Question about GE J2B915SS Dual Fuel (Electric and Gas) Kitchen Range
Removing Gas Slide-in Range, Installing Gas Freestanding Range
The basic measurement width is the same at 30inches across. The Depth is about 2inches deeper. That means it will stick out about 2 more inches then the old one. Besides that, and the inconvience of not having the overhang on both sides of counter to catch food and juice, what other problems will I run into installing this Range. I also have to take out and disconnect gas shutoff on old one. Do I need a plumber? I am told this is an easy installation that shouldnt take more then 30minutes. Also have a new Dishwasher to install. Any tips? Should I replace all the old stuff in back since its all been there for 12 years. Waterfeedhoses and stuff. I am also told that the new one will not come with a power cord. Any help you can give me on these 2 items would be most helpful. Thanks in advance
Mike
SOURCE: GE Spectra XL44 Oven over-heating???
I got an e mail saying that there was a solution - have you seen it?
Posted on Feb 09, 2008
docjohn174
  • 943 Answers
SOURCE: GE Profile Gas Range Igniters working but gas takes a while to start flowing
HI thanks for your question. the igniter is the cause for this problem. the heat from the glow bar is just not hot enough to ignite the gas. i would replace the igniter. thanks
Posted on Oct 14, 2008
SOURCE: Low Heat from GE XL44 gas range
you can increase the sides of the flames by opening the orifices, if not differences. make the orifices holes a bit bigger, you can have as big of a flame as you want. those orifices are at the connection of the burner with the valve that supplies gas to the burners.
Posted on Dec 09, 2008
  • 6 Answers
SOURCE: oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
Posted on Dec 20, 2008
jsrock516
  • 5911 Answers
SOURCE: GE XL44 stove, broiler work fine. Oven won't light.
If this is a GAS range, the majority of the cases this problem is attributed to a bad igniter on the bake manifold. Each oven manifold (one for bake, one for broil) has its own igniter. They are both fed from the same gas source, though. So, if the broiler works, more than likely you simply need to replace the bake igniter. The following link explains:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
The bake igniter tends to wear out faster, due to the frequency of use.
You can purchase replacements on line at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com, or repairclinic.com. Just use you model number as your search criteria.
This is a simple repair that anyone can do on their without the need of a service call. Just follow the steps provided. If you have any questions, please let me know. I hope this helps you.
Posted on Jul 30, 2009
Is width measured horizontally and depth/length measured vertically?
Width is measured across the front or back horizontally. Depth is the measurement taken from front to back, not the height which would be a vertical measurement.
May 05, 2016 | Refrigerators
I am wanting to buy a new gas range, but I need help in finding out the cu ft of my old range first. can you help me?
Two ways
measure the internal sides in feet or cm of the oven and multiply the width by the depth and then multiply by the height.
or
Google for the old one
make model specifications
Really you don't need to work out the cubic feet, you just need to measure it so it fits your space. If it fits, it will be the same.
Apr 16, 2016 | Kitchen Ranges
I have a 1976 Gaffers & Sattlers slide in range I want to replace. Any idea how to remove it? Thanks
this taken from ehow site:
Slide-in ranges and freestanding ranges use the same installation techniques, with one minor difference: the slide-in range rests on the edge of your counter top. Removing a slide-in range is not difficult but will require a friend to assist. Removing the storage drawer from the slide-in range first will give you access to the power cord and gas shut-off valve, if your unit uses gas
Instructions
    • 1 Pull the bottom storage drawer out as far as it will slide. Lift up the front of the drawer and unhook the back of the drawer from the drawer guide. Pull the drawer away from the range.
    • 2 Reach under the slide-in range and unplug the power cord from the wall outlet. Turn the gas valve to the off position on the house line coming from the wall.
  • 3 Lift the top of the slide-in range with the assistance of your helper, and pull the range forward enough that you can access the back of the range.
  • 4 Go behind the range and locate the connection between the house gas line and the range gas line. Disconnect the flexible gas line from the house gas line with a pair of channel lock pliers or a pipe wrench.
  • 5 Lift up on the rear of the slide-in range while your partner lifts the front. Slide the range out of the cabinet opening and out of the house. Lifting the unit will prevent unnecessary damage to your counter tops.
  • Read more : http://www.ehow.com/how_5959888_remove-slide-range.html
    Jan 03, 2015 | Kitchen Ranges
    Where can I find an electric range with depth less than 28 inches
    Bertha, most stoves are going to be anywhere from 26" deep to 29" deep. Most any stove that I have used or worked on has never been a counter depth stove unless it was a slide in or a drop in stove. When I went to GE's website, I did not many stoves that were less than 28" deep until I got up to $1000 in retail pricing. The only one under that price that was less than 28" was also only 24" in width. Hope this helps!
    Dec 08, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
    My pool is 15' X 30 '. Deepest part of pool is 6' in the center. One end of the pool is 3' deep the other end is 4'. What are the gallons required to fill the pool?
    not possible to calculate with the information provided. here is a basic formula to get you close.
    length x width x average depth x height in feet x 7.5 gallons / cubic ft
    Aug 30, 2014 | Pool & Spa
    How many cubic feet is this model of Amana Range?
    actual oven space? Never had anyone ask that before. Even manufacturers don't list that info. Why not just measure depth x width x height (of oven cavity) in inches and multiply to get an estimated total of square inches. Then divide by 144 (the number of cubic inches in a cubic foot).
    Aug 21, 2014 | Amana ARGS7650SS Gas Kitchen Range
    What is width depth height specs
    Good Morning Friend,
    I see that you are looking for the width, depth, and height of the Frigidaire dishwasher, model# FDB636GF. The measurements are as follows:
    Width: 23 7/8"
    Depth: 24 1/4"
    Height: 33 3/4"
    Hope this is helpful.
    -Best regards-
    WP
    May 28, 2014 | Frigidaire 24 in. FDB636GF Built-in...
    Hi,My oven won't light but I can smell gas and hear the clicking when I went to light it Kit. Aid model # KGSS907 Thank you. Steve
    which one is your model KGSS907SBL00 (30`` Slide-In GAS OVEN CONVECTION)
    > KGSS907SBL01 (30`` Freestanding GAS OVEN CONVECTION)
    > KGSS907SBL02 (30`` FREESTANDING GAS OVEN CONVECTION)
    > KGSS907SBL03 (30`` Freestanding Gas Range with Convection Oven)
    > KGSS907SBT00 (30`` Slide-In GAS OVEN CONVECTION)
    > KGSS907SBT01 (30`` Freestanding GAS OVEN CONVECTION)
    > KGSS907SSS00 (30`` Slide-In GAS OVEN CONVECTION)
    > KGSS907SSS01 (30`` Freestanding GAS OVEN CONVECTION)
    > KGSS907SSS02 (30`` FREESTANDING GAS OVEN CONVECTION)
    > KGSS907SSS03 (30`` Freestanding Gas Range with Convection Oven)
    > KGSS907SWH00 (30`` Slide-In GAS OVEN CONVECTION)
    > KGSS907SWH01 (30`` Freestanding GAS OVEN CONVECTION)
    > KGSS907SWH02 (30`` FREESTANDING GAS OVEN CONVECTION)
    > KGSS907SWH03 (30`` Freestanding Gas Range with Convection Oven)
    > KGSS907XSP00 (30`` FREESTANDING GAS OVEN CONVECTION)
    > KGSS907XSP01 (30`` FREESTANDING GAS RANGE WITH CONVECTION OVEN)
    Jan 04, 2013 | KitchenAid KGSS907SSS Gas Kitchen Range
    I am trying to replace my old slide in gas range (Magic Chef- model # 6498XTS with a new slide in gas range and am trying to find out if the new one will fit where the old stove was, here's my problem the...
    The installation depths provided in the installation literature, are the minimum requirements for fitting the slide in range into place. You need to determine what the depth of your opening is where you intend to install the appliance. The depth shown on the installation instructions might be showing the overall depth of the appliance, including the oven door, which typically sticks out from the cabinet anywhere from 1-3 inches, depending on the brand, model, etc. The old Magic Chef might have only provided the needed depth for the oven body, and might not have included the front oven door projection, past the countertop, etc. Most cabinents are about 24 inches deep, so anything larger than that, will likely stick out into the room more, unless your cabinents are deeper than 24", you're looking at having the new slide in oven stick out past the front cabinet front/edge, by about 4 5/16". I'd make a cardboard template to the dimensions of the new oven and use that to see just what you're facing with the replacement oven. It could be possible that you've confused the depth with the width for the new oven, as I've not seen many ovens that are as large as 28" unless it was a Viking, or other really high end, professional style oven, etc. Check your installation dimensions again for the Maytag and make a cardboard template to confirm how much space will be needed. The good news is that you can remove the old Magic Chef, since it's not working, to allow you to make a more informed decision as to fit and clearances required for the new oven. Just be sure to disconnect the power to the range or unplug the power cord, if that's what it has, before attempting to remove the slide in. Hope you find this Very Helpful and best regards!
    Sep 10, 2009 | Kitchen Ranges
    Can you give me easy install directions?
    are yours and hers both freestanding? (do they both have a drawer at the bottom?) if so measure the width to see if hers will fit. if so, turn off the circuit breaker to your stove. remove the drawer of your stove. do you see the plug? unplug it. now just slide it out toward you being careful not to damage the floor. installation opposite of removal.
    Hope this helps
    Oct 31, 2007 | Frigidaire FGF337EC Stainless Steel Gas...
    GE J2B915SS Dual Fuel (Electric and Gas) Kitchen Range Logo
    518 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Mike Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
