Question about Panasonic Panafax UF-595 Plain Paper Laser Fax
Jamming paper at fuser. Paper try is pulling fine. Stops at Fuser
I don't know if I need a new fuser or some sort of pick-up assembly
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
Open the fuser and look at the exit area. There should be little scrapers (pick off fingers). These are mostly spring loaded and rest on the upper fuser roller. If the spring or pressure level is missing or detached, the scraper /finger will hang in the paper path and catch the paper. There could be 4-6 scrapers. The main scrapers needed are the 2 ends and the middle. So if a spring is missing you could take the scraper/ finger out. **** MAKE SURE AS TO NOT SCRAPE THE FUSER ROLLER AS THIS WILL LEAVE A MARK ON EVERY COPY*****
Posted on Jan 05, 2009
Minolta di350 jam at fuser
IF you can find a fuser. The Di 350 is a legacy Minolta, now Konica Minolta. mite be able to find refurbished unit. If accordion check to make sure the pick fingers are not broken they prevent paper from wrapping around the fuser roller. one mite be broken causing it to hit it.
Dec 10, 2013 | Minolta DiALTA Di350 Laser Printer
Hp2300 jams half way out of tray 1 and tray 2
1. Up to where paper traveled.. If its reached up to Fuser assembly & curl folds accrued under cartridge.. replace Teflon sleeve or Fuser assembly.
2. If paper traveled up to Fuser out(near 2-3 inch)...Clean/replace/flag Fuser out paper sensor
3. If paper traveled up to registration assembly:Clean registration sensors/flags.
4. Check pickup rollers.
Feb 20, 2013 | HP LaserJet 2300 Printer
I have a Laserjet p4014dn printer. it warms normally but once it picks up paper, it jams. i have dried clearing jam several times but on starting to print it jams
Three areas you need to check.1.Pick up area: While pick up roller picking up the paper,delay pick or no pick causes paper jam..
2.Registration assembly area: Once paper picked from the tray, paper leading edge registered by the paper sensor located under the registration assembly.. In case this sensor dusty malfunction or flag damage, paper wont sense. result paper damage..
3.Fusing area. If the paper travels up to fuser area, check paper jammed before entering in fuser(Teflon not rotating properly, replace teflon sleeve) or just crossed?(check paper sensors in fuser unit, clean the sensors & check flags,flag springs.
Aug 31, 2012 | HP P4014DN Laserjet Printer
Take apart hp3005dn
Analyse what type of jam it is...based on that we can shoot the trouble.1. Paper is jamming before entry in fuser and its folds like curl in the cartridge area.. A. Fuser Teflon sleeve not rotating or slow rotation results media(paper)unable to reached the destination in specified interval. Replace fuser assm or Teflon sleeve.2. Paper jamming after fuser assembly crossed little bit ( approx 1-2 inch).A. Clean fuser out paper sensor, check sensor flag & flag spring located in fuser assm.3. Paper jammed after fuser crossed more than 6 inches..A. Check paper pick up roller warn out(tray1 or 2), check registration sensor located under registration assm.How to remove fuser assm: remove back door, see the snap shot...
Registration sensor location:
Pick roller roller tray 2 :
1_9_2012_3_54_49_pm.jpgPl try it carefully..Best of luck...
Jan 09, 2012 | HP LaserJet P3005n Printer
We have XC865 the copier was working just fine until today. The paper keeps jamming inside. It would start to copy and then just gets stuck in the middle of the cycle. So I have to open the machine up...
Most likely a common problem of a broken fuser drive gear. This is especially true if the lead edge of the paper is stopping at the fuser assembly. This is the assembly that is hot to the touch. There is a upper fuser roller drive gear that breaks on these and causes the fuser roller to stop turning. So everytime the paper gets to the rollers it stops and a jam reults. The gear is 16.00 at precisionroller.com part number M510X
Here is a picture of the gear.
Sep 17, 2010 | Xerox Office Equipment & Supplies
Xerox Phaser 7700DN jam at fuser
Those rollers are necessary to feed paper from the fuser. Order PN 116-1759-00 which is the 15 inch long shaft w/ 4 rollers
Whit
Item, Inc.
Nov 10, 2009 | Xerox Phaser 7700DN Laser Printer
HP laserjet 5500dn paper jam at fuser
I was able to fix my problem. On the left side of the fuser assembly there are two small plastic tabs or flags that move up & down. One is attached to the plastic rod/flap that you can see from the top of the fuser and moves when the paper comes out of the "chute". The other tab, which is below the first tab and moves when the paper has passed some point in the fuser, was broken off. I glued the tab back on and now the paper is ejected from the printer like it is suppose to.
I'm thinking that the broken tab was part of a page sensor flag that would tell the printer to stop rolling the fuser assembly when the paper was ejected. Without the flag, the sensor would disengage the fuser prematurely and stop ejecting the paper while the paper was still in the fuser.
Charlotte
Apr 17, 2009 | HP LaserJet 5500DN Printer
When i try to print something the paper wrinkles up and does not print
Depending on where exactly the page stops in the printer. If in the paper tray area you may need new paper pick up tires. If it stops just after the toner cartridge you could have a bad fuser or bad fuser drive gear which is on the swing plate assembly. Or it could as simple as the toner cartridge.
Oct 20, 2008 | Office Equipment & Supplies
Jammed paper
where is it jamming ? pick up, on the side in the fuser where it gets hot???
Jul 17, 2008 | Sharp AL 1631 Copier
Oki c5150 fuser jamming
This tells me the one of the Pickers in the fuser is damaged and causeing this Jam , I would replace the fuser and chaces are this most likely will resolve your problem
May 02, 2008 | OKI C5150n Led Printer
Panasonic Panafax UF-595 Plain Paper Laser Fax Logo
95 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
