Question about Amana PTH123B25AJ Heat Pump Air Conditioner
Ptac fan keeps blowing
Amana ptac unit--wired to unit (not thermostat) for control. fam continues to blow will not cut off. sounds like the compressor is kicking on and off but the fan continues to run HELP!
  • Anonymous Mar 12, 2014
    can not program it from unit
  • Anonymous Mar 18, 2014
    furnace blows cool air. sounds like the furnace blower keeps trying to kick it but it will not.
    Problem Solver:
  • 11 Answers
Reset the unit to factory setting by take the master switch off of 10 sec.
Then press and hold the cool and heat button down while turning the master switch back on.
Posted on Jun 08, 2012
    Problem Solver:
  • 18 Answers
IF the fan continues to run in the OFF position   It possibly could be the switch if this is the one im thinking that it is....the solution would be to replace the board being the switch is built into the board.    But if you are refering to the fan not turning off with the compressor then yes turn the fan cycle switch to auto/cycle.
Posted on Oct 13, 2007
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
Posted on Sep 07, 2007
Amana Wall unit blows cold air before heating
the unit works by chilling air and the byproduct is heat in the compressor, this is used for heating in the winter and then reversed in summer to blow cold air. It has to blow cold and warm up before it can blow heat.
Mar 17, 2017 | Amana Heating & Cooling
PTAC is not blowing cold air.
bad switch, bad motor capacitor, bad motor.
Jul 27, 2015 | Amana PTH093E35AXXX
Amana AMH95 Blown control fuse
Control fuses only blow with a 24 volt problem. Make sure that you replace it with a fuse NO LARGER than 5 amps.You could have a thermostat wire pinched or some wire touching the cabinet inside the unit, but it is a 24 volt problem.
Jan 22, 2013 | Amana GMH950453BX Gas Furnace
Amana PTAC unit when in the heat mode only blows cold air.
check heater coil may be faulty may be a faulty thermostat or temp sensor
Dec 08, 2010 | Amana Heating & Cooling
The Inner Fam Will Not Stop Turning And Continues To Blow Un Cooled Air
Hello my name is Heath it will be my pleasure to assist you. Make sure the fan switch on the thermostat is set to auto to turn the indoor blower off. If its the outside unit that will not shut off take the cover off the thermostat and disconnect the y wire and see if the outside unit shuts off. If the unit doesn't shut off then pull the cover to the outside unit and check to be sure that the contactor is not welded shut not allowing the outside unit to shut off.
Oct 11, 2010 | Goodman CLQ36AR49 Air Conditioner
Air Conditioner malfunction
Hi, Sounds like you have a short in the control circuit to me. Turn off all power going to the unit. Write down or otherwise mark the wires leaving the control board going to the thermostat. Remove them from the control board. Replace the fuse. Turn power back on and see if the fan still runs. If it does, check and or replace the heat limit switch that brings the fan on during the heat cycle. It may just need adjusted. If the fuse blows, I would think that the control board is probably bad. If it doesn't blow, Remove the thermostat. Leaving all thermostat wires open check them with an Ohm meter. There should be no continuity between them. Twist all the wires together at one end and ohm them again at the other end. You should have complete continuity on all wires. If the wiring checks out, down power the unit. Double check your wire colors and rewire the control board. With all wires open at the thermostat, turn the power back on. Touch the RED wire to the YELLOW wire. The Condensing unit should come on. Touch the RED wire to the GREEN wire. The fan should come on. Touch the RED wire to the WHITE wire. The heat should come on. Down power the unit. Replace the thermostat. Test unit. If the fuse has lasted ok but blows now it is either wired wrong at the Thermostat or the thermostat is bad. I hope I have helped. NOTE: If you can not understand these instructions. Call a licensed Heating / Air conditioning company. kstfas
Sep 23, 2007 | Heating & Cooling
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
1,066 people viewed this question
Top Amana Heating & Cooling Experts
Donni Steen
Colin Stickland
Colin Stickland
John Tripp
John Tripp
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
