Question about Cell Phones
Verizon v325i does not ring with incoming calls
I have a Motorola v325i on a Verizon network. It does not ring when called.  The vibe function works fine and calls are received correctly.  This is also a problem in the settings menu, as none of the ring tones will ring there either.  The phone does make noise when turned on and keys/buttons make beeps when operated.  I have done the master reset thing, did a "hard reset" (removed battery for <5 minutes) and made sure the phone was updated with the most recent software.
I believe this is a software problem because the startup/shutdown sounds play and the keys make noise, but I don't know how to reinstall the firmware or otherwise reset the phone so it starts ringing. Any ideas?
my phone wont make any sounds or noise at all! it is a verizon LG pink venus and its completely silent! I checked for any modes it might be on, but nothing has helped.
4 Suggested Answers
SOURCE: v325i does not ring
I'm sorry, but that is a useless response. If you read the posting, it's obvious that the problem extends beyond a simple change in the menu. If you don't have helpful information, please do not post useless responses such as "turn up the volume". If it was that simple, most people will fix it before posting to this forum.
Posted on Oct 15, 2007
nickholbrook
  • 11 Answers
SOURCE: Verizon v325i does not ring with incoming calls
are you sure you don't just have the volume turned all the way down?
Posted on Jul 12, 2008
avl02413
  • 8 Answers
SOURCE: Need unlock code for Verizon Wireless Motorola V325i
Dial *228, then when prompted to do so by the automated system, press 1. After it says: "Your phone has been programmed successfully", press "OK" or "Done". When you press that, the phone will automatically power off, then back on. Once the phone has powered back on, the unlock code will now be the last four digits of the phone number.
Posted on Aug 12, 2009
Dropped it - put battery back in. Works for outgoing calls but only vibrates, does NOT RING for incoming calls. Checked Settings--> Ring Styles and changed to Loud (still doesn't ring) and back to Vibe...
You dont hear tones after you dropped it.
This is because the speaker connection may be disconnected due to sudden ****.
You need to contact your authorized motorola service centre to fix this problem.this is a very small problem so no need to worry.
Thank you
Aug 08, 2010 | Motorola Mobility RAZR V3
Will not ring for incoming call only viberates
You should try to put it on only ring cause some phones have issues simular to yours.
Jan 31, 2010 | Motorola Mobility Adventure v750 Cell...
Feb 01, 2009 | Verizon Communications Motorola V325i...
Motorola V325i
Short answer: NO.
Long answer: the V stands for Verizon, which uses CDMA technology not GSM and more specifically, they don't use SIM chips, instead using Electronic Serial Numbers (ESN) you can still have multiple phones, but you have to call them or go onto your website to change between the phones.
Sep 24, 2008 | Motorola Mobility V325 Cellular Phone
Won't Ring
check the settings in your phone book. this happened to my phone and all of the personal ring tones were set to vibrate. I don't know how this happened. I went into each contact and changed the ring tone to none and I am back in business
Sep 15, 2008 | Motorola Mobility W385 Cellular Phone
V325i does not ring
have you checked in the MENU/settings/audio? Maybe it is set to SILENT or VIBRATE?
Oct 15, 2007 | Motorola Mobility V325 Cellular Phone
Oct 15, 2007 | Samsung SGH-p207
Phone sttopped ringing and vibrating
Is there an update for you phone? you might have a virus if you have downloaded pics, ringtones or wallpapers from unreliable website.
Nov 25, 2006 | Motorola Mobility RAZR V3
Cell Phones Logo
311 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
