Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
OK to store a new regrigerator still in the box on its side?
I want to store a new ge fridge still in the unopened box on its side instead of upright for about a week.
  • 242 Answers
Its ok to turn it on its side but it MUST sit upright 24-48 hours before pluging it in.
Posted on Dec 30, 2008
GE GSCS3KGYSS REGRIGERATOR DEFROSTING
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts: http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Sep 26, 2011 | GE GSCS3KGYSS (227 cu ft) Side by Side...
REGRIGERATOR SIDE IS NOT WORKING - FREEZER IS JUST COOL. GREEN NUMBER 4 IS BLINKING WHERE TEMPERATURE FOR FRIDGE IS SUPPOSED TO SHOW
Sounds like your defrost timer may have gone bad. Feel your walls and if they
are hard with no give then the fridge is froze up solid not allowing any air to
circulate. Try this: Unplug for 24-48 hours. Place towels on floor to **** up
water. Plug back in. If the fridge gets cold then the defrost timer is bad.
Unfortunately this is not a cheap fix and consideration may have to be given on
replacing your unit.
Good luck and thanks for your question and I hope my suggestions help. burdfrenzy
Visit My eBay Store!
http://stores.ebay.com/Pittsburgh-Joes-Pants-Nat
Dec 24, 2010 | Frigidaire FRS-26DR7D Side by Side...
My regrigerator (GE Profile) is not cold on the fridge side, but ok on the freezer side. I found ice buildup in the freezer so I defrosted and dryed it completely, cleaned it- including coils...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 16, 2010 | GE Refrigerators
Top shelf of both regrigerator and freezer not working
i have a side by side refrigerator is all ice bihind the cover evaporator
Apr 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Gurrgeling noise after compressor kicks in
The sound that you are hearing is the refrigerant moving through the system. That can be a very normal sound. If you are not experiencing any other issues I think it is ok.
I can't believe that just sitting in a box can harm it. If it was stored in an upright condition, you should be fine. The system has oils in the compressor. So if it was stored upside down or something then the compressor could have run dry. This is usually ok if the unit returns to an upright position for a day or so before it is run.
Jul 03, 2008 | Haier hwr10xc6 Air Conditioner
Regrigerator
It could be the fan...check the outlet in the fridge with the door button pushed in...light off. If it is, it could be a bad fan or freezeup (most likely). Defrost the unit completely. This is a two day, open doors deal unless you take the rear of the freezer section off and use a hair dryer (water and electricity together are dangerous!). You probably have ice in the coils impeding airflow. Pretty soon, your freezer is going to get warmer, too. Reasons: humidity is getting in there...door gaskets, liquids left to evaporate, windowshopping.
Dec 23, 2007 | GE GSH25JFR Side by Side Refrigerator
Ge side by side regrigerator
You'll find that the defrost heater is the problem most of the time.
Dec 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
