Question about Whirlpool GEW9250 Electric Dryer
Whirlpool Electric Dryer wont turn on
Approx 8yr old Whirlpool Electric Dryer 4 cycle 3 temp. just quit working. When we push the button it makes a noise like it is trying to start turning, but then it just stops. What could be the trouble?
  • Whirlpool Master
  • 3,463 Answers
Try this;
In your browser bar type in
In the search box type in repairing whirlpool dryers
Then click on the apprpiate video.
This should help you.
Plz rate my solution.
Posted on Dec 31, 2008
My dryer heats up,, glow works, igniter works,, then cycles approx 3-4 times then stops cycling
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
Oct 18, 2010 | Whirlpool LGV4634JQ Gas Dryer
I own a 4 yr old whirlpool duet dryer and controls locked light came on and can not get it to go off
Look for the End of Cycle button at the extreme right hand side of the console then press and hold it for 3 seconds or until the Control Locked light turns off. The instruction is actually printed right below the button. The control lock is a safety feature of the dryer to prevent settings manipulation during the drying cycle.
Unplug the dryer for at least 15 minutes to reset the central control unit if the control cannot be unlocked using the End of Cycle button. Let us know if it's still cannot be unlocked even after the machine is unplugged.
Apr 11, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool Calypso dryer GEW9868KL2
It is one or two things. Motor start switch or the motor itself.
Aug 11, 2009 | Whirlpool GEW9868K Electric Dryer
Just purchased a used Whirlpool Duet dryer(2 to 3 yrs. old). I hooked it up and placed it on a normal automatic cycle. The unit started up a little noisey but quitened down in approx. one min. Shortly...
try replacing the power cord, and make sure that you have a "dedicated" power sorce for the plug. The system board will shut the dryer down if a power supply issue is detected. This feature is to prevent fire hazards. Make sure your electric box is grounded and up to code.
Jun 26, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool Dryer Does not dry
Its the thermal fuse. when you jump or, by-pass the cycle thermostat, you are basically by-passing the fuse as well. replacing the thermal fuse will fix thsi issue.
The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
Dryer wont start - no lights
Dryer door does not think it is closed. There is a sensor on the top of the door that is probably not making contact with the door. Trying pushing the top part of the door and holding it then press the start button.. if the unit starts running then you know what it is. I just had one of these dryers delivered today and had to find out about this by myself tonight!!
Apr 30, 2009 | Whirlpool WED9500T Electric Dryer
Dryer does not work
Dryer just beeps, lights work, panel lights change, dryer just wont start. before this dryer worked but kept beeping thru the whole cycle. now nothing but lights.
Mar 13, 2009 | Whirlpool GEX9868J Electric Dryer
Dryer problem
try pressing the End of Cycle button on the far right for more than 3 or 4 seconds.  It should reset.
Dec 28, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
310 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
