Question about GE WJSE4150B Top Load Washer
GE washer WJSE4150B1WW clicks on gentle cycle
It also clicks on 6 minute cycle and makes lights dim in home each time it clicks.
  • Anonymous Jan 16, 2009
    Have experienced the exact, yes exact same problem over the last month. Specific to the six minute cycle during normal wash conditions. Loud clicking, drawing quite a bit of current as some of our lights elsewhere in the house dim during each click.
  • 239 Answers
SOURCE: GE WJSE4150B1WW Model top load problem
It sounds like the timer must have went bad or has a loose connection, If I understand you correctly its stuck in the spin mode. and won't go to rinse or wash cycle, Is that what you are saying, If so Maybe the start button got pushed in to hard or pulled out to hard. If It don't work let me know so we can work on something else so we can get it fixed for you, Happy Holidays bear001
Posted on Dec 14, 2007
SOURCE: GE WCVH6260 Front Load Washer
thank you ...thank you...thank you. i never knew that there was a filter..as ge manuel says nothing about that. got 2.75 in change, a few rusted screws and assorted other **** out of it. runs like new
Posted on Nov 27, 2008
  • 151 Answers
SOURCE: GE Prodigy Washing machine making clunking noise
One common problem area is the clutch assembly. The clutch is built on top of the motor, the motor drives the clutch and the clutch assembly drives the rest of the washer. The clutch gets very noisy when parts inside are worn out. The shoes lining that drives the inner drum of the clutch wear off and you will get a metal on metal sound. Clutches often can be rebuilt, but sometimes they are too worn and replacing the whole clutch is the best repair. Please use this link here for clutch replace and repair info. The belt and pump may be the next items to check for noises. How to access the washer. Clutch repair help.
Posted on May 03, 2009
SOURCE: GW Profile Washer Model WASE4220
The motor is bad. I just fixed one like this myself. The original motor has been superceded and the new one fixes the problem.
Posted on May 18, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: I have a GE Profile Prodigy top load washing
The gears maybe going out. Sometimes it is able to engage in the other direction which the spin, sometimes not. Washing machine have complex gears that in one way agitator works, and the other the gear locks to turn the whole tub. The clicking noise is probably the locking mechanism in the gears that has caused the whole intermittent problem.
Posted on Jul 01, 2009
Agitater problems will not agitate
To Reset computer. Unplug for 2 minutes, plug back in, open and close lid 7 times slowly to reset computer. This should solve your problem.
May 09, 2009 | GE WBSR3140DW Top Load Washer
May 03, 2009 | GE Washing Machines
Dec 13, 2007 | GE WBSE3120B Top Load Washer
Washer stopped
Bear in mind I'M a novice.. but I'm going to try replacing the CONTROL PANEL ASM WJSE4150B1WW (for GE Model: WH42X10303 found one for $45 at partadvantage.com ... I don't have the water temp problem but the other two yes...
Dec 04, 2007 | GE WBSE3120B Top Load Washer
Have to hit start button several times over first few minutes, due to it shutting off. I think it may be a faulty switch?
I have the exact same problem.. (I suggested I'm going to replace the CONTROL PANEL ASM WJSE4150B1WW (for GE Model: WH42X10303) found one for $45 at partadvantage.com
Nov 15, 2007 | GE WBSE3120B Top Load Washer
WASHER JAMS UP
from the description it sounds like the motor might be getting weak or something is getting caught underneath does it make any funny noises. let me know
Nov 05, 2007 | GE Profile Prodigy WPSE4200A
GE WJSE4150B Top Load Washer Logo
111 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
