Question about Sony Vaio VGN NS20E Laptop Car- Air DC Adapter 15-17v (AC22VPNM3NNWY) AC Adapter
Cursor freezing cursor freezes constantly
  • Sony Master
  • 27,725 Answers
For a standard trackball mouse, unplug the mouse, turn it over and then twist the retaining ring counter-clockwise to remove it.
Remove the trackball inside the mouse.
Clean the trackball with warm water and dry carefully. Clean the rollers inside the mouse with a cotton swab dipped in rubbing alcohol. Replace the trackball, then secure it with the retaining ring.
Clean the outside of the mouse with rubbing alcohol and a cotton ball.
For an optical or wireless mouse, clean the bottom of the mouse and the surface it sits on with a damp cloth.
Solve Hardware Problems
Make sure the mouse is connected properly.
The connector will either be USB or PS/2. A PS/2 connector is color-coded green and can only be inserted in one direction.
Check for any bent or broken pins or damage, then carefully plug it in, making sure the connection is secure. Reboot the computer.
Connect the mouse to another computer, then reboot the PC.
If the mouse works after testing it on another computer, the problem is most likely with your PC or operating system.
Also, try a different mouse on your computer.
If there is no PC freeze, your mouse is probably malfunctioning.
Switch to a different USB port. Sometimes mouse freeze will occur if the mouse is connected to a USB hub.
Connect the mouse directly to one of the USB ports on your PC.
Try different ports until you find one that works.
Replace the batteries.
If you have a wireless mouse, replace the batteries with fresh ones.
Also, try using a different kind of mouse pad.
Sometimes surface imperfections can interfere with the operation of a wireless or optical mouse.
Install more RAM or memory.
If your PC doesn't have enough memory, PC mouse freeze may occur when you are running resource intensive programs.
Installing more RAM will help your PC run more efficiently.
Solve Software Problems
Check for device conflicts. When you install another device on your computer, it can sometimes conflict with a PC mouse.
Remove any new hardware and drivers you may have installed, then reboot the computer.
Reinstall PC mouse drivers. In Windows, open "Control Panel" then "System."
Select the "Device Manager" tab, then scroll to and select your mouse.
Uninstall any drivers that are listed.
Unplug the mouse and reboot the PC.
Plug the mouse back in, reboot the system, then allow Windows to reinstall the drivers if prompted.
Remove viruses.
PC mouse freeze and other serious problems can be caused by viruses lurking on your system.Set the program to run a complete scan every 24 hours.
Also make sure the virus definitions are updated regularly.
Turn off video acceleration. Sometimes video acceleration can cause PC mouse freeze.
Go to "Control Panel," then click "Display," and then "Change Display Settings."
Click the "Advanced Settings" button, then the "performance" tab. Set the acceleration slider to "None," then reboot.
Repeat the process moving the slider up one notch until you have the maximum amount of acceleration with no mouse freeze
hope this helps
Posted on Oct 10, 2012
How to fix frozen cursor on Toshiba latop
There are a multitude of reasons why a cursor may be frozen. If you start your laptop in safe mode does it still freeze?
Repeatedly press F8 while your laptop turns on to get into safe mode.
You may have a lot of programs loading in the background that could cause your computer to freeze
Does the keyboard freeze at the same time?
Reply with some more info and I will help you
Mar 14, 2015 | Toshiba Computers & Internet
My G5 freezes constantly. What can I do.
Try running Apple Hardware Test on the machine (it's one of the discs that came with the machine.) Also, if it's freezing by showing the spinning rainbow cursor (beachballing) you may have a failing hard drive. That wouldn't be uncommon for how old the machine is.
Feb 24, 2015 | Apple PowerMac G5 Dual Mac Desktop
Acer Aspire One Netbook Freezes Constantly Playing Video
ive got a kav60 netbook and the video and audio freezes, makes a nasty buzzing sound. i also have a problem with my mouse, it goes crazy, or sometimes doesnt respond unless i apply pressure to one side of the netbook (slightly bending). tried disconnecting the touchpad, and applying an external usb mouse, but it sometimes freezes the cursor,or the cursor does its own thing. please help
Aug 23, 2012 | Computers & Internet
How can i keep my cursor/ponter from feezing my cursor for my laptop keeps freezing up and i have to keep restarting my computer to get it undone
If it does press control,alt, and delete witch will u freeze it and bring it to the center of the screen. There is really no way to prevent your curser from freezing.
Mar 15, 2010 | Acer Computers & Internet
Mouse Pad freezes
Will you please try these.
FN+ Following marked ker.
36a19f7.jpg Thanks & waiting for your feed back.
Feb 10, 2010 | Samsung NC10-14GW PC Notebook
My cursor freezes and the screen goes blank. The
Try to update your machine's BIOS. Download it from the internet (search for the Gateway drivers - bios).
Jul 01, 2009 | Gateway M-6843 Notebook
Freeze panes doesn't work in mac excel
HOW TO FREEZE THE TOP ROW OF EXCEL FOR MAC:
Wow - using the above ideas I figured out how to freeze the top row!!! Thanks guys!! Here's how:
1.) Use 'Normal' View (i.e. look up at tool bar, hover over 'View' and make sure 'Normal' is checked)
2.) Select cell B2 (only the cell, not the row or the column)
3.) Click 'Window' (from the tool bar at the top of your screen)
4.) Click 'Freeze Panes'
...et voila! :-)
Apr 09, 2009 | Apple Mac Pro Desktop
Curser freeze when battery connected
other things works ok does u sytem work ok after this , actually battery has nothing to do with ur cursor pls tell me in detail abt ur problem
Feb 24, 2009 | Acer Aspire 3000 Notebook
Cursor freeze
leave it close to a warm oven..just kidding..
that happens for a variety of reasons..go to control panel, and mouse..and check the settings for the speed and other issues of that cursor setting..
check your computers warranty here 4 FREE
Mar 10, 2008 | Toshiba Satellite A135-S2276 Notebook
Sony Vaio VGN NS20E Laptop Car- Air DC Adapter 15-17v (AC22VPNM3NNWY) AC Adapter Logo
113 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
