Question about Panasonic Microwave Ovens
Should the door creaks
When the microwave is cold it is quiet but after it has heated food the door creaks when opened and closed. The microwave is brand new but arrived with a dent on the left side panel near to the front / hinge. I don't want want to have to go through the trouble of returning it but if the dent is causing problems with the door, creating the creaking noise and maybe other problems with the seal then I will have to return it.
  • Panasonic Master
  • 9,098 Answers
I'd say you're right that the damage is causing the problem when the material expands.
This will eventually wear away the material and could lead to other problems unless you lubricate the tight spot regularly.
As much trouble as it is, I think returning it will mean less trouble than you may face otherwise.
Posted on Jan 01, 2009
Microwave heats, light come on, turntable turns, door opens/closes properly, but when heating food it starts buzzing and flickering
Replace if you are not in to DIY, sounds like the inside of the cabin has been compromised and it is now arcing. or watch this You tube video, can potentially be a fix
https://www.youtube.com/watch?v=EZmKTpaAUUQ
Dec 18, 2017 | In Microwave Ovens
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
I need to know how to operate my Kenwood KGTS23 Microwave. I put it on, operate it on how I understood it, but it doesn't warm my food (it remains cold) Please where can I get a user guide/manual for...
Use a microwave safe dish and put in some water. Now open door and keep the dish on the glass plate. Close the door, select the power to be medium or high. Or choose a fast cook. Press 0 and the start button as the microwave should start up. If there is no heat after the cycle then it is possible that the magnetron, the capacitor or the fuse is open.
Jan 08, 2011 | Microwave Ovens
My microwave does not heat up food, it looks ok buy does not heat up at all
Please check your door safety interlock switches. Find them inside on the side opposite the hinge. If they measure open both with the door open and the door closed, they must be replaced. You are looking for one or more micro switches.
These switches are how the device knows whether the door is open or not - forget what YOU know about the door - the device must know the door is closed in order to turn on the heat.
Thanks for your question at FixYa.com
Dec 21, 2009 | GE JVM1630 Microwave Oven
My spacemaker just stopped heating food. What do
This is a microwave, correct?
I suspect the door lock interface switch(es) are burned out. Unplug it, be mindful of the 25,000 volts in the silver thing. Check the micro switches (look where the door closes on the top right side, probably) two positions, normally open or normally closed. check them for proper operation.
Micro switches are the most common of microwave failures because most of us open the door while the machine is running causing arc at the switch and burning up the little contacts.
Sep 07, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
MICROWAVE NOT HEATING
I have the same problem. Everything seems to work except it doesn't heat up food.
I remember last time when it was working. I pressed the start botton before I closed the door. So it didn't start automatically, and I pushed start and it worked(it still heat up the food), but it doesn't work now. Help Please!!!
I have a Whirlpool Gold GH5184XPQ.
Thanks in advance
Aug 27, 2008 | Microwave Ovens
Self start when door closes
if electronic control, one of two things come to mind. 1)your toutch pad is defective.replace it. 2)you electronic board has a leaky component.not very likly though. believe it or not, ive seen it start before by itself then i noticed a large quantity of bugs inside the glass which i realised triggered the microwave 0ff.
Jul 23, 2007 | GE JVM1460SA Microwave Oven
Microwave Ovens Logo
87 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
