Question about HP Photosmart M407 Digital Camera
Unsupported card the same as Chris(Nov.4/08
Also, when using the USB cable to the computer the camera shows"establishing connection". The camera doesn't show the prompt on the computer after ten minutes. The card works fine in the card reader in the computer. I didn't do the firmware update as Chris did
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • HP Master
  • 102,366 Answers
Make sure you're using an SD card, 2GB or smaller. The M407 does not work with higher-capacity SDHC cards.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Sep 16, 2012
CompuGuy44
  • 432 Answers
SOURCE: trouble transferring pictures from camera to computer
First, Try and install the HP software again. Uninstall the software first and reboot the pc. Then reinstall software. The memory chip maybe have currupt pictures, so format the chip using the camera. You manual should tell you how to do this. Second, Turn the camera on and let the battery run all the way down. This may take some time, maybe a day. Then charge it back up for a day. I hope this helps you out. Let me know.
Posted on Jul 01, 2007
SOURCE: unsupported card
check the internal cable which contact with the memory card package, only easy push on it
Posted on Jun 05, 2008
informatica
  • 1114 Answers
Hi - You can download the manual by clicking the link underlined in blue below:
Photosmart M415
See page 166:
Also try formatting the card in the camera as cards that have been used in other cameras or formatted on a PC may not work correctly until formatted in the camera.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Sep 06, 2008
  • 54 Answers
SOURCE: Camera gives ''Device not Responding'' message ...
For Windows Vista, try switching the usb settings on the camera from Digital camera to Disc Drive. This converts the camera into an elaborate flash drive/sd card reader.
I also found that the usb connection on the camera may not be responding. This means that there is something wrong with camera part and it may have to be replaced. Replacing that part is not hard to do, but it is tedious because it involves taking the camera apart (removing the main circuit board from the plastic case, removing the LCD, loosing the lens from the circuit board, loosing the circuit board from the chasis of the camera to expose the mini-card circuit board that operates the AC power and usb cable. Switched this board from another camera (m425, or m525 (same board)) and reassemble the camera in the reverse order of disassembly.
Posted on Dec 10, 2008
SOURCE: digital camera that will no longer connect to the computer.
I don't know about your "picasa" software, and the importing procedure, but you could simply plug your card into the SD slot on your PC, and it will show up as a 'removable drive' located in "my Computer". You can open it and simply copy/paste the photos directly to any folder you wish. In other words, you don't need any specific software to import photos, and to me it's a much simpler process.
If you don't have a card reader on your PC, you can buy a USB to SD adapter to plug into your USB port for $15 +/-
Posted on Mar 12, 2009
The usb sign doesnt come up when iconnect it in the camera
When your camera is connected to your computer with a USB cable, you need to turn the camera on before the connection is established.
That is maybe why the usb sign does not show.
Regards
Sep 30, 2011 | Cameras
I cannot download pictures from my LG Neon gt365 to my computer. What do I need to do? Do I need a USB? Do I need a micro SD? If so, what kind do I need? any help would be great!
You should be able to connect it using a usb cable that will need to be bought separately and a micro SD card installed in the phone. You should be able to buy any micro SD card up to 4GB. Also, if you buy a card with an SD adapter that will allow you to connect the SD card (with a memory card reader) to your computer without the additional usb cable. The manual link is attached: http://www.tmoatt.com/uploads/53/LG_Neon_GT365_UG_English.pdf
Per the manual:
Transferring Music from the Digital Music Service 1. Using your computer, open your preferred PC music management client. 2. Download the selected song to your library. 3. Make sure the microSD™ card is inserted properly into the handset. 4. Use the USB adapter cable to connect the handset to the PC. When you try to connect handset on your PC, the handset displays "Call and Message functions will not be available while connected to USB". 5. Once the USB connection has been established, the handset displays "To avoid data corruption always carry out safe removal hardware on PC after use." and the computer screen then shows the LG NEON device. If the detection does not occur, skip to Changing USB Connection Settings section on page 63. 6. Follow the instruction in the program to transfer music to your handset. n Note If you have a USB hub, connect the handset directly to your computer rather than through the hub. Transferring Music using Windows Media Player 1. Open Windows Media® Player on your computer (version 10.0 or higher). 2. Use the USB adapter cable to connect the handset to the PC. When you try to connect handset on your PC, the handset displays "Call and Message functions will not be available while connected to USB". 3. Once the USB connection has been established, the handset displays "To avoid data corruption always carry out safe removal hardware on PC after use." and the computer screen then shows the LG NEON device.
Jul 23, 2011 | Cell Phones
My hp photosmart 8886 dock will not transfer my pictures to my computer. I checked all of the cables and tried all of the USB ports on my computer. When I press the transfer button, it reads,...
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jan 17, 2011 | HP Photosmart 945 Digital Camera
Camera used to auto download pictures to pc but now just shws device not connected when it is and camera shows establishing connection already reinstalled software
Consider NOT connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Dec 07, 2010 | HP Photosmart M417 Digital Camera
I have been using my G11 with no problems for a year. Just tried to download pix and keep getting "Communication error". Checked the cord, it's fine, turned camera off and on several times,...
hi kbailey. Turn on the camera and go to the menu. find the reset function. Reset the camera. This means you are returning it to all of the settings it was at when it was brand new out of the box. Joe
Thanks for choosing Fixya!
Nov 26, 2010 | Canon PowerShot G11 Digital Camera
How to upload photos on my computer
They are several ways to upload a picture to the computer. The common way is through the USB cable that should of been provided with the camera. Once the connection is establish, the computer will show an external drive is connected in the My Computer window. Locate that drive and open it. In there you will find the pictures. Then you can copy those files and transfer them to anywhere in the computer. Another method is to remove the memory card from the camera and insert it into a computer that has the slot for that particular card. If it doesn't, you can purchase a multiple card reader and connect it to a USB port. The computer will recognize them as external drives. Insert your card into the appropriate slot. Then do the same as I mentioned above.
Oct 28, 2010 | BenQ DC C840 Digital Camera
Won't download pics "Establishing Connection"
Jun 16, 2009 | HP Photosmart R727 Digital Camera
HP Photosmart M437 not establishing connection
Apr 20, 2009 | HP PhotoSmart M437 Digital Camera
Digital camera that will no longer connect to the computer.
Mar 12, 2009 | HP Photosmart M415 Digital Camera
Transfer the photos
This can occur due to 2 reasons..
1) Bad USB port: Try connecting to a different USB port and see if it works. If it does then its probably a problem with the USB cable.
2)Bad USB cable: You can resolve this by Changing the cable or by getting a USB card reader. Specify the details of your Memory card and i will help you find a card readr that suits your card..
Jun 16, 2008 | HP Photosmart R717 Digital Camera
HP Photosmart M407 Digital Camera Logo
37 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
