Question about Sony PlayStation 2 (PS2) Console
"The Dualshock 2 Analog controller is not detected. "
"Please attach the Dualshock 2 Analog controller to controller port 1 and select OK."
2 Suggested Answers
PIMPKING100
  • 6 Answers
SOURCE: Error on Game screen
U UNPLUGGED THE SECON CONTROLLER SO PLUG IT BACK IN DUH
Posted on Jul 01, 2008
Why do i keep getting the same message, "Dualshock controller not detected" when i have changed the ports and cleaned them?
maybe connection pin has been pushed in and is not touching the other side of the connector. has happened to me when I put a test meter connector together and then pulled it out and rejoined the two plugs, a pin had been pushed in for enough to not be seen but not connected and showed the 'unable to detect message. look for something out of the norm when test show ok, but it's not
Aug 07, 2014 | Sony PlayStation 2 (PS2) Console
Dual shock 2 wire digrem
The pinout is as follows when looking into the cable like this;
__________________
1 ' * * * ' * * * ' * * * ' 9
\_________________/
Pin Name Description
1 DATA Data
2 CMD Command
3 +7.6V
Dualshock and Dualshock 2 uses this for powering vibro-motors. Voltage on PS2 is 7.6V, however many sites says it's 9V. But it will work on 9V too.
4 GND Ground
5 VCC Vcc
6 ATT ATT select
7 CLK Clock
8 N/C Not connected
9 ACK Acknowledge
~KenjiFox
Jan 07, 2011 | Sony PS2 Dual Shock 2 Controller...
Is it ok to charge my controller on laptop/pc
There isn;t a reason why you shouldn't charge using a laptop/pc, did a bit of resaearch and many people claim to be charging thier pads via a pc's usb,
I tried it on mine and it didn't work, it recognised the PS3 pad and installed it as a game controller, which was pretty cool but it wouldn't charge, haven't tried it on my mac yet . If it doesn't work first time try a diff. usb port on your laptop pc, as sometimes its certain usb ports on your system that carry enough juice to power a device
d:)
Jul 31, 2009 | Sony DUALSHOCK® 2 Analog Controller for...
The dualshock 2 analog controller is not detected
Well its probable your controlor port either needs to be cleaned out or your controlers wire is lose.I might be easier to just buy a new controler and if the problem persists clean out the port.
May 07, 2009 | Sony PlayStation 2 (PS2) Console
For PS2 "The Dualshock 2 Analog Controller is not detected." What should be done to fix this? Mom with 3 kids home from school! Help!
This could be the PS2 console. You need to try a different Dual Shock controller to determine if the problem is the controller itself or the ports on the Playstation. The normal problem here is a dirty connector on the Playstation. Clean the connector or you may need to check the Fuses inside the Playstation. This requires specialized skillls.
I have seen where Dogs have chewed the cable running from a controller, and caused the problem.
Dec 30, 2008 | Sony PlayStation 2 (PS2) Console
My dualshock 2 controllers analog are very hard. how to fix it
Hi warren111,
When you say hard, did you mean the controllers analog stick is very "stiff" or loose to the point that you can't move the characters onscreen or the characters move involuntarily. If this is your case then you may have to try another PS2 dualshock 2 analog controller in your PS2, If the problem doesn't happen with another controller, then you may consider buying a new PS2 dualshock 2 analog controller since most likely the controller is already defective.
Also try other games, see if the problem only happens with a particular game. If it does then you will have to check the settings of the game, and see if you can adjust the settings of the buttons or analog stick.
If the problem you're having is more with the "comfort" of the controller you're using then you should consider looking at 3rd party controllers for the PS2. One company that makes them is Logitech, they have a line controllers that work for the PS2 there are other companies so check out gaming sites to get reviews on them. But I would suggest though that if you're shopping for a controller because of this reason, you should try to test the controller out in a game shop first. So that you can get a feel of it before buying. If you like the controller and you're comfortable with it then tha's the time you buy it.
Hope this helps!
Peace! :)
Oct 22, 2008 | Sony PS2 Dual Shock 2 Controller...
Jun 30, 2008 | Sony PlayStation 2 (PS2) Console
Multiplayer doesn't work
  • loading a different disc to see if the problem continues.
  • Try inserting the controller into either controller ports (1 and 2) to see if the problem continues.
  • Try a different controller and/or memory card to see if the problem continues.
  • In certain games, there are on-screen "controller options" where you can designate which character (or team) you want your controller to control. Make sure that these options have been verified within the game.
  • Make sure there are no obstructions in the controller or memory card ports (i.e., lint, debris, etc.).
  • Make sure the controller cables are in good condition, free of cuts, frays, or other visible damage.
  • Make sure the controller and the memory card is plugged into their respective ports completely.
  • Make sure the analog button in the middle of the controller is pressed. Toggle this button On/Off to see if either mode helps the controller function properly. This can also help troubleshoot the vibration function with the DUALSHOCK®2 analog controller.
  • Make sure all of the controllers and memory cards (or any other peripheral) you own are licensed[1] for use with PlayStation® products. (Licensed products have the official "PS" logo on the product.)
    Sony Computer Entertainment America, Inc. (SCEA) manufactures the following first party peripherals[2]. There may be other third party peripherals that are licensed; please check with the third party manufacturer directly.
    - DUALSHOCK®2 analog controller: Model SCPH-10010
    - DUALSHOCK® analog controller: Model: SCPH-110
    - Memory Card (8MB) (for PlayStation®2): Model: SCPH-10020 or SCPH-10410
    - Memory Card: Model: SCPH-1020
    - Multitap (for PlayStation®2): Model: SCPH-70120 (for 70000 Series only)
    - Multitap (for PlayStation®2): Model: SCPH-10090 (for 30000 - 50000 Series only)
    - Multitap: Model: SCPH-1070 (for PS oneTM or 30000 - 50000 series PlayStation 2 only)
    - DVD remote control[3] (for PlayStation®2)
Dec 17, 2007 | Sony PlayStation 2 (PS2) Console
Ps2 dualshock analog controller not vibrating
Usually, all dualshock controllers malfunction after a year or so. Do not be surprised.
Sep 10, 2007 | Sony PlayStation 2 (PS2) Console
Logitech Cordless action controller 2.4 ghz is not working
Try Blowing into the peice that plugs into the playstation or whatever you have, after that, blow into the port that you would plug it into, sometimes dust gets in there. Good Luck. -JD
Apr 01, 2007 | Logitech Cordless Action (9633200403) Game...
Sony PlayStation 2 (PS2) Console Logo
231 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
