Question about Nintendo DS Console
Ds won't power on. Orange light stays on when charging.
Fuses and switch seems to be fine, battery seems to put out 5.0 volts.
Unit was dropped.
  • newport11801 Dec 30, 2008
    the connectors seem fine ?
  • luster99 Apr 16, 2009
    Hi i have the same problem as newport11801 i put in the charger the orange light turns on and like an hour later i turn it on and it's still on red
  • 709 Answers
Make sure your Top screen ribbon cable is securely plugged in. This is very hard to do, and a key reason why the DS will not power up. Also check the bottom screen connector.
Posted on Dec 30, 2008
  • Greg Stokes
    Greg Stokes Dec 31, 2008
    You may need to do a closer inpection of the ribbon cables. They must be inserted squarely and another thing relating to the drop, the battery connector could have come unsoldered. You will need to test with a ohm meter to see if the battery connections apply to the circuit board.
DS charging..light stays orange...
It could mean that the Motherboard (Main Circuit) could be damaged or could be a fuse problem as you may have said. Although it actually might be the battery, there's one way to find out, if your friend has a DS Lite, ask them if you could borrow your battery for 2 seconds and put their battery in yours to see if it is the battery, if the same thing happens, its the Motherboard (Main Circuit)
Jul 06, 2013 | Nintendo DS Lite Console
When charging DS lite the light stays orange
The issue is not with the fuses or with the battery. That end is working properly if the light stays a constant orange. The issue is with the other end, how the system powers on. Check the power slider (on mother board) or the L2 inductor (located below the slider). Chances are the tab on the slider has broken off or the L2 slider broke off from the motherboard.
I lost my manual to my duracell instant jumpstart . Just wanna know to properly recharge my unit.
I'm having the same problem where it won't take a charged. If you left it with a dead battery for say 6 months, it probably ruined the battery. You should have a charger for house current and car voltage charger. I guess your dead in the battery like me. I'm taking it to Battery Plus to check it out. It only had a 1 year limited warranty. Good Luck.
Oct 30, 2010 | Duracell ® Instant Jumpstart System
Nintendo ds wont charge
cheekiemunke,
First of all, your DS Lite is charging both ways.....with power on and without power on.
You have for almost 99% sure a blown fuse F2 on the systemboard.
If you can solder you can try to replace it with a new one but be adviced, it is tricky if you don't have the skills with soldering SMD components and it can send your DS lite to the trash.
So my advice is find someone that repair DS Lites or order a fuse on eBay and try it yourself.
Regards
John
Nov 27, 2008 | Nintendo DS Console
Dropped Nintendo DS Lite on wooden floor - NOW IT WON'T TURN ON
remove the battery for a few mins and put it back in and try again?
Its a long shot but theres very little you can do with this, the insides of the DS lite are REALLY small and the only replaceable parts are the screen, buttons, etc. and you cant really fix damage to the board or chips inside which presumably is whats happened here if you get zero response.
Sorry.. :(
Nov 13, 2008 | Nintendo DS Lite Console
NINTENDO DS LITE WON'T CHARGE OR POWER ON
Hey everyone, not sure if this will work for everyone, but its worth a shot.  my problem was identical to all the others here, a flash of orange and then nothing.
i thought perhaps those little metal contacts on the battery and the ds had build up a little corrosion, interrupting the charge.  so, i took some rubbing alcohol and q-tips and gently scrubbed them clean, both on the battery AND the ds side.
After this, my ds has worked flawlessly.  Hope it's the same for you!
Feb 06, 2008 | Nintendo DS Lite Console
Nintendo ds orange charge light flicker on then off . no power when try to switch on
i also had same problem and gameathlon solved it wow you can buy it here http://www.gameathlon.com/advanced_search_result.php?keywords=Nintendo+ds+battery&x=0&y=0
Jan 23, 2008 | Nintendo DS Console
Nintendo ds lite
Try opening the system up and cleaning it out.
Dec 20, 2007 | Nintendo DS Lite Console
Ds light not coming on and charger not working
When I hooked up my DS with the charger the orange light would flicker for only a few seconds then turn off.
I found out that if you KEEP THE DS ON WHILE HOOKED UP the DS will charge. Although, because you are playing/DS is on the charging will go extremely slowly.
Best option, and what I did, was was just return/exchange it. I just did that today.
Nov 28, 2007 | Nintendo DS Console
Nintendo DS Console Logo
293 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
