Question about Craftsman 4 Cycle Blower/Vac
Can't get snow thrower to start
I have replaced the spark plug and I cant get the snow thrower to start, it has tension on the cord and I pull and it makes the right sound it just wont fire. It has a 4.0hp briggs and stratton motor and has very low hours. The actual model number is 536-88140. And yes the oil is full and recently changed and of course it has gas and I've made sure I didn't flood it.
  • DEddyB Feb 01, 2009
    I have taken the Gas bowl off and sprayed starter fluid inside.I checked my gas line and there is gas. I spryed starter fluid in the firing chamber and it will turn over and start but I cannot get the gas to flow through the carb. At least I am getting it to try and start at the begining, I prime the carb and it trys to start.
    I assume my problem is in the carb.
    I have had this machine for 2 & 1/2 years and had two problems with it, I hope some one from Sears is reading this because I am pissed off.
  • flash666 Dec 24, 2013
    if some has put fuel stableiser in gas before bought it if so you have to take the carb totally apart and clean it with engine carb cleaner and take the jets out and polish them put carb cleaner through all openings make the float isn\'t clog or jammed or full old junk, clean every thing out. make sure count your turns on jet screws to see where set at be careful try this see what happens if works you done very well your welcome . santa
Does it have spark ??? I would check that first, and IF it does maybe add a tablespoon of gas down the sparkplug hole then try it..
Posted on Dec 31, 2008
MTD Snow Blower will NOT start up!
fuel float stuck --- need carburator repair -- to check it has spark then pull spark plug --- if wet blow off spark plug and check spark on plug then squirt a small fuel out of oil can into plug hole and put plug back in -- if engine fires on first pull carburator needs fixing -- check by squirting fuel in carburator with oil can and see if you can keep it running
Feb 23, 2014 | Garden
I just bought a Sears Craftsman snow blower,put gas and oil in it.Itried to pull the starter cord but it will not pull. I then tried the electric starter but it just grinded.Why won t it start?
Sounds like a serious flooding issue, perhaps due to having blower on its side, take out spark plug and place plastic bag over and try pulling over, be careful that it doesn't spark and ignite any fuel expelled out of cylinder.
if that is the case pull over several times blow off plug and try again, fuel might be trapped in muffler so be aware of spray, ignition.
If it doesn't pull over with the plug removed take it back as a valve might be sprung.
Dec 16, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Carb adjustment and what is the correct spark plug
If the snow thrower worked last year I would suspect old fuel in the tank. Dump out the old fuel in the tank and put in fresh. Put a squirt of starting fluid in the carb and try to start it. If it fires the ignition is good. Do this a few times to pull the old fuel through the carb and fuel line. When the new fuel gets through the fuel system to the engine it will stay running. The spark plug in the engine will have number on it. Get one with the same number if you want to replace it.
Dec 10, 2013 | Craftsman Sears Snow Thrower Manual Model...
Snow Thrower Won't Start. I have a Sears 26" Snow Thrower Model No 247.889702. It will not start. Changed fuel, new spark plug, propoerly primed the engine, tried both pull start and electric star
does it have spark? if you can start it with starting fluid chances are the carb needs a good cleaning or replacement. fuel these days goes bad in about 2 months without stabilisers in it. gums up the tiny passages in the carbs. i suggest seafoam as a treatment but anything is better than nothing...good luck
Nov 18, 2017 | Garden
Ran over cord with snow thrower
Can you pull the engine over and then the cord locks or you can't pull the cord at all?
Dec 27, 2012 | Garden
Toro snowthrower 38180 won't start
You have probably fouled the spark plug (got a heap of black carbon on it) remove the spark plug wash in some petrol then use a wire brush vigorously brush between the contact points on the plug then reinstall. & lastly don't forget to push in the choke when you get it fired up next time.??
Mar 14, 2017 | Garden
Simplicity Sno Away Snow Thrower Briggs 6hp engine No Spark
Check engine oil.
Remove wire from low oil sensor and the start.
Replace low oil sensor.
Hope this tip help solve your problem.
r/David
Dec 28, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
My snow thrower wont start
Change the spark plug being sure to set the spark plug gap as recommended in the owner's manual. Then clean or change the air filter. Finally use new high test gasoline. good luck.
Jan 12, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Snow thrower won't stay running
Replace the spark plug being sure to use the plug recommended in your owner manual, and the gap recommended. Then clean or replace the air filter. Finally use high test, new gasoline. Not gas that has been sitting around for months. good luck
Jan 11, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Craftsman 4 Cycle Blower/Vac Logo
430 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
