 3 (PS3) Console
Wont read the disc .my sony playstation 3 wont read any disc.
The PS3 has a special Recovery Menu, which you can access in the following way:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
From the above select option "Rebuild Database". After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu.
Apr 07, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont turn on
Alright you need to put your ps3 in what is called "safe mode". First make sure there is no disc in the ps3, then turn off the ps3 in the back(main power switch), turn that switch back on, then hold the power button in front until you hear a total of 3 beeps, then let go, the light will be red, hold the power button again and you will hear 2 beep then a quick double beep, let go of power button and the light should stay green. A menu will appear, try all option working your way up from option 1 until it works. If you go through all 6 option and you are still having issues call 1-800-345-7669 to have your ps3 serviced
Aug 10, 2009 | Sony PlayStation 3 40GB System
Ps3 wont read games or dvd. but main menu is fine. system less than year old.
unfortunately sounds like your laser is shot. if the disc inserted icon is showing yet no discs will be recognized in there relevent places on the xmb then i'm afraid your laser is most definatley...to put it technically...caput. if you have warranty use it immediatley.
Aug 02, 2009 | Sony Playstation 3 (PS3) Console
Quantum of solace, on blu ray, previews play fine, film wont
Do need the internet, just go into your settings tab on the intro menu for the PS3 and hit system update. Use the via internet option and it finds the newest version...2.70. Takes a bit to download but, when it's done you get to enjoy watching the otherwise $30 drink coaster.
Mar 30, 2009 | Sony PlayStation 3 40GB System
PS3 WONT LOAD OR READ DISCS. FROZE ON MAIN MENU GAME DISPLAY.
Check out my blog for help fixing the problem.
Start with # 3 on my 5 Most Common Errors entry.
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
Feb 26, 2009 | Sony Playstation 3 (PS3) Console
Ps3 was playing movies i had burned to disk now it wont
The best way to play burned movies is to copy them onto a memory stick or external hard drive then copy them onto the ps3 i use this method and find the movies play in much higher quality than dvd-r or+r or whatever discs you use
Jan 25, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont load games up
I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine. Also downloaded games were working ok.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
Select option "Rebuild Database".
After PS3 has executed the DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
Nov 18, 2008 | Sony Playstation 3 (PS3) Console
PS3 - No main menu
Contact Sony @ 1-877-253-SONY(7669) for a replacement unit as this is not normal.
It autoplays games but no main menu eh?
Sep 08, 2008 | Sony Playstation 3 (PS3) Console
Ps3 wont read games discs
ts a problem with the latest download update. sorry to say but its a job for sony as long as its still under warranty. just phone them up explain the probs your having and they will send you a new (normally reconditioned) unit out. sony's replacement service is very good.
Feb 12, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
20 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
