My Laurastar SteamUp Iron Model 724 outlet screw (for rinsing the steam generator) is stuck probably because of calcium deposits at the base of the steam generator. How do I loosen the screw?
snakehead
  • 1074 Answers
SOURCE: My Tefal Steam Generater Iron will not steam
check the little tube that regulates the water to the holes it needs to be changed.good luck.
Posted on Apr 18, 2007
satscoop
  • 59 Answers
SOURCE: Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Posted on Nov 15, 2007
22yooper
  • 828 Answers
SOURCE: having purchased a phillips steam
Electrically open heater circuit for sole plate, or bad thermostatic control.
Posted on May 25, 2008
geokohler
  • 304 Answers
SOURCE: tefal proline express steam generator iron needs de scaling
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up the vinegar concentration but do not go higher than 2 cup to 1.
George
Posted on Jul 24, 2008
geokohler
  • 304 Answers
Fill with 50/50 water vinegar solution. Get it good and hot and let it sit for two hours. Rinse and repeat if necessary. Buy a gallon of water from the market and use that from now on. This will fix your problem. The Iron is concentrating the iron in you water and this is what is causing the brown spots. Hope you find this helpful. If you do please take the time to rate it fixya and maybe I will keep helping people for free.
George
Tefal iron steam generator
Steam irons can become clogged with mineral deposits. Use distilled water in the iron to minimize these deposits.
To clean the iron , use 1/2 white vinegar and 1/2 water. pour in iron and place iron on steam. The iron may require a few cleanings.
May 11, 2014 | Tefal Irons
SAND LIKE SUBSTANCE COMING OUT OF IRON
Yes, there is a "Solution" you could use in the reservoir to remove the crud. First of all, STOP using tap water. What you have is mineral deposits inside your iron from using tap water. Use ONLY steam distilled water. I usually find this at my grocery store.
To clean out your iron, use white vinegar in your iron instead of water. This is to CLEAN the iron ONLY! Do NOT use to press cloths! And make sure the steam and/or water flow very clear (free from "sand", dirty water/steam or any other contaminates BEFORE using iron to press your cloths. You may need to flush the iron with water (remember, steam distilled ONLY) more than once to get all of the vinegar out.
Hope this helps...
Jun 29, 2012 | Rowenta Perfect Iron
Brown water and seems like sand or fine grit comes from iron ,when first put on with the steam
sounds like it is time to de-scale the iron to loosen all the deposits inside the unit.
add some white viegar to the water ( which should be distilled water ) and heat up and let the iron steam out the solution. now add just water to the unit shake it and rinse out with water and drain. now do one more vinegar / water de-scaling and rinse out again. now fill with just distilled water and let it steam out and now your iron should be clean as new.
c...
Feb 12, 2011 | Russell Hobbs 13153 Iron
It is spitting and am not getting much steam
Probably needs decalcifying. If the iron has a steam boost button then fill it with water, turn it on and wait for it to heat up, hold it over the kitchen sink and repeatedly press the steam boost button. this may clear any blockages.
If that does not work then you can purchase a cleaning solution from a hardware store that is used to decalcify the iron. You fill the tank with the solution and let it pass through the iron to remove calcium deposits. Instructions will be provided with the solution.
Feb 07, 2011 | Rowenta Irons
No steam
What you need to do is clean out the steam orifice. (The tiny hole the steam comes out) When water is turned to steam it leaves behind mineral deposits, (Iron, Calcium) Especially if you have "hard" water in your area. Here's what you do. Add some CLR, (Calcium,Lime Remover) to the water you put in the iron, let it sit a while, laying flat, then drain the water out. You want to get the nozzle, to, holding the iron upside down, try to immerse the steam nozzle for a couple of seconds in the CLR or drip some directly on it. You can buy this product in most stores. It works well and fast. Dip your showerhead in it too, you'll be suprised at how it improves water flow. It is safe as long as you follow the instructions.
Apr 06, 2010 | Rowenta DG-920 Iron
STEAM ONLY COMING OUT OF TOP HOLES SWAN S15040
The iron is probably clogged up from mineral deposits in the water. Fill the iron with a 50/50 mix of water and white vinegar. Heat the iron and let it set for awhile. Then steam the solution through the iron. Repeat the process if this does not work. If the Vinegar and water does not work, then try a product such as Lime Away or CLR to remove the deposits. After the iron is cleaned out, try using distilled bottled water in the iron, to reduce the mineral build up.
Hope this helps you!
Aug 15, 2009 | Black & Decker Steam Generator SG200 Iron
I have Laurastar steampump model 01-0165. How
Vinegar and water mix (about 1 to 4 ratio) and run through. Use distilled water only thereafter--rinse through several times to clear out vinegar.
Aug 01, 2009 | Hamilton Beach Steam Excel 14770 Iron
I have a Sunbeam Steam Pro iron. Because we used normal tap water, there is a build up of calcified minerals in the water tank and the inside of the baseplate of the iron itself. The iron spits out these...
try putting straight vinegar in the water tank. Let it set until you see the deposit dissolved. Pour it out, rinse and use either some decalcified water or add a couple tsp. of vinegar to the tank each time you use it.
Sep 16, 2008 | Euro-Pro Steam Generator EP8001 Iron
Tefal Pro Express Steam Generator Iron
Once you have filled up with water and always just below full line, if your model has one, you need to press the "reset" or "restart" button on the back end of the generator (the end furthest away from the water container). Also, do be sure to regularly descale as advised above otherwise the water/steam can't get through.
Jan 21, 2008 | Irons
Heating & Cooling Logo
342 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
