Question about Motorola Mobility RAZR V3
MOTOROLA RAZR V3 SD CARD? SANDISK.
PUT SAN DISK INTO PHONE PHONE DOES NOT NOTICE CARD IN PHONE DELL LAPTOP KNOWS ITS THERE. WHAT NEXT?
    President:
  • 949 Answers
Did you format this card with your pc first, you should not have, is the card under 2gb,the phone can not handle a 2g card or over,,
now if you did not format the card with your pc and it is under 2g,you can now try to format card with your phone, it will not be able to use the card until it is formatted with the phone,,if this does not work then try formatting the card with pc then try it again with phone.
Posted on Dec 30, 2008
REMOVE SD CARD
1. turn the phone off.
2. Open the battery door.
3. you'll see the end of the sd card sticking out next to the battery.
4. remove it.
Apr 08, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Removing the SD chip
Okay, here is a link that will help..but it shows you how to insert it instead of remove, but you would just be doin reverse so either way it will benefit you. http://www.somelifeblog.com/2007/09/razr-install-microsd-transflash-card.html
Jul 03, 2008 | Motorola Mobility RAZR V3
Memory card installation
hi,
does your motorola Razr have a Memory Card Slot?
is you Razr model is V3re or V3 only.. (this models doesn't have MMC slot)
is your razr is V3i or v3x or v3xx then the MMC slot is located at the back closed to SIM card.
Jun 09, 2008 | Cell Phones
Where do you put the Micro SD card in a Motorola V3 Phone.
It depends on your carrier or phone model.
Verizon Wireless still uses the CDMA network. CDMA gets the phone user ID from a programmed chip hardwired to the phone instead of a SIM card.
Because of this, there is room underneath the battery cover, south of the battery on the right side of the compartment for a mini-SD card.
Other carriers such as T-Mobile, Cingular/AT&T DO use SIM cards to store user ID, so there is not room for a memory card.
I do know that the MotoRazr2 V9 from AT&T DOES accept Micro-SD cards.
But if you have a GSM carrier such as T-Mobile or AT&T, the Razr V3 does not have a card slot.
Mar 03, 2008 | Motorola Mobility RAZR V3
I know of a solution, but it is dangerous to your phone and it will probably void your warranty ifyou break it.
1) open the back of your razr, revealing the battery and the sim card.
2) do you see the small screws that hold the lower part of the phone on? there located on the edge of the phone.
3) unscrew these and take off the black casing that both holds your SIM card in place, and prevents you from putting in an SC card to your phones motherboard.
4) place the sd card onto the pannel of your motherboard, making sure that it fits properly.
5) put everything back together and your done, you now have a thrid storage device on your phone.
Feb 26, 2008 | Motorola Mobility RAZR V3
Remodelling of motorola RAZR V3
what you are atalking about is impossible yo can not have that done you would have to buy a new model phone that supports and external sd card or 2gb
Feb 23, 2008 | Motorola Mobility RAZR V3
Motorola RAZR V3
try reformatting the sd card then transfer music to it again
Feb 08, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Cant find where to put the micro sd card on my motorola v3
take the back off the phone that covers the battery.....on the left side next to where the sim is inserted you will see a silver clip place the MicroSD card in the slot....:)
Jan 03, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Downloadindg pictures from motorola razar v3 to pc
Goto Settings-> Connection -> USB Connection -> Default settings change to "Memory Card" and then connect with your PC. you will see your SD card as a disk drive in my computer. if you have photos saved on phone you need Motorola Phone tools installed. software CD that comes free of charge.
Dec 12, 2007 | Motorola Mobility RAZR V3
Micro SD Not Reading
I have same problem with A1200 not recognize micro sd card.
some one help ,Please.
Thank - you.
Oct 07, 2007 | Motorola Mobility A1200
Motorola Mobility RAZR V3 Logo
134 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
