Digital tuning Vistron Tv
Have a brand new Vistron DB19-S 19'' TV which should tune itself automatically using its installed Freeview Tuner.
All I get when I scan is a notice saying ''No Signal''. I have tried it on a known good reception Digital Inlet ( this one I use with a Samsung 32'' LCD) and still the same thing happens.
Any ideas what the problem could be? I have read some mixed reviews on Vistron tuning capabilities!
  • nghales Jan 01, 2009
    I have exactly the same problem.
    Received the TV from Ebuyer yesterday, only tried it last night, not contacted Ebuyer as yet.
    Works fine on UHF signals can get all 5 channels.
    Looks like I will be sending it back.
    Not happy to take apart brand new tv. (I think I'm a techie.)
    Looks like digital receiver is at fault.
SOURCE: Can't tune my sony KD-28DX50-U TV into freeview channels
Phone SONY UK digital helpline on 08706 001717 and they will give you the phone number of your nearest authorised SONY dealer to come out and fix the problem free of charge.
Posted on Feb 17, 2009
  • 441 Answers
SOURCE: samsung lcd tv is saying low or weak signal when
try adding a inline digital amp, most of the time all you need is a 25 db gain, that should do it for ya
Posted on Jul 11, 2009
SOURCE: Cannot find freeview/digital on our new TV
problem as above please help
Posted on Sep 10, 2009
  • 909 Answers
SOURCE: How do i tune freeview on my samsung ps42c7hd tv?
when you press DTV, press menu,setup,tuning and follow the on screen instructions.
Posted on Oct 11, 2009
  • 73 Answers
SOURCE: i cant tune in the freeview channels on my brand
Have you completed the entire auto programming?This can take up to 30 minutes and if you don't complete it you won' get any digital channels.If you have done this then you need a new main signal board.Call lg and they will refer you to the nearest service center.
Posted on Nov 10, 2009
How do I tune sky tv into my new Toshiba television
If the TV set is on the same stand as the Sky box then you don't tune at all. Connect with either a HDMI cable or a SCART. Use the AV input on the TV.
If you mean you have a bedroom set, and Sky is piped around the house on RF, then that's something different.
Make sure your TV has an analogue tuner as well as the digital one used for Freeview. (check the remote for a TV/DTV button). Go in the the TV tuning menu, and do an Auto tune for both analogue and digital.
Sep 13, 2014 | Televison & Video
I have recently bought a sharp aquos lc 40 le811e tv set,im havin problems tuning it i have a new antenna installed and when i try and auto tune it says there is no signal,i have also tried 2 differant...
Does it have a built in digital tuner? unplug wait 5 minutes hold power button while you plug it in you should get into a secret menu usd by techs look and see if you have a digital tuner hope that way works for that set
Jan 27, 2011 | Sharp Televison & Video
I have a Grundig TV P37-080GB or G.CG61-02GBM bought in UK. Using Auto Tuning I can find local TV channels but the audio to each of these channels does not work. I get a hissing sound as gets when not...
Hi.
If you are using the TV in UK, and you are using the internal digital tuner (aerial cable to TV), then the TV may be defective (faulty tuner or audio circuit). In that case call Grundig at the number listed on manual.
If TV is using an external digi box (eg. freeview), then check connection from box to TV, test using a different connection cable. Test using a DVD, if TV works on DVD replace the digi box.
If you are trying to use the TV outside UK, and you are using the internal digital tuner, then there may be a problem with signal. In that case purchase a tuner box and connect it to the TV.
Jul 14, 2010 | Televison & Video
How to tune freeview for digihome PVR80 it wont record bbc how to fine tune it .when we had to re-tune for channel 5 it worked perfect so please tell me how to do that again
On your remote control, press 'menu'.
Then select 'set up' on the screen.
Then select 'Installation' on the screen.
Then select 'Automatic channel scan' on the screen.
The box should then scan for all channels, and with luck BBC will be included. If not, please repost. Some older Digihome PVR80s can't cope with the new multiplexing standard employed by digital freeview.
May 07, 2010 | Televison & Video
I CANNOT TUNE IN MY LG FREEVIEW TV IN WHEN I AUTO TUNE IT IT CANNOT FIND ANY CHANNELS HAD NO PROBLEM BEFORE THE 4TH NOV
Sounds like the digital tuner modual has failed. Check all connections into the TV and make sure secure. Check with another Tv at that location & make sure you have signal. If all checks out with signal & runnning auto program, then you have a faulty tuner.
Nov 07, 2009 | Televison & Video
My Sony KD28DL10U digital TV will not tune into freeview
I think this is one of the TV's that wont work as part of the Digital Switchover as it's too old. My Brother has the same TV and has had to buy a new Set top box to get Freeview.
Jun 10, 2009 | Sony Televison & Video
Can,t record from digital channels
You’re dvd/vcr only has analogue tuner so the only way to record is by using the Phillips tv but as said tv will need to be switched on.you would need a sky or cable box or a free view box separate to the tv to record with tv off.the vcr will recieve only on the av channel av1 when connected to tv.a sky box or cable can be connected to av2 on sharp using a second scart lead and box
Feb 05, 2018 | Sharp Televison & Video
Wharfedale DVDR24HD250 DVD Recorder When set up will not find any programmes on Automatic Programme Search (APS)
Products such as this will use an internal tuner to tune channels, this tuner will not detect your televisions freeview stations, to record from your television, connect scart out from tv to the scart in on the recorder, then select the scart A/V channel, use the television to select the channel you want to record, you will not be able to record 1 freeview channel and watch another freeview chanel as you only have 1 digital tuner (in the television) the recorder does not have freeview built in.. hope that helps
Mar 24, 2008 | Televison & Video
Televison & Video Logo
296 people viewed this question
Top Televison & Video Experts
