Its on a pc i built myself it has the option to boot from usb in bios but when i select that option and hit enter it wont load the operating system for installation the reason i want to do this is to be able to erase whats on the hrd drive and then reinstall windows whether i select it on bios or boot menu on startup screen..i have a copy of my operating system on a partition on hdd but when it installs it only goes over the last copy tht was on the hdd and doesnt give the option to erase when it loads ...i tried plop and no joy with that either i have 2 drives one has vista and the other win 7 ultimate i also tried command prompt and did the usual diskpart etc etc didnt work ive seen it on youtube been done its my pc doesnt have the same option on screen to erase ok thnx in advance....sean
Rather disconnecting the dvd you could just uninstall your dvd drive then reinstall it after http://www.bootdisk.com/art/penboot.jpg
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives right click select uninstall
or
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to usb,press escape then press f10 to save to cmos to restart
or
hope this helps
Testimonial: "very good its the small things i miss great answer thnx...sean"
Turn on your laptop and look at the first screen that comes up as soon as it is on. This screen will tell you "Press x key to enter setup", replacing "x" with the actual BIOS access key. It's usually "Del" or "F2" on Toshiba systems.
Press the key firmly and quickly before the screen goes away. If you do not react quickly enough, you will miss the window of opportunity to enter the BIOS. On Toshiba systems, this window of opportunity is somewhere between two to five seconds.
Navigate your BIOS configuration screen to the "Boot" tab. It is usually just before "Exit."
As the first boot device, select "USB," or "USB HDD." If you have a "USB ZIP" option, you might be able to boot from it, so select that if you have no other choice.
Press the button for "Save and Exit" in your BIOS. The correct button is usually F10.
hi folks i answered this one myself ...open pc and disconnect the dvd drive then start and it will install from usb then make sure your pc is powered off before you open the pc thnx anway guys i do think there should be an easier way to do this i fyou have on let me know thnx...sean
thanks replying and the testimonial some of us think inside the big square when its the litle square that holds the key anyway hope it all goes well for you
