Question about Uniden BCT8 Base Scanner
Programming error BCT8 Uniden
Hello.
A friend of mine couldn't program their new Uniden BCT8 scanner so they brought it to me to see if i could program it for them. I've programmed lots of scanners but this one keeps coming up with a "pr9-loc" message every time you try to enter a frequency. I followed the instructions as per manual but no luck. Any ideas?
Thanks for any suggestions.
Keith
Hello.
Back to answer my own question.
I just found the problem. If you try to program one of these scanners (Uniden BCT8) and you keep getting a "pr9-loc" message every time you try to enter a frequency and "M-LOCK" is showing in the upper right corner of the display press and hold the M-Lock (E) key until it beeps twice and "M-LOCK" disappears from the display. You're now set to program.
Keith.
Posted on Dec 30, 2008
Need to program uniden bearcat scanner
The best programming instructions for the BCT8 are in the factory manual that you can download and print, at no cost, here:
http://www.uniden.com/pdf/BCT8om.pdf
For a comprehensive database of active frequencies and systems in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
May 04, 2011 | Uniden BCT8 Base Scanner
.........i want to switch my scanner over to
Sorry, but the Uniden Bearcat BCT8 is an analog-only scanner, and there is no magic that will enable it to receive and process digital signals. EDACS, however, is NOT a digital system. It's discussed at length in the BCT8 operating manual, which also contains step-by-step programming instructions for EDACS systems. You can also find a lot of useful information on EDACS, and specifics on systems in use in your area, at: www.RadioReference.com
If you don't have the manual for your scanner, you can download and print it, at no cost, here:
Bill B.
Jan 18, 2011 | Uniden BCT8 Base Scanner
How do you start to program a bct8 800 mz scanner
Programming conventional frequencies into the scanner's PRIVATE bank is simple, but programming trunking systems is a detailed process that will take some research and probably some practice. The best instructions for both types of programming are found in the factory operating manual that you can download and print, at no cost, here:
For a comprehensive database of active frequencies and trunking systems in your area, and a lot of other useful scanning information, visit:
Bill B.
Jan 11, 2011 | Uniden BCT8 Base Scanner
How do delete a frequency code from my scanner i know how to program but dont know how to take a frequency off thanks
Just program 0.0 (zero point zero) into a channel to clear the existing frequency. Also, programming a new frequency into a channel will overwrite/delete the previously programmed freq.
Bill B
Aug 02, 2010 | Uniden BCT8 Base Scanner
I am trying to program my Uniden BCT8 to track LTR systems but having problems.
LTR systems must be entered in a specific order so that channel 1 is 1st, channel 2 is 2nd etc...
Are you sure that the BCT8 tracks LTR systems? A Radio Shack PRO 92 tracks all 3 trunking systems (analog) including Motorola and LTR, while some Uniden only track 1, and some don't do trunking systems at all.
Dec 27, 2009 | Uniden BCT8 Base Scanner
How to program and delete uniden bearcat scanner 210 XWneed to c
I can't locate information specific to the 210XW, but hopefully this generic Bearcat programming info will help:
1. Press the MANUAL key to advance to the channel that you wish to reprogram.
2. Enter the new frequency, including decimal point.
3. Press the ENTER or E key.
4. Start over with step one to continue programming channels.
Jul 31, 2009 | Uniden BCT8 Base Scanner
Hwy pre-programmed frequencies
Unfortunately, I think this is a common problem with these radios. I have a brand new BCT8 and it started to not receive anything on the pre-programed highway patrol after using less than a month. Unfortunately the best bet would be to contact Uniden which they will probably tell you to reload the firmware (which won't solve the problem) or send it to them to fix.
Apr 13, 2008 | Uniden BCT8 Base Scanner
Programming
If its just a normal frequency then select Hold/Resume and press the arrow keys until you find the selected channel, then program in the frequency for example 130.000 you have to make sure the decimal point goes in with the frequency then press (E) then press the arrow key up to go to the next channel and program and repeat steps.
Then select scan you may need to activate the banks so when scanning just press 1,2,3,4,5 so next to the bank icon all 5 should be up.
Cheers Shane
www.rochedalescan.com
Feb 24, 2008 | Uniden BCT8 Base Scanner
Please Provide Basic Instructions For Programming My Scanner
go to www.radioreference.com and find the forum for that brand scanner and you will find many people who will help you, then sit back and enjoy listening
Dec 25, 2006 | Uniden BCT8 Base Scanner
Uniden BCT8 Base Scanner Logo
956 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
