Question about InFocus LP330 and LP335 Replacement Projector Lamp - SP-LAMP-LP3 Projector Lamp
Black lines are appearing on the top and bottom of projection,.
I have an Infocus LP335 used primarily for meetings and presentations in the office. I noticed two large thick black lines that a appear on the top and bottom of the projection whenever we turn the machine on. I have already re-adjusted the bulb and checked the resolution of my laptop, but the lines remain. Any suggestions?
  • itteck Jan 09, 2008
  • 2,237 Answers
Try factory reset in the menu. if that doesn't help, it could be the light tunnel, but infocus doesn't have parts for the lp3xx series anymore.
Posted on Aug 03, 2009
Where could I get the plastic lens for my infocus 61md10
Remove the little plastic lens and throw it away. There is no replacement available anyway. Reassemble the tv and it should work fine. Mine has been good for quite a while now.
Dec 08, 2011 | InFocus ScreenPlay 61" Rear Projection...
Infocus projected image is distorted
check the screen resolution settings in visa it maybe different than the desktop settings.infocus can execpt many resolutions but not all. try 1280x1024
Jan 29, 2008 | InFocus ScreenPlay 4805 Multimedia...
The device is an InFocus LP 290 with less than 100 hours on the bulb. I have used the projector several times over the course of two years without any problem, but never longer than 3 hours at a time. A...
there is an issue with the power supply edge connection with the main board. you'll need to have it sent to an infocus service center for repair. try av solutions in ny. they're pretty good. www.avsolutionsny.com
Nov 24, 2009 | InFocus LP290 1100 Lumen XGA LCD Projector...
Mitsubishi DLP wd-52725 wavy lines from top left to bottom right
the DM board is going bad and needs to be rebuilt. check out www.tv-techs.com
Jan 02, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Image has bend at top of screen
first reset the setting to factory default. if it persists on a regular image too, either the lens, the tunnel or something else in the optical engine is damaged (from a fall?).
Jul 29, 2008 | InFocus ScreenPlay 4805 Multimedia...
Lp335 in focus projector lamp not turning on; spark switch gap is sparking
It could be the lamp. I have seen this many times on DLP'S. If the ballast is firing it which is usually around 600 volts or so, then i would say it is fine, and only needs a lamp. Let me know if that helped you. Later Jay
Jan 20, 2008 | Office Equipment & Supplies
Infocus x1 image issue
the light tunnel has collapsed and needs replacement. it's only about $10 and fairly easy to replace.
Sep 29, 2007 | InFocus X1 Multimedia Projector
248 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
