Question about Home
Leaking Kitchen Tap
Kitchen Tap is constantly dripping unknown how to repsir
    Novelist:
  • 148 Answers
I am assuming that your kitchen tap is leaking through the spout
if it is single lever you will need to remove the crown and spout by removing a small erasure size cap on the housing right under the spout or up near the back of the ever then use a hex wrench to remove the set screw( plug the drain holes do it does not go down the drain)
turn the water off (hot and cold ) under the sink
remove the set screw and lift off the lever
at his point you can take an adjustible wrench(channel lock and tighten the big ring nut that holds the cartridge in place
temorairly put the handle back on and put the handle in the off position turn the water on under the sink and see if it stopped leaking
if it still leaks you have to turn the water back off and remove the lock nut then the cartridge and go to big box store with old cartridge and name of mfg and get a new one and install
If you have seperate hot and cold valves on top of sink deermne which is leaking by turning one off with oher on undr the sink
once you have determined which it is (hot or cold)
take a phillips head screw driver( remove plastic clear cap on top of faucet handle with sharp crewdriver of knife blade) and remove the screw holdin the handle on to the stem(turn counter clock wise
be sure to turn water of under snk on both faucet risers after removing acrylic handle you then take an adjustible wrench and remove the crown nut turn counter clockwise until it comes off over stem
remove stem( looks like size of a pretzel about six inches long with washers on side and one on end
take the stem to local hardware(ace) or big box store and go to lumbing section ask clerk to inspect and recommend replacement washers or replacement stem (if needed)
go back reinstall and tighten crown nut snug( open (turn counter clockwise) tem valve before you snug it down with crown nut
install acrykic or chrome handle with brass phillips screw then ut cap on and turn on water and check for leaks
good luck
Posted on Dec 30, 2008
Newlec calypso shower
the tap head sealing is defected probably
Apr 24, 2014 | Kitchen Ranges
Leaking kitchen tap
It is very easy to stop it just make sure you lock the tap and loose the tap head from the pipe then you get what they call white thread for taps just rap the thread round the tap and you just fix it back
Feb 05, 2014 | Home
Fix a quater turn mixer tap Aumix
change the cartridge...shuld help
Dec 04, 2013 | Plumbing
Hansgrohe 35807801 kitchen faucet leak
On the 35807801 there are generally only two causes of a leak. If the faucet does not seem to shut off and constantly drips it will most likely be the cartridge. This will be part number 92730000. If the faucet is leaking around the sprayer or below the sink the most common cause is the pull out spray hose. This will be part number 88624000. If you need further help locating the parts or a dealer feel free to call Hansgrohe Tech at 1-800-334-0455.
Nov 18, 2012 | Plumbing
Constant drip in the Moen Renzo
turn of the water at the mains waer for the house before proceeding
unscrew the nut under the tap handle to remove the tap handle
look inside for a copper or plastic rod lift it out
you could try your fingers or a set of pointy nosed pliers
this will have a leather or plastic washer attached at the base
hope this helps
Nov 27, 2011 | Moen Plumbing
My system vibrates & resonates loudly when the ordinary tap is switched on. Also, water comes out of the filter tap when it isn't turned on, sometimes in a stream, other times constantly dripping. Have...
You are getting water feeding back to the kitchen faucet from the filter system. A check valve needs to be installed on the line feeding the drinking water system to prevent this. Excess pressure may also be causing these problems. An in-line flow restrictor may alleviate the dripping.
RJ
Oct 27, 2010 | Culligan Under Sink Water Filter
Slow drip near back of lid
Hi there.this may be water dripping from the injector tube where the water actually enters the bowl.It is normal to drip for a short while after the machine has just been used but if it is a constant drip then you probably have a faulty inlet valve.Try this,turn off one of the taps & see if dripping stops.if not,turn off tha other tap & see if it stops.this will tell you which of the valves are leaking.You could just turn the taps off after use,that would save having to replace it.Hope that helped you.if not then give more detail if possible please.cheers!
May 29, 2010 | Fisher and Paykel GWL11 Top Load Washer
Water leaks from around the stem when I lift the water handle. What to do? It doesn't drip from the tap, but from around the stem part - sometimes quite a lot of water. Can I repair this myself? It's a...
ur cartridge needs service or replacement u can turn off water supply remove lever and retaining nuts pull up cartridge and inspect the o rings for debris and or damage if good inspect cartridge for damage if looks check gaskets/o-rings in stem for same add a little vasline around o-rings and reinstall test for leak if leaking still replace all o-rings or if cartridge order and replace
Nov 03, 2009 | Moen 87530 Touch Control Single Handle...
Moen 7065 leaking at base of lever control in kitchen faucet
Yes, a cartridge will probably solve it. There are two different Moen cartridges so be sure to take the old one with you so you get the correct one.
Apr 05, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Home Logo
1,129 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
