Question about RCA T25061GY 25 in. Combo
RCA T25061GY Need to find VCR motor switch or is there a kit to elimate the guts of this combo unit and turn it into a monitor only.
SOURCE:
  • 4 Answers
SOURCE: Need code for Emerson TV,DVD,VCR Combo
I don't have a code book for you, but I can tell you how to program the RCR660 using the automatic programming feature.
Programming RCA model RCR660 (no code search button)
While following these instructions, keep the following in mind:
device = the component you wish to control with your remote (TV, DVD, VCR, etc.)
DEVICE = the button labeled for the component you wish to program
1. Turn on the device you wish to program.
2. Turn off all other devices in the general vicinity.
2. Press and hold DEVICE
3. While holding DEVICE down, press ON/OFF and hold them both down until the LED turns on for that device.
4. Release both buttons.
5. Point the remote at the device, press and release PLAY and wait 5 seconds or until the LED stops flashing.
6. If the device does not turn off, then continue to press PLAY and wait the required interval (for a maximum of 20 times) until the device turns off.
7. When the device turns off, press REVERSE, wait two seconds and continue doing this until the device turns back on.
8. To finish programming, press and hold STOP until the LED turns off.
Posted on Dec 31, 2007
bubba10560
SOURCE: programing rca remote for dvd/vcr combo
all you have to do is press and hold code search when the light shows up let go of code search then press VCR and it will blink onces and let go of VCR and press OFF/ON about 50 times and then press enter onces and there you go
Posted on Mar 07, 2008
  • 28 Answers
SOURCE: rca tv/vcr combo model T13208
Recording speed is the last item on the timer programming. SP or SLP. Some remotes have a button that will allow you to change the speed, when recording manually.
Posted on Sep 18, 2008
  • 71 Answers
SOURCE: rca universal remote RCU300TMS
Here is your manual.
http://66.77.167.109/rcaaccessories/docs/man/RCU300T_DOC_OM.PDF
If you want to find the code for your TV, use the automatic code search function on page 8.
Hope it helps!
Posted on Oct 13, 2008
Xtremeroofin
  • 67 Answers
SOURCE: unervisal remote rca rcr321w for sylvania vcr/dvd
http://remotefinder.rca.com/default.aspx?site=rca
This link is what you are looking for
Posted on Dec 23, 2008
How do I hook up my Toshiba DVD player to my old Daewoo Tv /vcr combo
what inputs does the old Daewood / VCR combo use is it RCA and Video cable on an AV input? How many Av inputs are there in TV ? Does the DVD player have AV out audio out (Yellow) RCA (Red and White). If you do not have enough AV inputs on the Tv use an AV switch box . and Switch two AV RCA inputs /DVD and VCR and into one output to the TV. You may be able to feed the AV out RCA out into the VCR AV in and switch the input on the VCR.
May 25, 2015 | Toshiba Televison & Video
My tv says dew on it how do i fix it
Hello
This is a common fault seen with VCRs. If the drum motor head gets misted, the due sensor connected with it will sense it and will show "Dew" on display. Let the set switch ON for some time, say over 2 hours or so. The switch it OFF and the switch it ON again. If this process doesn't help you, the dew sensor circuit inside the VCR section of your combo must be checked well. It is not a user repairable item. Contact any experienced service technician or RCA Authorised Service Center at your town. OK.
Aug 07, 2011 | RCA T09085 9 in. TV/VCR Combo
I need a code to to turn my tv combo vcr its RCA and so is the the universal remote
An RCA 4-device Universal Remote codes for an RCA tv/vcr combo are 1000, 1003, 1004, 1005, 1006, 1007, 1019, 1054, 1055, 1082, 1096, 1098, 1099, 1100, 1101, 1102, 1103, 1129, 1179, 1181, 1188, 1190, 1196, 1202, 1203, 1212, 1215, 1233, 1257, 1258, 1266, 1278, 1279, 1281, 1286, 1352 . These are the possible codes that RCA gives.
Mar 10, 2011 | RCA 4-Device Universal Remote
I HAVE A 61'' DLP RCA PROJECTER SCREEN AND THE BLUE INDERCATER LIGHT KEEP BLINKING THE SCREEN IS BLACK AND NO SOUND
YOU NEED TO REPLACE THE POWER SUPPLY,,, ITS CAUSED BY BAD CAPACITORS. YOU CAN GET THE PART AT TVPARTSANDMANUALS. COM AND GET CREDIT ON THE CORE..
PARTS COME WITH ONE YEAR WARRANTEE
Dec 15, 2010 | RCA T25061GY 25 in. Combo
Have rca tv combo unit have rca universal [rcu600m] cant seem to
RCA 000,006,011,019,027,034,038,044,046,088 <-----codes
Programming a Device using Code Search:
1. Manually turn ON your device (TV, VCR, Cable Box)
2. Press and "HOLD" CODE SEARCH
3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
4. Release CODE SEARCH.
5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
6. Once the device turns off, press and release ENTER.
7. With the device on, press any other button.
If the device responds, no further programming is required.
If the device does not respond, repeat steps 1-6.
Nov 09, 2009 | Televison & Video
Phillips magnavox tv/vcr combo need codes to program remote
most universal remote controls will not operate the combo type units. Contact www.remotes.com for a repoacement remote.
Nov 24, 2008 | RCA Universal Remote Control
RCA T25061GY TV/VCR
Replace the SAW Filter.
Jan 21, 2008 | Toshiba 19A26 19" TV
No sound
you can find the amplifier NEAR the cable connector from speaker. it is usually looks like a comb in standing position attatched to a aluminum heatsink. good luck!
Feb 03, 2007 | RCA T25061GY 25 in. Combo
Vcr non-function
Theres no reset as I know but I only had a couple of these types of RCA and both had tv problems.. In todays VCR's there are no belts to replace or go bad. Mostly all nylon gears and plasic chassis. Most of the faults that lie with todays VCR's are bad Capstan motors ,defective tape loading carriages, defective mode switchs or sometimes even bad cylinder motors. If any of the gears break or cracks it will completely throw the unis mechaism out of alighnment and you will need to know from the manual where to set every gear ,lever and switch or it will never work.. Thats why most VCR;'s today are throwaway as you have to buy a service manual spoend time finding out why the mechanism dosent work and then buy the parts to correct the fualt. Good Luck to ya and heres a # you can call if you do decide to take the unit in for service by an RCA guy.. https://www.rca.com/secure/service/contactrca/1,,,00.html
Apr 19, 2006 | RCA T13208 13 in. TV/VCR Combo
Televison & Video Logo
52 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
