Question about Brother MFC 8820D All-In-One Laser Printer
I'm getting a PAPER JAM error when the MFC 8820D is turned on. I've gone thru all the steps but there is NO paper in the unit. I've tried replacing the toner cartridge too, all to no avail. Any ideas?
Try turning it off checking from any paper that might be stuck way in the back unplug t then turn it back on
Posted on Dec 30, 2008
MFC 8820D ADF Will Not Feed Document
The ADF in my Brother MFC 8820D will not feed a page through
Feb 23, 2013 | Brother MFC 8820D All-In-One Laser Printer
Brother MFC 8820D Error Message "MAINTENANCE 7". Error Message "CHANGE DRUM" drum and toner changed. I have gently blown out any dust. There seems to be a burning smell when the...
Hi Erika:
A burning smell presents when paper is stuck on the fuser (The hot thing that heats the toner to the paper.) I would take out the drum, and peek in the printer with a flash light and see if you see any paper stuck anywhere it does not belong. Usually, the paper will be burnt "Brownish" in color.
With the drum, there are contacts on them. Make sure they are clean; and do not have toner residue on them. Easy to clean with a pencil eraser. Gently, rub the eraser over the metal contacts to clean off residue. Hope that helps you. If so, please leave me positive feed back.
Aug 04, 2011 | Brother MFC-8820D Laser Flatbel...
Hello FixYa, I have a problem with my Brother MFC-240C. Everytime I try to print something I get a paper jam error message. I have tried opening the back cover and removing the paper but it still does...
This is not a fix, but a troubleshooting step. After you perform this step, please respond and let me know the outcome.
Take a small stack of paper (less than 50 sheets) and place flat in a refrigerator overnight. After the paper has been in there for at least 8 hours, pull it out and fan it (to remove static cling between the sheets). Place in the printer and see if the paper will feed correctly.
If it does, then your problem is high humidity which is a common cause for paper sticking together and causing paper jams. If it doesn't, then you've probably got a torn piece of paper somewhere in the paper path that is causing a jam. Either way, let me know your results so I can help you troubleshoot your issue.
Apr 10, 2011 | Brother Multi-Function Center MFC-240C...
I cleared paper jam. All is spotless. Won't
check fuser sensor switch have to remove fuser assy
May 18, 2010 | Brother MFC 8820D All-In-One Laser Printer
Small piece of paper jammed in my brother 240C. Can't see if but I know it is there. how do I get it out?
  1. Turn the printer off and on to see if it can automatically clearsome or all of the jam. Many printers provide an error-code listing onthe front panel display for the area where the jam occurred. If yourprinter shows an error code, be sure and check the printer manual tosee if that identifies the area of the printer where the jam occurred.
  2. Step 2 Turn off the printer.
  3. Step 3 Remove any paper trays. Inspect them for wrinkled or damaged paper.
  4. Step 4 Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. Step 5 If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
  6. Step 6 266_a1.jpg Ifyou find a piece of jammed paper, remove it by holding it with bothhands and pulling firmly (see A). The goal is to keep the paper fromtearing. If several pieces are jammed together, try pulling out themiddle piece first to loosen the jam.
  7. Step 7 266_a2.jpg If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
  8. Step 8 Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. Step 9 If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Nov 26, 2009 | Brother Multi-Function Center MFC-240C...
Brother 8820d MFC auto doc feeder does not work...
You need a new hinge so the cover will sit down properly, or paper will jam anyway, but it sounds like there is still a scrap of paper on one of the sensors inside the ADF, you need to look with a flashlight down thru where the paper goes and also look up thru the slot with the ADF lifted.
Sep 11, 2009 | Brother MFC 8820D All-In-One Laser Printer
Hi I had a paper jam in my MFC 8820d - I removed the cover and removed the paper but I still get a Paper Jam error msg. I powered down the machine and turned back on - still same error msg. I have removed...
This can sometimes be related to paper dust interfering with a sensor. A burst of canned air can fix the problem. Just pull out the toner, open all of the covers and spray air into all the little crevices. You might want to do this outside, in case toner is loose in ther, so as not to make a mess.
Sep 02, 2009 | Brother MFC 8820D All-In-One Laser Printer
Paper jam that i can not get out
By opening the front cover the toner/drum unit should be exposed. You can take it out simply by taking a grip on the black/grey area in the middle and lifting it up- and outwards. It is clicked into the machine, so it doesn't just slide out, it could require some effort.
Jun 02, 2009 | Brother MFC 8820D All-In-One Laser Printer
Paper jam
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Step
Step
Step
5
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
Step
8
Step
9
Sep 06, 2008 | Brother MFC-5440CN All-In-One InkJet...
Printer says paper jam, but there is no paper in the printer. (mfc 210c)
If the paper tore when removing it, chances are there could be a small piece of paper still causing the paper jam. Sometimes all you need to do is turn the fax off for a few minutes and then turn it on again and the paper jam message is gone
May 10, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 8820D All-In-One Laser Printer Logo
154 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
