Question about Maytag Atlantis MAV6000 Top Load Washer
How do you open the top of a front load washer?
  • 21 Answers
Most have a few screws at the back of the machine holding the top in place.....once you have taken the screws out, slide the top forward....please make sure you unplug the machine prior to opening it up
Posted on Dec 30, 2008
  • HNHAPP Dec 30, 2008
    sorry, slide the top to the rear of the machine not forward
How do i open the top of a top loading washer
IF you are standing in front of the washer, there should be a slot in the front top center of the machine. Just reach your fingers in there and prop the lid up. If it is locked, try cycling the washer through a load until it is completed and releases the lock.
If you are referring to the entire deck lid, and need to open the machine up, use a butterknife on the front end seam where it clips into the washer and lift up. pressure clips. there may also be two screws in the rear that need to be removed, but you can just pry the front open, and it will lift up, giving you access..
Jul 24, 2014 | Roper Washing Machines
I got the top off the washer, and now I cannot find any way to open the front panel of this top loading washer. It is the Atlantis MAV9750AWW.
Most don't have a front panel. Just top panel and rear panel.
Did you raise the top panel?
There are clips there that you have to find with a flat knife type tool.
Jun 26, 2011 | Maytag Atlantis MAV7551 Top Load Washer
Have a Hotpoint 6 cycle HD washer. I need to open the top in order to clean.
Most front load washers have 3 screws on the top, back edge of the lid. Remove these 3 screws, slide the top back about 1 inch, and lift the top off. If you could post the model number off of the machine, I will be able to help you further.
Regards, Rick
Jan 07, 2011 | Hotpoint WMA64 Front Load Washer
How do I open the top of the washer to change out the lid lock part?
top/front of washer seperates by way of hidden clips. insert putty knife or butter knife between front seam of cabanet and top. about 2 inches from left side and 2 inches from right side push in and pull up on top. lid switch is located under top/front
Nov 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Where do I find the serial number on my lg washer
Open the front door on front-loading washers. Look at the upper part of the door frame just above the opening.Look at the right side of the washing machine near the front, upper corner on top-loading washers.Identify the location of the metallic rating plate attached to the frame.Find the serial number by identifying the number that follows the "S/N" printed on the plate.
Jun 12, 2010 | LG WM2301H Washer
Whirlpool Front Load - Code F 32 - Cannot open door
F32 is the code for Pressure Switch Failure. Which is only found on a tech computer. Remove the top panel from the washer by removing the three screws in the top back of the washer. Inside the back right corner is a round plastic box, either black or white, that is the pressure switch box. Check to make sure all the quick connect wires are connected and tight. Unplug washer to reset it. If the cycle fails still with the F32, you'll need to get a new Pressure switch box. If that doesn't fix it then it could be the control box( the bigger rectangular box in the front right that the wires connect to.) Good Luck and Happy Washing
Sep 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How do I open the top of my front load washer (Neptune Mod. MAH3
there 3 screws on the back u take off but to take door latch off u dont need top off u open your door take the spring off the front of your boot then remove the screws from door latch reach back there behind boot unplug put new in and put back togather
Apr 08, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Kenmore Elite top load washer leaking
in the two front corners insert a putty knife and pry upward.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 05, 2009 | Kenmore Elite 45986 Front Load Washer
How does the top come off ge washer model wjxr2080t6ww
Use a putty knife to push the spring clips in where the top of the front panel meets the washer top, about 2 or 3 inches in from each side. Front panel pulls forward and lifts off pegs, revealing two 1/4 inch drive hex screws holding top to side panels. If your washer has the lid switch near the front, push the tab on the back side toward the center of the switch and push switch up, then twist 90 degrees and pass switch back through the opening. Now lift washer top at the front side. Most washer tops will unhook from the back side now, but some need to be slid an inch to the side yet to remove once the top is lifted a few inches. If you model still has the lid switch near the back of the washer opening, lift the top at the front and unhook the back of the washer top, pull the top forward a few inches and unplug the lid switch disconnect block. (two wires)
Oct 12, 2008 | GE WVSR1060A Top Load Washer
Opening the top of front load LG washer
to get your lid of the washer there are 2/3 screws at the back right under the lip of the lid once you have taken the lid of u will see the top of the soap drawer u can sometimes get into these by undoing the clips on either side of the soap drawer if u cant do it that way only other way is to make sure your soap drawer is closed properly and hit it hard at the front it should dislodge more than likely your conditioner drawer
Aug 15, 2007 | LG WM-2277HW Front Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
81 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
