Question about Samsung YP-T10 Digital Media Player
My YP-T10JAB will not connect to my computer.
PC: eMachines E3014 DDR2 SDRAM 256MB  Intel Centrino D Inside Processor 346   3.06 GHz
When I connect it I get a new hardware wizard and then I install automatically or choose the driver myself which is the digitally signed MTP Driver, it then starts to install. Next it has this screen with the moving green bar (installing). When that goes off it shows me a page which says the volume label, filename, or volume syntax is incorrect. I knew this meant that the location of the driver was incorrect. So i downloaded many drivers and files but every time I searched for a driver in the wizard it only comes up with the MTP Driver which doesn't install.After some research I found out that the MTP Driver comes whith WMP10 but it is not included or something with WMP11 (which I have) so I decide to roll back. I downloaded WMP10 setup and iit extracted and then gave me the "This version of windows media software is not compatible with this version of windows" error. When I researched that i realized I had to delete WMP11 first so I uninstalled it and deleted the files but i still got the error and when I uninstalled the WMP component and opened  WMP11 it opened up fine even though i Uninstalled it. I have run msicuu.exe but it did not fix it. Please help me!
5 Suggested Answers
SOURCE: it says filename,directory name or volume label syntax is incorect
try reformatting the device using the software you use with it. This should fix any naming errors. you will need to put all the songs back though
Posted on Feb 15, 2008
SOURCE: Samsung Media Studio 5 software won't convert video files for player
necesito el programa
Posted on Nov 16, 2008
SOURCE: Doesn't show as a driver
I did it!...
you have to perform all the windows updates, then you have to install "Windows media player 10" (I have installed "Windows media player 11" because on my pc the wmp10 didn't work...).
it seems that YP-Q1 work with some driver hidden in wmp10 or 11...I didn't found them nowhere...
connect the mp3 with the cable usb and test to automatically install the drive... it should work... I did it after a few hours...
sorry for my dumb-english, I must improve it ;)
Posted on Jan 22, 2009
SOURCE: SAmsung YP-K3 MP3 player - Corrupted library ? cannot delete songs or synch
i would like to download other songs but i dont know how?and i have to delete all of them!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Mar 02, 2009
Installing new cpu on a emachine
According to the specs I have Serena, the eMachines eTower 633i Desktop PC, uses a TriGem Cognac motherboard.
[TriGem is the manufacturer, Cognac is the model.
Note it is Not the TriGem Cognac+ ]
http://www.motherboards.org/mobot/motherboards_d/Trigem/Cognac/
Specifications. (You can click on the photo to enlarge)
PDF motherboard manual,
http://www.elhvb.com/mboards/TriGem/manuals/index.html
Click on - Cognac - in the left side of the list.
Going back to the Motherboards.org page;
(Nothing like upside down photo information, and the motherboard is turned 90 degrees to the Right, to how it actually sits in your computer case )
The processor socket is a Socket 370,
http://en.wikipedia.org/wiki/Socket_370
Used for Intel Pentium III processors, and intel 'Celey' processors.
(Excuse me......Celeron.
An Intel Pentium III processor has TWICE the L2 cache, that a comparable Intel Celeron has.
The cache for a Processor is a small memory area for the Processor.
It is the First memory the Processor accesses.
The Ram Memory is second, and the Harddrive is third.
More cache for a Processor makes it more faster )
The motherboard chipset is an Intel 810.
The Northbridge chip of the motherboard chipset, is an Intel 82810.
The Southbridge chip is an Intel 82801AA, or an Intel 82801AB.
(Intel ICH, or Intel ICH0 )
Looking at the chart, and reading across, you can see what the Intel 810 motherboard chipset supports;
1) Processors: Intel Celeron, or Intel Pentium II, or Intel Pentium III.
2) Processor Front Side Bus: (FSB) 66MegaHertz, or 100MHz.
3) SDR Sdram ram memory at 100Megahertz.
[Single Data Rate Sdram is often just referred to as Sdram.
Erroneous.
Double Data Rate Sdram is also Sdram (DDR Sdram)
Synchronous Dynamic Random Access Memory
So is DDR2 Sdram, and DDR3 Sdram ]
Also referred to as PC100.
So when looking for a CPU you look for;
1) Fits in a Socket 370 processor socket.
Yep. The best is going to be an Intel Pentium III.
2) Has a FSB of 100MHz.
Hmmm,............
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_III_microprocessors#.22Coppermine.22_.28180_nm.29
Scroll down.
Pentium III 1100.
Maximum frequency rate ('Speed') is 1.1GHz (1100MHz)
Front Side Bus = 100MHz
Uses a Socket 370 processor socket.
Part Number = RB80526PY005256
sSpec Number = SL5QW
http://www.cpu-world.com/CPUs/Pentium-III/TYPE-Pentium%20III%20%28Coppermine%29.html
http://www.cpu-world.com/CPUs/Pentium-III/Intel-Pentium%20III%201100%20-%20RB80526PY005256%20%28BX80526F1100256%29.html
In the top header -
Specifications / Pictures (1) / CPU ID (1) / Comments (1),
click on Pictures (1)
You can click on the photo to enlarge.
256MegaByte of L2 cache. (256MB)
A comparable Celeron would have 128MB of L2 cache.
http://www.recycledgoods.com/products/Intel-SL5QW-PIII-Processor-1100-256-100-1.75V.html
http://www.impactcomputers.com/sl5qw.html
[ Don't forget to follow Anti-Static Precautions.
Clean the bottom of the Heatsink THOROUGHLY, and the top of the Processor if it needs it. (I always do anyway)
PROPERLY apply fresh, new Thermal Paste.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 26, 2012 | E-Machines etower 633is PC Desktop
Will pc2-5300 memory work in emachines t5082?
Yes it will work
Memory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 2GB
Slots: 2
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.*
*Not to exceed manufacturer supported memory.
Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.
Jul 02, 2011 | E-Machines T5082 PC Desktop
I need to know how much ram my motherboard will be able to run without burning up? I have an Emachines t1090 w/ Windows XP, 900MHz Intel Celeron Processor, 128MB SDRAM, CD-ROM 48x Max. CD-Drive, 20GB Hard...
The max for your system is 512MB. You have two memory slots and one has a 128MB chip so if you want 512MB, you need two 256MB chips and throw away the 128MB.
At Newegg, a 256MB chip is $42+ shipping of $1. I'd consider getting a new computer instead.
I don't think memory upgrade will tax your system cooling.
Sep 09, 2010 | E-Machines T1090 PC Desktop
Looking for specifications on sony vaio pcg-3c2l
Features/Specifications:
  • Sony VAIO VGN-CS115J/R Core 2 Duo T5800 2.0 GHz 14.1-inch Widescreen Notebook
  • General Features:
  • Color: Sangria Red
  • Microsoft Windows Vista Home Premium 64-bit pre-installed w/COA
  • Intel Core 2 Duo T5800 2.0 GHz processor
  • Intel Centrino Processor Technology
  • 4 GB PC2-6400 DDR2 SDRAM (4 GB maximum supported)
  • 250 GB Serial ATA hard drive
  • DVD±RW Double Layer Drive
  • Mobile Intel Graphics Media Accelerator 4500MHD with Intel Clear Video Technology with Total Available Graphics Memory of 1750 MB (max.)
  • Built-in 1.3 megapixel MOTION EYE camera and microphone
  • Intel High Definition Audio with built-in speakers
  • Integrated V.92/V.90 Modem
  • 10Base-T/100Base-TX Ethernet
  • Intel WiFi Link 5100AGN (802.11a/b/g/n) Wireless LAN
  • Integrated Stereo A2DP Bluetooth Technology
  • Keyboard with Touchpad
  • Action Buttons: Play/ Pause/ Stop, AV Mode, Mute, Volume-/+, Capture, WLAN on/off
  • 14.1-inch Widescreen display with XBRITE-ECO Technology (1280 x 800)
  • MultiMedia Card Slots:
  • Memory Stick Pro Media slot (Standard/Duo) with MagicGate functionality
  • Secure Digital media slot
  • Expansion slots:
  • ExpressCard/34 slot
  • I/O ports:
  • Three (3) USB 2.0 ports
  • Headphone jack
  • Microphone input
  • One (1) 15-pin VGA port
  • One (1) i.LINK IEEE 1394 FireWire port
  • RJ-45 Ethernet port
  • RJ-11 Modem port
  • Regulatory Approvals:
  • FCC
  • cULus
This information can be found on Geeks.com
Happy New Year!
Feedback is appreciated!
Dec 31, 2009 | Sony VAIO Notebook
Tried to upgrade ram with 2 new pc133 sticks of 256mb ea. Didn't work. What's wrong? Are there switches on the motherboard I need to change? Or something else?
No there are no DIP switches to change, or jumpers to move on your motherboard, in regards to your BIOS recognizing ram memory installed.
(BIOS. Basic Input/Output System. This tiny program, {64MB in size usually}, that is burned into your BIOS chipset, is what recognizes ram memory on your computer)
Things to know about the older Sdram ram memory.
1.It's really SDR Sdram. Single Data Rate Synchronous Dynamic Random Access Memory.
DDR is Double Data Rate Sdram, DDR2 is Double Data Rate 2 Sdram, and so on.
Point? All ram from SDR to DDR3, IS Sdram.
2.Standards have been set by JEDEC for computer ram memory starting from DDR Sdram on up. This standards were not implemented back in the day of SDR Sdram.
Point? Ram memory manufacturers didn't all follow the same standard, and ram memory made for one computer, would Not work in another computer.
This means you need THE ram memory for YOUR eMachines computer.
Main factors when buying SDR Sdram,
A.Correct type. You know this. SDR Sdram.
168 gold plated contact pins on the bottom of the ram 'stick'. (82 on each side)
B.Correct 'Speed'. ('Speed' is slang for Frequency Rate) You know this. SDR Sdram that operates at a frequency rate of 133MHz. (Or also known as PC133)
C.It must be low density Non-ECC ram memory. It cannot be high density ECC. (Error Control Correcting. Used for Server computers mostly)
D.Correct CAS Latency. Also known as Ram Timings. 3-3-3-3-2 would be normal for SDR Sdram.
E.Correct Chip Configuration. How the DRAM chips are accessed. DRAM chips are the black rectangular chips on each side of your ram memory 'stick'. Also what size the DRAM chips are in MegaBytes. (MB)
F.What the Maximum TOTAL Amount is for the motherboard. Is it 256MB? 512MB? Or more?
G.What the Maximum Amount is for EACH ram 'slot'. (Correct speak for 'Slot' is Bank)
H.Do you have four ram 'slots'? You MUST have a ram stick in Slot 1. This is the slot closest to the processor. It is the first ram slot the processor 'reads'.
Jul 12, 2009 | E-Machines eMachines Desktop PC
Hp Pavilion dv8216tx with 512mb video graphic memory
Then the service engineer needs to go back to school and learn to read. For if you look up the specs to your model. It clearly states:
Processor
Centrino Technology - Intel Core Duo Processor T2300 (1.66 GHz)
Chipset
Intel 945 PM Express Chipset
L2 Cache / FSB
2 MB L2 Cache / 667 MHz FSB
Memory
1 GB PC2-5300 (667 GHz) DDR2
HDD
160 GB Serial ATA, 150 MB/ Sec @5400 RPM
Optical Drive
Lightscribe 8X Double Layer (8.5 GB) DVD +RW/ +R Writer
Graphics
****NVIDIA GeForce Go 7400 Dedicated Video Graphics with 512 MB TurboCache****
Display
17.0" WideScreen (WXGA+) with Dual Lamp and Ultra BrightView Technology
OS
My suggestion^ Go to someone who knows about computers and who knows how to read too. Hope this is helpful.
Good Luck =)
May 29, 2009 | HP xw6600 Workstation with 650W 80 PLUS...
Buying a notebook
Please go for this my friend has bought its rockz man
Compaq Presario V6700TX series Operating system
s.gif Operating System
  • Genuine Windows Vista Home Premium (32-bit)
Processor
  • From: Intel Core 2 Duo Processor T5450 (1.67 GHz, 2MB L2 Cache, 667MHz FSB)
  • Up to: Intel Core 2 Duo Processor T7250 (2.00 GHz, 2 MB L2 Cache, 800MHz FSB)
s.gif Processor
  • Pentium Dual-Core Mobile Processor T2330 (1.6 GHz, 1MB L2 Cache, 533MHz FSB)
Display
15.4" WXGA high-definition widescreen with BrightView s.gif Display
15.4" WXGA high-definition widescreen display with BrightView Dimensions
14.05 (L) x 10.12 (W) x 1 (min H)/1.69 (max H) s.gif Dimensions
14.1 (L) x 10.11 (W) x 1.29 (min H)/1.58" (max H) Weight
5.99lbs
Weight varies by configuration s.gif Weight
6.4 lb.
Weight varies by configuration Communications
Available Intel PRO/Wireless 3945ABG network with optional Bluetooth s.gif Communications
802.11b/g wireless LAN Broadband wireless
N/A s.gif Broadband wireless
N/A Graphics
Intel Graphics Media Accelerator X3100 s.gif Graphics
Intel Graphics Media Accelerator X3100 PCI expansion
Expansion port 3 connector s.gif PCI expansion
N/A Memory
From 1.0GB to 2.0GB DDR2 SDRAM s.gif Memory
From 512MB to 2.0GB DDR2 SDRAM Hard disk drive(s)
Up to 160GB 5400 rpm Serial ATA hard drive
Price $789.99*
regards-balisonu79
Feb 15, 2008 | Computers & Internet
How will i repair my toshiba satellite pc
There will be no damage to the laptop but what I think has happened is the adapter has blown try to replace it take the adapter to get checked out. After the lightening attack did the computer run till the battery run out if so the adapter is the problem.
Jan 20, 2008 | Toshiba Satellite A60 Notebook
Are they compatible?
Hi, your cpu currently in the machine should be a 754chipset, only way you would be able to put a core duo processor in the machine would be to replace the motherboard, cpu, and probably the memory.. to DDR2
Have a good new year
John
Dec 29, 2007 | Intel Core 2 Duo E6600, 2.4 GHz E6600...
Samsung YP-T10 Digital Media Player Logo
1,259 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
