Question about Sony Multi-System Mini Hi-Fi system /DVD Shelf System
No sound Sony Stereo Model HCD-G5500 will turn on but no sound. Speakers are ok. Have back off, nothing disconnected or appears melted. What do I look for now?
  • Debby Roller Dec 30, 2008
    I connected the speakers in the proper ports and I get absolutely NO sound. Not even a fuzz or buzz or murmur. No static, nothing. The unit turns on, the cassette tape turns, the CDs turn, the radio tunes, the lights flash--but no sound. Help.
  • lenwalton May 11, 2010
    its a
    NAD 7020 TUNER AMP not a sony
    Genius:
  • Sony Master
  • 1,550 Answers
Check if there got fuses for the speaker and check if them are good
Posted on Feb 11, 2009
Sony hifi no sound
DAC [Digital to Analog Converter] problem. That's its main board problem. If you wish to get some details; check the site linked here. Pull up older posts.
Jul 01, 2016 | Sony Audio Players & Recorders
Sony hcd-ec99i i have no sound from the speakers at all. I am not getting the protect message. please help
Check the simple stuff first
Is it muted?
Is the source selected sending signal (radio staion broadcasting, cd playing, ipod all the way ect)
Try doing some basic troubleshooting like,
see if all sources available yield the same result (TV, Radio, CD, Ipod, Aux jack)
When you turn the volume all the way up, do you hear an audible hiss from the speakers?(or use a test tone) If so, your amp is working and the problem is, your unit is not sending any signal to it.
If possible hook up your speakers to another system to rule them out, however I doubt that is your problem.
Here is sony's recommendation and a review video
Let me know what you get
SONY eSupport How to troubleshoot if there is no sound or intermittent...
Feb 03, 2014 | Audio Players & Recorders
Sony hcd vx55
Hello. I downloaded the manual for the Sony system with the model number MHC-VX55. It seems that the part you are asking about is not a speaker system, but a preamplifie/power amplifier with integrated inputs from CD/Video, tape and tuner. The speakers that connect to the HCD-VX55 are a three way passive design with a nominal impedance of 6 ohms and model number SS-VX55. To answer your question I will assume that you meant you would like to connect the MHC-VX55 system to your computer for playing back audio tracks from your computer. Yes, you can do this. Your Sony system is equipped with an input labelled MD/Video (audio) With a sensitivity of 450 mV, this will (not ideally) the output from your computer headphone jack (if a laptop) or, even better you may have a desktop with an audio output at line level. You will need a simple audio connector with a 3.5 mm stereo plug on each end (very common and readily available for a few dollars. Be careful when setting up that you have your source turned down low and the input on your Sony machine about half way. You will find the sweet settings so that you get good sound without distortion. If you get distortion your source level is too high. Hope this helps. Cheers, Don.
Dec 13, 2013 | Audio Players & Recorders
I have a Sony HCD-451 home stereo. The sound goes in and out every few seconds and there is a clicking sound when it does. I just moved and when I hooked it up after the move it started behaving this way....
Diagnose first. Surgery last.
A big clue is that it started after a move.
Recheck your speaker connections for loose strands that might be touching each other.
If it still clicks and loses sound, disconnect all the speakers and see how that works out. If it's stable (no clicking) add speakers unr\till the problem reappears. Then isolate which one it is/was.
Jan 05, 2011 | Sony Audio Players & Recorders
I have hooked by two bose 161 speakers using 14 gauge speaker wire (about 8 feet) to sony str-dg720. But I get absolutely no sound from the speakers. I have hooked the speakers to port A set of input...
You gots ta isolate the problem.  Disconnect the speakers and hook them up to a stereo you know that works.  If you don't hear sound coming out of the speakers, then you know the speakers are fu.k.d up, so you need to look on the speakers to see if there is a fuse that is blown that needs to be replaced.  If you got sound coming through, then disconnect them and hook them back to the original stereo making sure you got a good connection and all the wires are in good and tight.  Then turn your stereo on and go through the various channels like Tuner, Tape Deck, Aux, and DVD to see if you get any sound.  Also turn the volume knob up. If you don't get any sound after all this, you know there is something wrong with the stereo your using.
Oct 29, 2009 | Sony STR-DE685 Receiver
I need a manual for my SONY stereo. The model no
manual availible at sony website
http://esupport.sony.com/US/perl/model-documents.pl?mdl=HCDHPX9
Oct 03, 2009 | Sony Audio Players & Recorders
My left speaker to my Sony HCD-GX450 stereo is
Make sure that Loudness switch is turned off & bass is not boasted up. Most cars have small cheap speakers that can't handle the bass. also its better to cut the low frequency from the woofer using a passive or active crossover. Most nowadays head units have got some sort of built in crossover. Refer to your head unit manual.
Sep 20, 2009 | Audio Players & Recorders
No sound
When the amplifier will turn on but not produce any sound that is usually an indication of either the high voltage power supply inside the amplifier is not working, or the amplifier IC or amplifier circuit is damaged. It is not something that can be repaired unless you have experience working on electronics.
Dec 30, 2008 | Sony TA-N9000ES 5-Channel Amplifier
Sony stereo model HCD G5500 will turn on but no sound comes from speakers. I tested speakers on other unit and they work. I have the back off. Nothing appears to be melted or disconnected. What else can I...
Check fuse in plug check onboard fuses if all good look for black or blue or ornge little rectangular boxes(relays) should click if not then protection problem and needs to be serviced
233 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
