Question about Acer Aspire 5100-3357 Notebook
My acer aspire 5100
It keeps on sending me to the system restore page and i keep on launching it but it goes no where im thinking of buying a bootable cd but cant acer dont have any i was wondering if anyone would be willing on making one for me and paying for it a lot better than waiting another month for it to come in the mail for me anyone have any other solutions i have tried to run all the programs and when it restarts ti goes back to the same thing again some one please help
  • Anonymous Jan 22, 2009
    My Acer Aspire 5100 has a message that it cannot start normally and that the system will detect and repair the problem. Several minutes later it says that the problem cannot be repaired. It never gets repaired. It might have something to do with an ATI 4379 Serial ATA Controller.
Have an Acer 5100 Aspire. Keyboard, touchpad both not working. If I hold down Alt+Tab+F10 while powering up the laptop will keep the computer from booting up, but nothing else. I have tried USB keyboard...
Do one thing performing the recovery option by ALT+F10 and restore your system to factory default
before that you take backup with the important data
Nov 16, 2010 | Acer Aspire 5100 Notebook
My acer aspire 5100 keeps coming up with an error code when switched on, and does not allow me to even restore to another date when computer was ok. the code is ERROR LOADING C: WINDOWS\SYSTEM 32...
do you have the restore cd? Using a restore cd would remove your files but it would fix the problem.
if you can get your hands on a windows installation disk, for the version you are using. You could perform a repair installation, it would also fix the problem and you would get to keep the files.
a pc tech might be able to fix the problem without reinstalling windows but that would require you to take the laptop to someone.
I know I could but I'm not in the UK.
Jan 14, 2009 | Acer Aspire 5100 Notebook
I did a recorvery on my Aspire 5100 everything installed but when it gets to the acer launch install it just keeps running at process 4/5
u hav to wait when it's running yr laptop hdd light are showing blinking means it's working it it's not then some problem wirh hardware or file curraption problem then do boot woth recover cd if it avalable
Jan 08, 2009 | Acer Aspire 5100 Notebook
ACER 5100 BIOS PASSWORD
If your son used the edata security and used both passwords. you can either ask him for password or change the boot secuence to boot to restore disk and restore back to default..which defaults to NO PASSWORD set.
Dec 04, 2008 | Acer Aspire 5100 Notebook
Cant restore my acer aspire 5100
ok well first iv had nothing but bad luck with them. i think you would need to buy a new copy of windows xp, u can choose the version. you cant get your factory settings back with all the programs that acer gives you when you buy your pc, unless they send you a new hard drive. the restore cds i think with acer word from that specific restore partition on the hard drive. and with most pcs from i think 2002 and up have the F11 option with the restore partition to reset and restore your computer. when they erased your hard drive, they erased every little bit of data that was on it. me personally can restore all, if not some of the information and personal data you have. please email me the model # serial # and as much else info you can provide of your computer. and i will do as much as i can to help. if you have any more questions, please email me at meanness628@aim.com
Jun 25, 2008 | Acer Aspire 5100 Notebook
Acer Keeps restarting
You have to reinstall your operating system. There is no other option. Bcoz every time the operating system try to operate hardware it receive wrong info from the hardware drivers. Contact me again for more info
Mar 31, 2008 | Acer Aspire 5100 Notebook
Acer Restore
The recovery partition is corrupted. 1st option is, You can send your computer to acer repair center in germany. I believe acer have international warranty. 2nd option is to buy the recovery cd from acer, you can installed by yourself.
About downloadable OS, i don't think they have it online.
Feb 24, 2008 | Acer Aspire 5100 Notebook
Aspire 5100 problem
You can disable this msg through msconfig or you can restore the os through system tools, if msg is again comming then try to edit the regestry & delete the entry(you can try all this).
Feb 13, 2008 | Acer Aspire 5100 Notebook
Problem error:
go buy a new hard drive the hard drive has failed,,,,then use the restore disk and restore your machine...the reason it is going to the ethernet controller is that since the hard drive has failed it tries to access the next bootable device...and none is present
Nov 26, 2007 | Acer Aspire 5100 Notebook
My Acer aspire 5100
If you are able, when the pc is booting up keep pressing F8, this will take you to safe mode and not allow the graphics driver to run. When in the safe mode options, select either Last known good configuration or start windows in safe mode. Last known good configuration should find the last good system settings, when it reboots. Start windows in safe mode allows you to go into windows using the administartor account, and then you should select system restore and restore back to the day before or just before you updated the graphics driver.
Aug 16, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100-3357 Notebook Logo
99 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
