Question about Frigidaire FRS26R4A Side by Side Refrigerator
Where is the drain?
I read on one of the solutions, that the reason why ice maybe building up on the bottom of my Frigidaire side by side, is maybe due to the drain being clogged with ice or something.
But I can seem to find this drain.
any detailed instruction one where it maybe?
ALSO for some reason, after I use the water dispenser, it does not stop dispensing water right way, it takes about a second or so to realize we took the glass away, but by that time, the water catch tray is filled with water.
BTW, I don't use the built in water filter, I replaced with a external 200 or 2000 gallon filter, could this be a problem>
Thanks in advance.
    Scholar:
  • 86 Answers
Hi, Well could you tell me if your f/freezer is frost free? Or is it a wet wall type fridge? I.E. water running down the back of the fridge? This would help me in telling you what is wrong. As for the water despenser you will probably find that there is a small bit of scale in the water valve which lets the water in or that there is a scale build up in the water despenser in the door. This does happen even tho you have a water softner. You will need to check both as to ascertain which it is.
Posted on Jan 02, 2009
Why would we get ice build up underneath bottom bskt in freezer?
because your drain is clogged and now frozen, now the defrosted frost is staying in the freezer. you must defrost the drain and than, clean the drain and insure that water can flow out into the drain pan.
Aug 10, 2014 | Frigidaire Refrigerators
Ice keeps building up in bottom of freezer and on vent inside fridge and now fridge won't stay cold.
Clean the coil inside the rear access panel behind the unit with a spray air duster and check for this problem.
I just opened up the back of my Frigidaire Side by Side counter depth to find the drain hose was bent and collapsed coming right out of the bottom of the freezer and the pan was dry as a bone. It doesn't look like my drain hose has ever drained a drop of water. The freezer bottom is full of ice And the rust and chipping paint under the bottom of the freezer door along with the mysterious puddles of water every morning means the drain system definetely never worked. Frigidaire should be responsible for this. This, along with the ice maker rebuild I had to do,... after ice was spilling all through the fridge. I actually had warrantty left on that one and called customer support in India to find out I could make the repair myself. Yep I had to do it. Frigidaire you failed.
Jun 14, 2010 | Frigidaire 22.6 Cu. Ft. Counter Depth...
Ice in bottom of frigidaire side by side freezer
clean out the drain hole with clorine bleach/blow out any gunk manually defrost unit.no hot water. no fault of siting.just a blocked vent...
Feb 08, 2010 | Frigidaire FRS26R4A Side by Side...
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Aug 04, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Ice Build Up in Freezer of FRS26ZSH
I had this problem. You need to clean out the drain under the freezer. The tech that came out used a squeezie bulb similar to what you use for a baby to clean their nose when clogged. You have to remove all the shelf's and the back plate. You need to use warm water to defrost the frozen ice and remove. use water and squeeze into the hole and **** out.. takes 10 minutes.. finally it will drain.. no parts are necessary. good `luck
Jul 23, 2009 | Frigidaire FRS26R4A Side by Side...
Fridgidaire frs26zsh side by side ice buildup in bottom freezer
if you have icemaker install check there or you have a clogged in your drain cut ashort piece of naked wire wrap it on the heater coil and puch wire down in drain not a long piece please unplug refrigerator
Mar 30, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidaire side by side freezer- water which turns to ice is collecting at the bottom of the freezer - drain hole at the back / lower part of the freezer appears to get frozen - causing the water / ice...
this should not be happening as a heater in the freezer should eliminate this problem.first check the hose is completely clear,if it is when your fridge goes into defrost mode you should be able to feel warmth near this drain or hear the ice crackling and defrosting thence draining via the rear tube also try removing the offending ice in the drain with hot water
Aug 11, 2008 | Frigidaire Refrigerators
Samsung RS253BASB leak at bottom veggie drawer
I had the same problem. I called tech support and they were no help. Being a handy man I dove into the problem myself and discovered the problem. If you want this solution, I have pictures and information. Simply email patmcclain@charter.net and I will send you this infomation.
Jun 07, 2008 | Frigidaire FRT15G4B Top Freezer...
Refrigerator
I just fixed similar issue. Defrost drain plugged. Take back panel off and behind fan is back hose. Take it out from the bottom and use something like coat hanger to unplug.
Also need to take off front panel from inside freezer and remove ice build up and thaw with hot water or hair dryer. Once done you should notice water in drain pan from back. Put all together.
Feb 01, 2008 | Frigidaire FRS3R5EMB Side by Side...
Ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
Nov 28, 2007 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
77 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
