Question about KitchenAid KCMS1555RSS Stainless Steel Microwave Oven
Stopped heating food
The other day, when microwaving food, I stopped the microwave to take the food out and did not cancel the remaining time and left the door ajar. A few minutes later , I heard a humming sound and tracked it down to the microwave running with the door ajar and the smell of a burning motor. Now it won't cook. Help!
  • KitchenAid Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here onFixYa:.
You can find helpful exploded view diagrams and order parts for many brands by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you may be able to download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Jan 01, 2009
  • morphneo Sep 07, 2011
    My problem is similar, but the microwave only "runs" when the door is closed, but does not heat the food. Does this also sound like a bad door switch or a loose door switch mount? I have the exact same model as mentioned in the original post. Some of the links in the response seem to be outdated, but I did find the parts listing here: http://www.appliancepartspros.com/partse...
Hamilton beach microwave stopped working suddenly. attempted to heat a breakfast sandwich...and it stopped working after heating a food item moments before. I purchased the microwave within the previous...
Typically, you have the first 30 days to exchange a new purchase. I would pursue that avenue. If you bought it online, it's probably freight related. Try to file a claim..
Oct 31, 2013 | Hamilton Beach 1.1 Cu. Ft. 1000-Watts...
Ge microwave stopped heating food
The problem is in the magnetron/inverter board if less than 7 years.
Apr 09, 2012 | GE Profile Spacemaker Over-the-Range...
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
The microwave just stopped working after heating some food. When left plugged in, the light stays on, the table turns, it sounds like it is running, but does not heat anything. The touch controls do not...
The problem is the magnetron. This is the part of the microwave that heats the food. partselect,com likely has your part with a diagram and great prices.
May 14, 2011 | Microwave Ovens
Odd buzzing after timer stopped, food was still being heated
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
r6uw
Aug 20, 2009 | Whirlpool MH1150XM Convection/Microwave...
GE turn table microwave stopped warming food
my microwave 1640GB from GE suddenly cannot heat food and make some noisy sound. as it is mounting in the closet, it is not easy to replace. any solutions or suggestion
Mar 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave run with a different noise and stopped heating up food
heatman101
fkj
MY microwave just stopped heating things
therrmal resistor bad . Mine quite working and I found one of two resistors bad. Seemes to be a common problem.
Feb 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
KitchenAid KCMS1555RSS Stainless Steel Microwave Oven Logo
252 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
