Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whirlpool fridge freezer us
Just installed no water coming through compartment
  • 37 Answers
Make sure you have water to the fridge and then make sure your filter is pushed in all the way. If thats not it
There should be two solenoids located behind the fridge at the bottom one is for your ice and one for water. Unplug unit and test the water solenoid with an ohm meter across the two terminals if it ohms out or beeps than your solenoid is bad.
Posted on Jan 03, 2009
Whirlpool fridge making a low, intermitant groaning sound
Is it coming from inside fridge compartment or freezer compartment or from outside back. If it is from freezer compartment and you have no water line connected to ice maker. Then it might be just your ice maker trying to go into fake harvesting mode. Make sure the Icemaker is off. Icemaker arm should be up.
Oct 14, 2014 | Whirlpool Refrigerators
I have a a whirlpool wrn42nwf6 fridge, and it is building water up on the inside ... im thinking blocked breather hole , but cant find it ..could you please give me any advice
Same issue with mine.
There is a drain between the freezing radiator behing the freezer compartment. The only way to get to that radiator is to remove the lining of the freezer.
There is a rubber elbow att he top left of the main fridge compartment . Remove that elbow by gently pulling it. Get a bit of flexible electrical cable and feed it down the pipe that is behind the lining of the main compartment and wobble it up and down that should make sure the pipe is clear.
then pust the cable upwards into the pipe coming down from the freezer. that should make sure that is clear.
The pipe that runs domn the back of the main compartment comes out down below someplace. I am in the process of finding out where.
Apr 15, 2011 | Whirlpool Refrigerators
Water is dripping from just behind refrigerator light closer to the back of fridge.
You will need to remove the rear panel from inside the freezer compartment and thaw the drain line. It is below the aluminum evaporator coil. Once thawed, install a drain heater to prevent this from happening again. The heater is inexpensive and easy to install. It comes with complete instructions.
Mar 27, 2011 | Whirlpool ET1FHTXM Top Freezer...
Water shoots out of the grill at the top of the fridge compartment,as if its coming from the freezer compartment?Tried turning it off for 2 days,but after a day has started doing it i need to set...
First how old is this unit? sounds like the water line from the filter to the ice maker is the problem, even if your model does not have an ice maker their is still that water line running to that area.
Feb 03, 2018 | Whirlpool GR2FHMXV Top Freezer...
Water is pooling at bottom of fridge, comes out from area at top in the back behind light.
If your freezer is above your refrigerator compartment, this may be your problem:
Your defroster (automatic) may not be working properly. Ice is building up in freezer drain, damming up the drain hose to the outlet. Water then overflows down into the refrigerator compartment.
Nov 03, 2010 | Whirlpool Refrigerators
Water leaks on to the floor from our whirlpool fridge
normally the pipe that drains the water on top of the compressor is a bucket that catch the water the pipe blocks sometime then needs to be opened again with a piece of wire
normally sits in the refridgerator compartement under neath the cooling plate
Oct 23, 2009 | Whirlpool Refrigerators
I have water pooling on my fridge trays and than turning into ice . The water seems to be coming from the vents. How do i get rid of that.
The freezer compartment has a drain hole behind the back wall inside the freezer compartment. The drain hole has probably rusted and has gotten larger. Carefully remove the icemaker and the screws from the back wall inside the freezer compartment. Lift the bottom of the back wall and look to see if the drain hole has gotten larger. You can make a small funnel from an aluminum can to fit over this area directing the water into the drain tube. It worked for me. good luck. Dave.
May 10, 2009 | Whirlpool ET9FHTXM Top Freezer...
Water building up in the main compartment
this is a plugged drain there may be a small cup up in the back of the fridge you can take out or you have to remove the freezer plate to access the drain
Apr 29, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Whirlpool fridge getting water from upper freezer compartment
well if you hat the freezer on top normaly air leaks inside freezer through the drain tube, that air turns into condensation and creates a ice and cloges your drain. now water can drain down to pan everytime ref goes into defrost , and water leaks to bottom section to air ducts and air returns. there are several ways to solve this problem the cheapeste way is to unplug refrigerator for 2 days then plug back up and it should go back to normal another way is to install a heat probe on your drain attached to your defrost heater , and add a grommet on drain tube that will let water drain but it will keep air out and that will solve your problem.
Oct 12, 2008 | Whirlpool Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
98 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
