my friend gave me his sansa m240 cuz he got an ipod. but here's the problem. i can put songs on it w/out having any software but i can't delete the songs he put on it before he gave it to me i open it up on my computer and it only shows me the songs i put on it do i need to get any software for it or is there some way to delete it without using a computer or some other way to delete the old songs
-   i can not delete the song to change songs-   Guest
Mar 20, 2009
-   my friend gave me a sanza m240 mp3 player. he downloaded a bunch of songs for me from his computer since i did not have one at the time. i cannot delete them or find them for that matter. help me obi wan your my only hope -   spaceghost80
Feb 17, 2009
-   it sucks-   Guest
Dec 20, 2008
-   i read and tried all these solutions but none of them seem to work no matter what i try -   Guest
Dec 18, 2008
-   the exac same for me, except about the friend stuff.
-   Guest
The sansa has two USB modes. If you load tracks in one mode you have to be in the same mode to see them in explorer and also be able to delete them. Took me ages to figure this out. From the main menu, go to Settings then select USB and toggle between "MSC" and "Auto Detect". You should then be able to see the hidden tracks. I have firmware 2.2.5A installed so you might want to check that too.
I now only use the Sansa in MSC mode as it seems to crash Winamp if I use it in Autodetect.
Was this helpful?
Yes
No
8 people thought this was helpful
Solution #2
posted on Dec 01, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
1. Go to my computer 2. Right click on sansa 3. Click on format 4. Then there you go all the files are deleted
Solution #3
posted on Nov 14, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
go to realplayer and select the type of media player you have. Then click "view" and it should upload all of your songs. then click the songs you want to delete by pushing the delete button.
Solution #4
posted on Jul 31, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
The songs that you put in it only show up because they are from your computer. That means that if you want to delete your friends songs you have to use his computer to delete his songs. Instructions: Plug in your Sandisk m240 to your friends computer and then go to the start menu and go to 'my computer' when you open up my computer an icon saying 'Sandisk m240'will be there and then when you open that up songs will appear then you may delete your friends songs
all u have 2 do is go 2 "my computer" and click on the sansa disk option and click on the only option u see there, and then click on music and delete how much u want
my ******* sansa express mp3 player is not working,till when i bought (nearly one year back).so...
(More)
my ******* sansa express mp3 player is not working,till when i bought (nearly one year back).so many times i tried to format that but no use .what i want to do? try to tell me the solution otherwise close your company inside india.this is last warning.
sansa m200Series MP3 Player m240 version-3.28A I am using sandisk ibid model.Memory is full. I am...
(More)
sansa m200Series MP3 Player m240 version-3.28A I am using sandisk ibid model.Memory is full. I am unable to delete files. When connecte the product to pc ,automatically makes open a dialog box ' auto play' - of no use. Unable to delete this. If i try to delete this using task manager which makes the pc to freeze. If I try to format with the use of disk manager I am getting a warning ' formatting could not be carried out successfully'. FM radio is also not available. When inserted with a battery getting display ' No files'. Please guide me or if such a question was answered earlier the fact of which be conveyed to me and where I can see the answer. Also guide me which firmware/software/anti virus( usb) if any, I have to use. Thanking you, Yours truly, B.Ranganathan
it takes a day and a half to sync songs now. and the batteries die quicker. what can i do to fix the...
(More)
it takes a day and a half to sync songs now. and the batteries die quicker. what can i do to fix the problem?
i only want to delete fm recordings from my sansa mp3 and i cant figure out how.i tried going...
(More)
I ONLY want to delete fm recordings from my sansa mp3 and i cant figure out how.i tried going to" my computer" and then clicked on "sansa" and the only songs that show up are the ones i loaded off of the computer so how do i delete music that i cant find? HELP PLEASE
ScanDisk Sansa m240 reads no files:
This player when switched on reads u have no space u need to free atleast 8mb, and it also reads no files found. I can't format it, i cant either see or read the files on it. when i open it on the computer the window is blank but when u check the properties 800mb are in use. so what is the problem.
Paul.
Uganda East Africa.
I used to use win explorer to drag and drop songs onto my sansa m240. My new computer will not recognize the songs that are in it and I can't get them out. The old computer is dead and buryed. I have tried win media player and my computer and explorer, none of them know that there are songs in the player. Can I reformat this player and load original software (where would I get it?), because I can't think of any other fixes.
Comment by Guest, posted on May 07, 2008
cant delete songs need to change my usb connection but my screen is broken
Comment by Guest, posted on May 05, 2008
I don't know how to delete songs, I need the manual. Thank you
As for me I had added songs to my sanza mp3 player last year with no problems but my pc crashed recently and I had to restore my system. Now I can still add some songs to the mp3 player but I cannot erase the old songs from it.
Comment by Guest, posted on Apr 26, 2008
IT WILL NOT DELETE THE SONGS OFF THE MP3 PLAYER THEY KEEP STAYING ON HERE
