Question about Sewing Machines
Can't open Pfaff Select 3.0 Sewing Machine to fix timing
I need to adjust the timing on my new Pfaff Select 3.0 sewing machine, but can't figure out how to open it up. It's got these hex-like screw heads but nothing I try in there budges it. Does anybody know the trick to opening these Pfaff machines?
Also, if anybody knows how to fix the timing on these (from the bobbin casing or from the needle shaft??), I'd appreciate it. My repair guy is out of town and I live in the Virgin Islands and can't find anybody else to fix it.
I found an electric drill with a hex bit and that did the trick!
Posted on Dec 31, 2008
Pfaff 3.5 was working fine,suddenly thread is bunching/getting caught under plate.Thread goes around the bobbin ok,when gets near to needle gets stuck on hook on right side.Any idea how to fix please?
Just guessing. You might try :
Installing a brand new needle
tightening the top tension a bit
If it continues to be a problem, most likely the machine is out of time and requires adjustment. Search for sewing machine timing or take it for service.
Apr 24, 2017 | PfaFF Sewing Machines
Where can I get service manual that will show me the exact procedure from start to finish a adjusting a 145 pfaff sewing machine? I do not need parts manual or service manual to thread the machine?
go google and type in --workshop manual for PFAFF sewing machine model 145
there is a site that is pdf version down load but before you down load it open the version up to see if it is a workshop manual or repair manual and nor service or operators manual
Nov 14, 2015 | PfaFF Sewing Machines
My pfaff 1475 is starting to squeeke on the top of the machine
PfaFF sewing machine squeak Questions & Answers - Fixya
www.fixya.com > Forum > Tags > sewing machine squeak
I need a new mother board for Pfaff creative 1475 ... sewing machine by ... I am unable to disengage the sewing action on my Pfaff 1473CD to wind the bobbin.
Sep 18, 2015 | PfaFF Sewing Machines
How do i fix the screen on my pfaff 2140 creative sewing machine?
Unfortunately it probably needs a new logic board.
Not cheap.
Feb 26, 2015 | PfaFF Sewing Machines
Need a battery for pfaff sewing machine
go to
pfaff sewing machine home page with model ,the use diff type but mostly the flat round 3 v
as in the pc motherboard ,its easy to renew. fritz
Sep 27, 2014 | Sewing Machines
Pfaff 1221 sewing machine stuck in reverse
if you can take the pfaff back and tell them what its doing and have them fix it or get another sewing machine..
Sep 06, 2013 | PfaFF Sewing Machines
Removing top cover on pfaff creative 4.0 embroidery machine
May be, you have not the right tools to open your pfaff chassis. In your case I prefer to get support from pfaff: http://www.pfaff.com/de/692.htmlIt's a risk to open the chassis, you can't see, where it is fixed. If you try to open, the risk is high your pfaff will take damage.
Sep 30, 2012 | Pfaff Creative 4.0 Sewing Machnie
How do you adjust timing on pfaff 138 sewing machine
Take the foot off the machine
Remove the needle plate
Remove the feed dogs
rotate by hand until the needle is at the lowest position
continue rotating until the needle rises 2 mm
the hook assembly should be passing exactly by the scarf of the needle
if not loosen the two screws that secure the the hook assembly and rotate the hook assembly by hand until it is exactly at the scarf of the needle and the distance between the hook and the scarf is .1 mm (almost touching the needle)
tightened the two screws, replace the feed dogs and foot and it should sew perfectly
Jul 30, 2012 | PfaFF Sewing Machines
I need a new mother board for Pfaff creative 1475 CD machine. The Local repair shop can not get one. Where can I buy one so I can get my machine working again?
If you want to learn how to repair sewing machine by yourself, I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional step-by-step repair guide written by an expert. Besides PfaFF sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Aug 18, 2010 | PfaFF Creative 7570
Pfaff 1475 tension problem.
Many users also reported similar bobbin tension adjust problems. But do you know it can be fixed by yourself? I suggest you to order the following product:
It's a professional repair guide written by an expert. Besides PfaFF sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Jun 21, 2009 | PfaFF Tiptronic 2030
Sewing Machines Logo
334 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
