Question about Brother MFC-7820N Printer
My printer says back cover open
I do not know if there is a paper stuck in their i was printing some papers then i turned of the printer and no papers where in therw
  • doctort1234 Jan 07, 2009
    The back cover is closed, but it keeps telling us the back cover is open, and won't let us use any functions of the printer
The sensor on the motherboard has possibly failed.
when you close the back cover an arm on the inner cover moves into the close position .This arm locates itself between a sensor on the motherboard .You can see the arm to the right hand side on the inner cover it sweeps in a slotted arc.
The only fix that I know is to replace the motherboard SORRY
Posted on Jan 11, 2009
I pulled paper out but I have bits of paper still stuck and cannot reach them. How do I get it out? They are way in the back.
Most printers have a flap at the back which you can open to get at damaged paper - it's not always obvious what to do, but an HP printer has a knob which you twist and the cover comes away.
I suggest a pair of fairly long tweezers is helpful to pull out bits
Feb 25, 2014 | Brother HL 2270DW Laser Printer
Paper jam dx7400
Here's how to clear the paper jam,
  • Open the paper tray and remove all the loaded papers.
  • Open the printer cover and check through for any stuck papers and remove them manually.
  • Close the cover and turn the printer off.Wait a few minutes then turn it on.
Now try to run a status print by:
  • Turning on the printer.
  • Load a paper
  • Press the right arrow > three times.
  • A status sheet is printed.
Hope this helps.Thanks!
Nov 02, 2011 | Office Equipment & Supplies
Turn the printer off and delete all print jobs. Open the printer cover and remove any paper from inside the printer and turn the printer back on. two red light segnul and not print .
Oct 06, 2010 | Epson TM-T60 Printer
Paper stuck in printer,can't get it out.
(1) Slowly pull the paper out, either from the paper source or from the Paper Output Slot, whichever is easier.
(A) When printing from the Auto Sheet Feeder
(B) When printing from the Front Feeder
bullet_s.gif If the paper tears and a piece remains inside the machine, open the Scanning Unit (Printer Cover) and remove it.
After removing all paper, close the Scanning Unit (Printer Cover), turn the machine off, and turn it back on.
* Be careful not to touch the components inside the machine.
bullet_s.gif If you cannot pull the paper out, turn the machine off and turn it back on. The paper will be ejected automatically.
(2) Reload the paper in the machine, and press the OK button on the machine.
If you turned off the machine in step 1, all print jobs in queue are canceled. Reprint if necessary.
May 17, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Printer indicates paper jam every few pages, but there is no paper anywhere in the paper path. If I open the top cover and close it, it will print a few more pages, then indicate another paper jam
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 08, 2009 | Xerox Phaser 6180N Laser Printer
I get a clicking noise when I print on a Dell 3115
The print cartridge carrier could be stuck and clicking agains the wall or gears might be clicking.
If your machine doesn't work at all, open the cartridge cover, take the cartridges out, close the cover, wait for it to call the carriage carrier to the side, then turn it off, unplug wait 2 minutes, plug it back in, turn it on, open the cover, install the cartridges back, close the cover and try printing again.
If that doesn't solve the problem follow these steps
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
If the problem still remains
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
After you have done all the suggestions, whats the status of your printer, are you still unable to print? is the printer still just clicking? are you able to remove the cartridges from the machine or is it just clicking?
If your not able to do the suggestions or the cartridges won't come to the center, your printer has a mechanical hardware problem that will require service.
Sep 05, 2009 | Computers & Internet
How can i remove the paper inside the printer
For the paper jam issue turn around the printer and open the back door to pull the paper.
and for the power issue unplug power cord from wall and from the printer side too,plug everything back and ready to work.
Aug 04, 2009 | HP OfficeJet 6110 All-In-One InkJet...
BROTHER PRINTER HL-2140
Try turning the printer off and back on. if this doesn't help, open any cover that will open and look for paper still in the printer. many times, if you stop the printer mid-job, paper will be stuck in the back of them, and most printers will not recover until you remove the paper jam.
Feb 10, 2009 | Brother HL-2040 Laser Printer
Printer won't feed the paper through.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Lets try few troubleshooting for paper Jam issue.
locate and slowly pull out the stuck paper, perform the following steps:
2. Open the printer cover.
3. Locate the stuck paper.
4. Remove the paper.
5. Close the printer cover.
6. Power the printer back on.
Locate and Remove Any Obstructions Inside the Printer and Input Tray
1. Open the front cover and make sure the kickstand (if there is one) is engaged.
2. Locate and remove any obstructions within the printer, such as paper pieces, staples, tape, or other objects.
3. Close the cover.
4. Remove all paper from the input tray.
5. Inspect the input tray for any obstructions.
6. Remove any visible obstructions.
7. Reinsert the paper.
Adjust the Printer Paper Guides
Extend the front paper support on the printer.
Try a Different Piece of Paper in the Printer
1. Take the top 10 sheets off of the **** of paper.
2. Verify that the remaining sheets of the **** are not wrinkled or dirty.
3. Replace the remaining part of the **** back in the printer.
Reseat the Dell Printer Power Adapter.
If your printer has a momentary loss of communication with your computer, it may be necessary to reset the printer to re-establish communication. You can reset a printer by unplugging the printer power cord from the electrical outlet and from the back of the printer for 10 seconds then reattaching the cord at both ends.
Try a Different Type of Print Media
Many image quality and paper feed issues are caused by the type of print media being used.
Try a different type of print media that is specifically made for this printer.
When there is no different print media available, take out the top half of the stack and flip it over.
Try holding the printer upside down and shake it moderately
Make sure you remove all the cables from printer before performing it
Check with manufacturer if printer is still covered under warranty...
If yes then get it replaced.....or else get a new printer
Aug 24, 2008 | Dell 922 All-In-One InkJet Printer
Brother MFC-7820N Printer Logo
175 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
