Question about Toshiba Satellite P30 P35 Series Notebook
Thin Vertical lines on the screen
I have Toshiba Satellite laptop. It is four years old. In the last three months, one by one thin vertical lines started to appear on the screen. Now there are four. It seemswill be more. Is there any way to fix that or I must go to the local Toshiba service?
  • jamesm1405 Jan 16, 2009
    Same here, p35-s611 4 years old, started 6 months ago, one line then two then three, i am up to at least 20 now, service rep say i need new screen.
Ebay - new screens $110-$135. Google for step-by-step replacement instructions.
Posted on Feb 12, 2009
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
I have 3 colored vertical thin lines running vertical on my desk top screen, how do I get rid of them? thank you
Does it do this if you attach an external screen and view windows through the external screen. If not, then you have a fault with the TFT panel on the laptop. This would require a replacement TFT panel.
Oct 15, 2009 | Toshiba Satellite A60 Notebook
Toshiba a10 satellite laptop screen problem
Hi, unfortunately this is an indication of dead pixels in the LCD screen. the only fix is to replace the screen and this may be more expensive than a new computer.
You could try EBAY "Want it now" section listing your exact model and serial number computer to see if some one has a screen available.
Regards mistyman
Aug 14, 2008 | Toshiba Satellite A10 Notebook
Vertical lines in my laptop screen
This could be a failure in several areas along the path from the video card to the monitor.
Being that there is not an issue across the entire monitor the video card should be considered a last resort check.
Usually this is caused by a loose connection between the LCD driver and the LCD panel itself. Sometimes light pressure applied near the affected line will clear it up. If that does then it is a connection between the LCD panel and the connector to the LCD driver at the panel's edge.
Not much can be done unless you have it repaired by a professional or you can take it apart yourself and apply a pad of some type inside the monitor's edge to apply the needed pressure once assembled.
Aug 11, 2008 | HP Pavilion dv8000t Notebook
Very thin vertical lines on display that won't go away
This might be a software issue with your video driver (follow Microsoft's built-in Help to test that, and look for an updated driver for your particular hardware) but it is fairly unlikely to be a driver issue. The thin lines running through your screen are usually due to screen failure -- hope you have your warranty, because this is a hardware issue and usually pretty expensive if you're out of pocket.
Aug 01, 2008 | Toshiba Satellite P105-S6104 Notebook
Vertical lines o my desktop
Sounds like your video inverter is bad or possibly the screen is going bad
Jul 21, 2008 | Toshiba Satellite M65 Notebook
My understanding is that you have 2 laptops with the same problem, if that is the case, you need to replace the lcd. When you have lines on lcd's, that is a sign of a bad lcd.
Jun 10, 2008 | Toshiba G15-AV501 Qosmio Notebook
what i recommend you to test is to press behind your monitor and see that the line goes off or not.If it does..that mean you have a loose connection,it can be fix.Incase no then you have problem with your LCD.Normally if its LCD problem then you fix this problem,all you have to do is change the LCD.
goodluck,takecare.
May 04, 2008 | Toshiba Satellite P30 P35 Series Notebook
Check it on External monitor prior to replacing the screen.. If the problems there as well its not the screen..
Feb 06, 2008 | Toshiba Satellite P35-S609 Notebook
The LCD would start to fail eventually, there is a fix you can try which has worked for some, but it solely depends if you want to try it out, it might revive your LCD...
http://udpix.free.fr/
Dec 09, 2007 | Toshiba Satellite P30 Notebook
Toshiba Satellite P30 P35 Series Notebook Logo
314 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
