Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Door hinge is broken on my hotpoint aquarius
The plastic door on our hotpoint aquarius is broken. Can it be replaced and if so where can you buy them from?
  • 242 Answers
Get the model number off the unit and go to sears parts on line. Good luck
Posted on Dec 30, 2008
Hotpoint Aquarius fdf784 door won't close think it's the hinge gone
suggest fix hinge or contact supplier for replacement.
Sep 18, 2016 | Hotpoint Washing Machines
Replace a door on a hotpoint washing machine
http://www.espares.co.uk/advice/washing-machines/a/7/1296/how-to-fix-a-broken-washing-machine-door-hing.html
Hi go to the above espares page where you will find a video on how to replace a door hinge, should show you enough to enable you to replace the door. There are other videos on how to replace the door interlock and release mechanisms as well.
Hope this helps, if it does please remember to rate me
May 04, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WM62 bearing noise how to change it
Hello,remove all the surround screws from around the door glass then gently lever the 2 halves apart,remove the old hinge,and re mount the new one along with the plastic bearings refit the screws,refit the door to the front cabinet.
Thanks
May 23, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Please reply
You could Replace the Door Catch/ Hinge. You do not have to replace the Complete Door. It is Relatively easy, if you have any prior experience working on any appliances.
You could check the Part from many Online Vendors like :-
http://www.repairclinc.com
Or you Could buy it from Any Repair Appliance Shop.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 22, 2009 | Washing Machines
Hi i have a WMA 50 and my little boy swung on the front loader door and it broke off at the hinge's the plastic part where the hinge goes, i have been told that hotpoint has a parts department that has all...
You can order the parts you require directly from Hotpoint.
Go to ;
WWW.Hotpoint4u.co.uk.
Click on washers, and follow the guide.
The part numbers are as below.
1603448 Hinge bearing.
1604434 Hinge assy.
This should solve your problem
Dec 17, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Dismantling door of Aquarius 1100 WM63P.
Revove all screws from inside of door then it will split with aid of flat screwdriver.
Nov 10, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wf220 glass door
undo door hinge from cabinet - held with two screws.
the door halves are held togethet with a few screws which undo and the door will split apart so you can replace the glass
Oct 02, 2008 | Hotpoint Aquarius WF220 Front Load Washer
Replacing door hinge wd63
Hi there is a plastic band around the rubber seal to take it off you would need a small screwdriver and prise it open gently than lift off the rubber and replace the door switch to put back the band just push clip the two ends together when it is around the rim
Jul 16, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
263 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
