Question about Acer Aspire 5315 Notebook
Fan on cpu not working.
A lap top that we have under warranty requires repair, and we need to know where we can take it to be fixed.
  • 45 Answers
Best Buy - Geek Squad
http://www.geeksquad.com/services/computer/default.aspx
Posted on Dec 30, 2008
I have a gateway nv44 and it will on power on if the screen is in the right position. I have to hold down the power button and move the screen up and down until it come on. Then it works fine.
It sounds like you have worn, loose or cut wires at or near your laptops hinges. You need to contact gateway if it is under warranty or the purchase place if you have an extended warranty through them. If it's out of warranty you will have to find a technician that repairs gateway laptops or pay for gateway to fix it.
Oct 04, 2013 | Gateway NV44 fan - NV44 laptop cpu cooling...
My lap top keeps shutting off
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Aug 23, 2012 | Acer Aspire 7720 Notebook
My fan is not running on my presario cq56 lap top~ do you know of exsisting problems w/ this laptop??? and pls how to get to fan~ tysm!
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Mar 04, 2012 | Computers & Internet
Hp probook 4510s is getting too hot and then it's swithing off alone then i have to wait for 10 mins minmum to could switch it on again? i changed the silicon part and after 3 monthes it's doing the...
Well, first you need to take the heat sink off the cpu & take it a part, remove giant dust ball. Then put it back together, replacing the cpu "grease/thermal paste" with arctic silver or some equivlent. Depending on where you use this lapatop, you may want to get a fanned cooler, to put under it.
Apr 16, 2011 | HP ProBook 4510s Notebook
My dell vostro 1014 is annoying too much. problem in fan. after iuse sometime, the fan stars to noise and hot air comes out. i don't use cooler and i use long time
This is a critical issue you will need to replace the fan inside the lap top. Or clean it the blades may be hitting dust accumulation around the fan. The bearings are getting worn down and soon it will stick and then burn up the CPU change this fan out I would say "RIGHT NOW". If you decided to do this on your own. If you know how to do this or have done lap top repairs before you would know this is so important. It is an indication of things not so pretty to come your way, now is the time for a bath and a new fan. Thanks great question? John
Jan 21, 2011 | Computers & Internet
I got my Acer Aspire One netbook today and it keeps running hot and switching off! I'm not using it on my lap, bed or floor. I'm using it at my desk where the cooling vents ought to be able to function...
You could have a faulty fan. Since this is a brand new notebook, I suggest you get ti repaired or replaced under warranty. If you try to fix it yourself you could void your warranty.
Dec 25, 2010 | Acer Computers & Internet
When I turn mine on, its says CPU fanfailure and system fan failure...what do u I do?
well your fan that sits on the CPU is not working properly and or the system fan...So you will have to get them replaced because the sytem know it will run hot if not replaced..you can go to a computer repair store near you and take the computer with you so they can open it and look at the fans and give you a price range or you can call dell because if it is new then its still under warrenty to get it replaced
Oct 25, 2010 | Dell XPS One All-in-One TV Desktop with...
I have a new(2 week old) E6400 Dell latitde. It got hot and now when I press the power button to turn it on the fan is running on high and the computer makes a beep and immediatety shuts off. How can I fix...
is this computer under warantee being new? if so contact dell for service..
this is usually a telltale sign of processor overheating.
unplug it from the wall and let it cool for 30 minutes. restart it, make sure your not laying it on a blank, your lap, or any other surface that will block the vents on the side bottom or rear. I always put mine on the table or a book, any flat hard surface is good.
if it still shuts down after a few mnutes , i would contact dell warantee support.
Apr 02, 2010 | Dell Latitude E6400 Laptop
Cpu fan not working
If the CPU fan is actually spinning (make sure you're looking at the right one - it should be the fan mounted directly onto a big circular heat sink near the top of your motherboard), then it sounds like your mobo has a faulty sensor. If it's still under warranty, get it changed for a new one.
Mar 09, 2010 | HP Computers & Internet
Not message, not beep, not at all, this motherboard a8s-x is new, have connect the memory, cpu, fan, video card, keyboard, el power supply is of 400 watts,the fan work.
who have a solution for this problem of my asus a8s-x not boot up, not beep, not message, have connect the memory, cpu, fan , video card, keyborad, this is new, only the fan work.
Thanks
Feb 19, 2009 | ASUS A8S-X Motherboard
Acer Aspire 5315 Notebook Logo
66 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
