Powers on but no sound
Schematic needed for NAD 7020 TUNER AMP , it lights up but as no output
  • 4,234 Answers
These are not available electronically as far as I know. Also, there are a number of variants of this receiver based upon its serial number. Can you post the serial number here please? Also, are there any other symptoms at all or just no output? Look inside to see if your unit has relays for the speakers. If it does not, look for speaker fuses and be sure that they are not blown. Once I get the serial number, I'll try to provide you with additional details.
Dan
Posted on Dec 31, 2008
Schematic diagram
check the pcb mounted fuses on the power supply board They look like resistors only they have 1 colored stripe. replace the open (resistance above 1 ohm) fuse and enjoy your amp.
Jan 04, 2014 | NAD C355BEE Amplifier
NAD 7140 input selector does not work
The selector chip is not working, either there is no B+ to the ic or the chip has malfunctioned or one of the surrounding components dead, for this type of problem a schematic will be needed to track the problem. try www.nad.com contact customer support and the technical department for additional help.
Jun 15, 2012 | NAD Audio Players & Recorders
NAD C740 Chanel B Speakers not working The speaker output A is working properly, then the output B is completely silent. I install differents speakers and even the same speakers. no sound from the B...
possibly the causes are: 1. defective channel B power amp board. But try operating first with the built in tuner, if it's ok the RCA cable from your other sources(DVD player, etc...) might have broken internal conductor.
2. if it has the speaker switch(A, B, A+B) try toggling it, might also just loose contacts.
if the trouble is #1, leave everything to your trusted qualified technician, he knows what to do, unless you want to tweak/repair it by yourself...hope this helps ;-)
Feb 03, 2011 | NAD C740 Receiver
Nad c270 power amp transfomer hum
if the hum is in the sound output you have a blown power regulator
Mar 31, 2010 | NAD C270 2-Channel Amplifier
Can I connect a power amp to this unit?
If your 2100ES has a selectable INPUT AND OUTPUT and if you're intending to send all signal to the power amp, i.e. not bi-wiring or using the 2100ES to run mid-range or treble then you simply send Left & Right audio (White & Red cable) from a 2100ES output, probably AUX OUT ( it doesn't really matter apart from Phono on some units) straight to the power amp on AUX IN.
We should be just dealing with audio here, so connect the NAD audio output to CD or DVD IN. Select CD or DVD IN on 2100ES input switch and switch output to AUX OUT (whatever you decided goes to the power amp) on the 2100ES. Turn power amp to AUX IN and it will now get an audio signal from the 2100ES for amplification.
Speakers connect to the power amp as a normal amp, so pos and neg etc. The 2100ES now only acts as a signal feed, the power amp does all the work.
So, summary - switch on the NAD, press play - video goes separately and audio goes to the 2100ES. Turn 2100ES to INPUT for NAD. Turn 2100ES to OUTPUT allocated for power amp. Turn INPUT on power amp to allocation for 2100ES.
Turn it up!
Jul 27, 2008 | Sony STR-DA2100ES Receiver
NAD tuner
Depending on your audio power needs, any will work except receivers that already have integrated tuners.
Apr 21, 2008 | NAD C425 Am Tuner Tuner
Amp wont switch off of stand-by
Both units have a problem with the output section. In case 1, the outputs are likely to be shorted. In case 2, the outputs are open. The low level and distortion come from you driving the speakers with the driver section of the amp. Both units will need to see a service provider.
Dan
Apr 11, 2008 | NAD C320 2-Channel Amplifier
Proper connection from amp to pre amp.
Hi Jimmy
The output of the preamp connects to the input of the power-amp, left and right channels respectively. Some preamps (like NAD) can have more than one set of outputs, is this what you are dealing with? If you can give me the make and models of the gear then I can help you more... :)
regards
Graeme
Feb 13, 2008 | Audio Players & Recorders
119 people viewed this question
 Grubhead
Grubhead
