Question about Bissell Velocity Bagless Upright Cyclonic Vacuum
2 bagless bissells,filters ,hoses clean,great power.
Cannot get anything to reach the container that you empty on both vacuums..
  • 36 Answers
Have you looked all down the hoses making sure they arent clogged
Posted on Aug 01, 2009
My vacuum is not picking up like it sould and the container is empty what should i do
Check to see that the brusk is turning, if not you have a broken belt. You did not say if you were having issues with the hose and attachments, using it to vacuum the floor or both. If both are working less than normally you probably have filter issues, there are four filters on your machine. The Bissell web-site lists those filters and belt.
Dec 14, 2011 | Bissell 3576 CleanView II Bagless Upright...
Will not **** up dirt no suction
Here is a tip that I wrote about my Bissel but I bet you have the same problemand the hose is clogged...
If the hose checks out then the filter will need to be cleaned/replaced...I have found that many people do not realize that the filter also is a regular maintenance item and that they need to be cleaned and/or replaced often, just emptying the dirt does not keep the vacuum working well...
Bissell Bagless Upright Vacuum not working
heatman101
May 19, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have bissell powerforce turbo bagless upright vacuum. Its a great machine. It is clogged though. I think I was not emptying the dirt collection tray thing enough. How can I unclog it. Its not sucking up...
remove the hose , clear that , then if you take a wire hanger apart you can pull whatever is remaining out of that connection, also remember to clean ( if you have the cleanable filter) the filter and also the top one
May 18, 2011 | Bissell Vacuums
Is blowing dust out as I vacuum
In your manual:
Visible dirt escaping from cleaner
Possible Causes: Remedies:
1) Dirt Container full 1) Empty Dirt Container
2) Filters missing or installed incorrectly 2) Check Upper Tank, Pre-Motor and Post-Motor
Filters for correct installation
3) Dirt Container installed incorrectly 3) Pull out and re-insert Dirt Container correctly
Feb 01, 2011 | Bissell 6591 Power Trak Revolution Bagless...
Vacuum won't pick up
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
May 28, 2010 | Dirt Devil Vision Turbo W/Bonus Upright...
My Bissell TurboForce Bagless Turbo Brush doesn't work
clean the filters..on atop the dustbin, inside the dustbin bottom..and over the fan below..if not sqeaky clean you loose suction
Sep 07, 2009 | Vacuums
Bissell lift off pet-no suction through base (hose is fine)
I had a similar problem with mine. When you take the collector container out, if you reach your hand up, you will fill a round, plastic piece. Gently turn it and the piece pulls out. On the outside of the piece is a foam filter that may be plugged. There is another filter underneath the collection container in a pull-out drawer. Both filters can be washed with cool water, allowed to dry totally, then replaced. I understand that both of these filters need to be washed "frequently". It worked for me, hope it works for you.
May 08, 2008 | Bissell 37604 Lift-Off Pet Bagless Upright...
Bissell Powerforce Bagless Vacuum
Either your hose is plugged, or the inlet by the brush roll is plugged. Another problem that can cause this is the the filters are clogged or may just need to be replaced. Most of these has a filter in the dust catch bucket, and also above the bucket. Make sure all filters are clean.
Jan 05, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Bissell powerforce bagless upright vacuum 6594-w
Be sure when you put the dirtant dust container in place that it is in properly. I have had this and believe it or not this container has enough room to fit without it seating properly. Take the dust container out and reseat it making sure the bottom is secure and then turn the lock lever in place. Try it again. What happens is you get an air gap which allows some air to flow but the vacum does not function properly.
desmjs
Aug 26, 2007 | Bissell 6594 PowerForce Bagless Upright...
Bissell Velocity Bagless Upright Cyclonic Vacuum Logo
66 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
