Question about Sony TA-N9000ES 5-Channel Amplifier
Sony stereo model HCD G5500 will turn on but no sound comes from speakers. I tested speakers on other unit and they work. I have the back off. Nothing appears to be melted or disconnected. What else can I look for?
  • 85 Answers
Check fuse in plug check onboard fuses if all good look for black or blue or ornge little rectangular boxes(relays) should click if not then protection problem and needs to be serviced
Posted on Jan 08, 2009
Sony hcd-ec99i i have no sound from the speakers at all. I am not getting the protect message. please help
Check the simple stuff first
Is it muted?
Is the source selected sending signal (radio staion broadcasting, cd playing, ipod all the way ect)
Try doing some basic troubleshooting like,
see if all sources available yield the same result (TV, Radio, CD, Ipod, Aux jack)
When you turn the volume all the way up, do you hear an audible hiss from the speakers?(or use a test tone) If so, your amp is working and the problem is, your unit is not sending any signal to it.
If possible hook up your speakers to another system to rule them out, however I doubt that is your problem.
Here is sony's recommendation and a review video
Let me know what you get
SONY eSupport How to troubleshoot if there is no sound or intermittent...
Feb 03, 2014 | Audio Players & Recorders
Sony hcd vx55
Hello. I downloaded the manual for the Sony system with the model number MHC-VX55. It seems that the part you are asking about is not a speaker system, but a preamplifie/power amplifier with integrated inputs from CD/Video, tape and tuner. The speakers that connect to the HCD-VX55 are a three way passive design with a nominal impedance of 6 ohms and model number SS-VX55. To answer your question I will assume that you meant you would like to connect the MHC-VX55 system to your computer for playing back audio tracks from your computer. Yes, you can do this. Your Sony system is equipped with an input labelled MD/Video (audio) With a sensitivity of 450 mV, this will (not ideally) the output from your computer headphone jack (if a laptop) or, even better you may have a desktop with an audio output at line level. You will need a simple audio connector with a 3.5 mm stereo plug on each end (very common and readily available for a few dollars. Be careful when setting up that you have your source turned down low and the input on your Sony machine about half way. You will find the sweet settings so that you get good sound without distortion. If you get distortion your source level is too high. Hope this helps. Cheers, Don.
Dec 13, 2013 | Audio Players & Recorders
Sony HCD-LX10000 will power on then turn back off
Check the speaker wires on the back for shorts, if okay! the problem is in the audio output ic's in the stereo.
Apr 22, 2012 | Sony MHC-GX450 CD Shelf System
I have a Sony receiver/tape deck/cd system, and need a copy of the owners/users manual in order to use the presets and other features to best advantage. The model of the unit is HCD250 or Hcd-G2000. I was...
http://www.givemefile.net/smanuals/hi-fi_hi-end--others/sony/hcd-g2000_26718.html
Above is a service and repair manual for the Hcd-G2000.
Below is your user guide.
www.devicemanuals.com/guide/.../Sony/Sony-Bookshelf-Hi-Fi-System-HCD-F250AV-User-Guide-TXpZek9EST.html
Support links for Sony below.
esupport.sony.com/
HCD250 service repair manual below.
http://www.givemefile.net/smanuals/stereos/sony/file/8297.html
Aug 24, 2010 | Audio Players & Recorders
Sony HCD-GX450, locked up.
Electronics have gone to heaven. Bury it and get a new one.
May 08, 2017 | Sony Audio Players & Recorders
My left speaker to my Sony HCD-GX450 stereo is
Make sure that Loudness switch is turned off & bass is not boasted up. Most cars have small cheap speakers that can't handle the bass. also its better to cut the low frequency from the woofer using a passive or active crossover. Most nowadays head units have got some sort of built in crossover. Refer to your head unit manual.
Sep 20, 2009 | Audio Players & Recorders
No sound
Check if there got fuses for the speaker and check if them are good
Dec 30, 2008 | Sony Multi-System Mini Hi-Fi system /DVD...
No sound
When the amplifier will turn on but not produce any sound that is usually an indication of either the high voltage power supply inside the amplifier is not working, or the amplifier IC or amplifier circuit is damaged. It is not something that can be repaired unless you have experience working on electronics.
Dec 30, 2008 | Sony TA-N9000ES 5-Channel Amplifier
Sony hcd gx450 blinking problem
your speaker are hooked up wrong.or there may be dust in or on the terminals.i used a q-tip with rubbing alcohol and wiped them down.hook up the speaker cords properly and try this again.if this does not work then unplug the stereo and let it sit overnight and try again.
Dec 04, 2008 | Audio Players & Recorders
Sony TA-N9000ES 5-Channel Amplifier Logo
498 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
