Question about Brother IntelliFAX 5750e Laser Fax
Fax machine is offline
My faxes and copies where coming up black. I changed the array sensor and now if says PLS OPEN COVER
Do I need to go through some type of set up process for this?
  • Ray M. May 11, 2010
    crespec, i think hes referring to the LED array or what bro refers to as the CIS.
  • 320 Answers
What is a array sensor, i am a brother tech and never heard of an array sensor???????????????
Posted on Jan 20, 2009
I am trying to send a fax but on the screen it says offline
Dont worry as offline is referring to you using the machine as a printer. It has no bearing on sending a fax.
Check your line to make sure its working by just plugging a phone into the line to see if you have a dial tone.
Sep 19, 2011 | Brother IntelliFAX 4100 Laser Fax
My brother faz 5750 e keeps coming up with a offline open cover I do that and it does not fix the problem HELP
Was there a paper jam or something happen just prior to the code? Was it moved bumped or dropped?
Make sure all your doors have the acuator fingers still prtruding, one may be broken and not closing the safety interlock.
Let me knw
Jan 09, 2011 | Brother IntelliFAX 5750e Laser Fax
Its giving me a pls open cover offline screen and it wont send any faxes i might be stupid this maybe is normal or simple but when the machine is warming it gives out a wicked screeching noise
Hi Fax machines are one of the oldest ways to send document information over a telephone line. Before e-mail became the most popular, and more efficient way to send documents, the fax machine was king. With time, fax machines have become sophisticated machines capable of many functions. No longer found only as a stand-alone machine, fax machines are included in copiers and printers. Faxing can even be done through computer software to a receiving fax machine or printer. So with such a complex machine there are several things that could go wrong. This article teaches you some basic troubleshooting steps.
    Fax Quality
  1. If the faxes you are receiving are too dark or light, or ruined by streaks and splotches, play around with the darkness and density settings on your machine. Send a few test faxes until the quality looks good on your end. If the faxes continue to come out poorly, the problem probably lies on the sender's end. If you are the sender, and your documents are coming out badly on the other end, try cleaning the sensors of your machine with a damp cloth.
Aug 09, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
I've changed my internet providers and have gone from a cable internet svc to a dsl phone line provider. Now my computer fax machine says it is offline. Is there a setting that I need to change?
Most likely cause is you don't have a dsl filter on your fax line. Without the filter, your fax machine's modem can't discern between a dsl signal and a telephone signal Since the telephone line coming into the building is now carrying a dsl signal, a filter is necessary to receive/send faxes.
Aug 25, 2009 | Office Equipment & Supplies
The machine says it is offline , open cover
It may need to have the drum unit reseated. Lift it slightly, pull it towards you then reinsert it till it clicks in.
Apr 14, 2009 | Brother IntelliFAX 4100 Laser Fax
i don't know how far you tore this down but usually this problem has to do with the black arm linkage that hooks to the left side of front door. if it appears to be hooked to door ok, then if you took all covers off you may have dislodged the linkage further back where it hooks to your laser shutter.
Dec 30, 2008 | Brother IntelliFAX 5750e Laser Fax
I just replaced the array sensor because my faxes and copies where coming up black. I put everything back together and turned it on and it says PLS OPEN COVER OFFLINE What do I need to do next?
You need to git in to the maintenance mode. press the menu key then the *, 2, 8, 6 and 4 keys in this order with in 2 seconds. maintenance will come up in the display. If not you will need to press the stop key & tray again till it dose. once in press the 8,2 the display will come up with a number. This will let me know the error you have. press 9,9 will exit maintenance. will be checking for your replie
Brother intellifax 4750e
if the copy comes out black and/or sends black the Contact Image Sensor in the scanner may be needed.
Hope that helps...
Jun 17, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Says paper jam, but none jammed
It is probably jammed in the back door of the fax. Check that and see if you find anything.
May 07, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
which cover are you opening? You must pull open the bottom cover not the one under the keyboard. It's the bottom front cover not the top front cover.
Sep 26, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 5750e Laser Fax Logo
1,090 people viewed this question
James Cagle
James Cagle
Jim Keysor
