Question about Dryers
Getting a f-40 code on a kenmore 110.67062600
F-40 flashes if the communication between the machine control and motor control is lost, have already changed machine control board still getting f-40
  • 91 Answers
Sounds like a oasis dryer ,, repl main control board,remembe there are 2 boards
Posted on Jan 03, 2009
My kenmore elite calypso has a code of ce
CE Communications ErrorIf there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Some common causes of CE errors include:
· Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
May 09, 2010 | Washing Machines
Kenmore elite oasis dryer model #110.6708 will not operate. flashes f-40. what does f-40 mean?
F40 = thermal fuse blown.
If the fuse is OK the error points to a communication problem between the machine control board and motor control board (check connectors).
Mar 19, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
Kenmore oasis dryer model 110.6706 flashing F40 code is it the motor control board? I have already had this replaced 18 months ago
Just had one of those calls today......what I found this time was simply that the blue communication wire harness (I think it's a 3 wire, very easy to spot, runs from the side of each control board) had popped loose from the MCU. Inspect each connection for damage, and re-seat the connectors back into the controls. If that doesn't do it, you can measure for voltage (no fun with those tiny connectors) to the MCU. The code F-40 simply means loss of communication between the CCU and MCU. So it actually could be either board. Check it out and re-post if needed.
Nov 10, 2009 | Kenmore 67082 Electric Dryer
It is flashing F 40 and will not run
F40 is a OASIS DRYER error that appears between the machine control and the motor control when communication becomes lost. Check the connection between the two. The error codes will be on the tech sheet beneath your console panel along with how to check for this error.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 10, 2009 | Kenmore Oasis HE 27082 Top Load Washer
The washing machine displays error code CE for communication error
Hi, Well if there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
Some common causes of "CE" errors include:
1.Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
2.Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
3.Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
4· Drive motor thermal protector has opened.
5·Motor controller is not powered or fuse has opened. Replace motor controller.
Press STOP/CANCEL to clear the display.
I hope it helps. Thanks! mannu_rakesh
Sep 02, 2009 | Kenmore Washing Machines
Code ce flashing
Jun 27, 2009 | Kenmore Washing Machines
Kenmore Elite Top Loader "CE" error code.
CE means communications error
If there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
·Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
Dec 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore HE3 stops in middle of cycle, flashes F-11.
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
Dec 08, 2008 | Kenmore Elite 45986 Front Load Washer
F Code
the display is showing u something else look for the F then another letter or number. F is not a valid code
Sep 28, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Dryers Logo
172 people viewed this question
Top Dryers Experts
