Question about Veo Stingray
What schould i do
I can't take a picture but every thing works
    President:
  • 8,637 Answers
Normal 0 Install Skype and you will be able to take a picture of yourself. Not sure why it won't let you take pictures as you have it installed.
First, download SKYPE by double clicking on this site: (http://www.skype.com/intl/en/download/skype/windows/beta/ ).
and install it.
Then let all your family and friends know you’re on Skype and give them your ID. After they get on Skype and you know their ID's add them to you Contacts in Skype. After you connect up with them you can turn the camera on so they can see you.
Skype is a free download and free to converse by computer without paying and you can talk to several people at a time.
It only costs if you call a telephone number from your computer while on Skype. Once you get the hang of it, you will enjoy it.
Hope this helps, Bud.
Posted on Jan 31, 2009
Lg split ac up down swing flap hanging loose and not working.bt cooling is ok. how to service it at home ?how to open that compartment ?
I's normal. In heating indor unit turns off up to 30 min. After this time indor schould working normal
Oct 13, 2016 | LG Heating & Cooling
How do I fix this problem when I drive the car jerking and mis
Start buy cleaning Battwry cables and ck to see if any codes
the computer schould help you and we can help also.it could be so many things?charging system,failing will do this bad coil bad fuel pump.Cam or crank sensor.cloged converter or so many things
look for code obd2 plug in its free at auto zone .
Jun 24, 2015 | 2002 Toyota Corolla
When does the 3 relay aactivate cooling fan stArt on a 94 toyota Camry 3000 engine
Only two I think ac fan come on as soon as ac is turned on and the
engine depends on switch 188 degrees it schould be marked
on the side of switch also pull tjhe wire of switch when you ground
the one wire off switch fan schould come on if fan stays on all the time relays stuck if the motor random on and off relay or motor
first replace relay cheaper then replace switch ckek motor
sirect from battery always. Hot wire jump it.hope this helped
Jun 24, 2015 | Toyota Cars & Trucks
Cooling fans won't come on 1995 camry
replace the relay fuse then. If the relay is stuck closed its no good if it should be reading temps to open current.
Apr 06, 2015 | 1995 Toyota Camry
Sanyo dp46849 no power
It is probably the power supply in you tv
it is close to the power inlet of the tv
look for capacitor s that are bold on top that means they are blown out
on one side there is a line with a - on it make pictures of it so you know with way to putt a new one back in it must be the same value microforat voltage schould be the same or higher
Jan 04, 2015 | Sanyo DP46849 46 in. HDTV
The dash lights doesn't work
got to take the dash apart and remove the cluster and their lights attach to it.replace the blubs and it schould light up.
Jan 27, 2013 | Office Equipment & Supplies
Radiator cooling fans won't come on. I can hook them both directly to a power supply and make them work, but not while they are installed. I even checked the sensor in the radiator. When I wire the...
Some cars have a thermostat that tells the fans when the water temp reaches a certain temp then the fans start. Or the relay that starts them could be bad. You may find the relay and switch it with another like it and see if that works.
Jul 30, 2011 | 1995 Toyota Camry
Screen keeps flashing like a strobe light, picture still works though
repair the powersupply off the tubes,
replace 3 elco bethween 47 en 470uF/40V and mesure al resistors if they have the correct value.
these parts schould be near the tube transformer where de wire of the tube are connected
Feb 12, 2010 | HP Compaq FP5315 15" LCD Monitor
Camera of my Sony K508i phone is not working whot schould i do ??
hey better change the phone......to change the camera u can better buy a new phone
Sep 27, 2009 | Sony Ericsson K508i Cellular Phone
Not going to the music,video,pictures icons
Run a Repair in the Philips Device Manager.
Mar 09, 2009 | Philips GOGEAR SA6045 MP3 Player
Veo Stingray Logo
53 people viewed this question
Top Veo Computers & Internet Experts
micky dee
Lyle Siemens
Lyle Siemens
Are you a Veo Computer and Internet Expert? Answer questions, earn points and help others
