Question about NEC VT47 Multimedia Projector
Cannot get projector to display image on laptop. Only image is the logo
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Try switching input of projector because seems projector has not selected proper input to display laptop image.
    Problem Solver:
  • 5 Answers
If that other one above didnt help then you can also press FN + f1,f2 etc, on your laptop and then send my the type of laptop your using and ill tell you the right f* button to press with it.
Posted on Feb 19, 2009
First time using infocus 1x projector with this laptop - installed drivers but there is no start up screen on the projector and will not display laptop image.
You have to tell the computer you hooked up an additional external monitor. Lower left on the keyboard you will see a "FN" key. Across the top, your F keys...look for an icon that looks like a monitor. Usually F5, F7 or F8. Hold down the FN key and select the F5 etc key which is the command to display the image through the external port. Doing this once displays image through the projector and laptop. Twice displays image to projector only and three times returns to display only on laptop again.
Jun 19, 2010 | InFocus LP640 Projector Multimedia...
Unable to play live tv from lap top to projector
Is it just the live tv or the laptop in general you are not getting a signal from? Using 15 pin VGA cable correct from laptop to projector?
When booted to projector, on laptop, select "FN" key and either F5, F7 or F8 depending on your laptop. Look for the monitor logo on the F keys. This is telling the computer that you have hooked up an additional external monitor (the projector). Once will send image to projector, twice will display on both, a third time will return to just image on laptop.
Jun 17, 2010 | Sanyo PLC-XU51 Multimedia Projector
I can''t get the computer image on the screen.
reflash the unit with the current firmware and also make sure your cables are good.
May 26, 2010 | InFocus LP70+ Multimedia Projector
Hi,I have a Proxima desktop projector that I have
right click on your desk top and check the display settings.
May 15, 2010 | Office Equipment & Supplies
CTX EzPro 550 data projector and laptop operating on Windows XP
Usually the key combination is 'Fn' (function Key) + F4 (or which ever F key that displays the symbol of monitor on it). This key combination is used to toggle the display between monitors.
Please come back and vote for me if this turns to be helpful for you. Thnx
Mar 20, 2010 | Electronics - Others
I have 5 Dell 4310 WX projecors and I would like to display my logo when they start-up. Can this be done with the projector only or is a laptop necessary for this to happen?
I believe the Dell logo is hard-coded for the Startup, but you can change the Wallpaper form the Dell logo, to an image of your choice:
From the Setup Menu, or Others Menu, you can go into:
SCREEN SETTINGS—Select and press checkmark to activate screen settings. The screen
settings menu consists of the following options:
CAPTURE SCREEN—Select and press checkmark to capture the screen display, the following message appears on the screen.
NOTE: To capture a full image, ensure the input signal that is connected to the projector is 1280 x 800 resolution.
SCREEN—Select Dell to use the Dell logo as wallpaper. Select Captured to set the captured image as wallpaper.
RESET—Select and press to delete the captured picture and set back to the default setting.
More information available on the Manual here: http://support.dell.com/support/edocs/acc/4310WX/en/ug/pdf/4310WX_en.pdf
Jan 14, 2010 | Compaq Presario M2000 Notebook
LCD projector not displaying image of the laptop
On that Dell, you have to tell the laptop to display the image on an external unit--look on either F4 or F8--you will find a small TV screen symbol. You have to press and hold "alt" and press the key. The options are, 1-show image on just the laptop, 2-show the image on the laptop *and* something else, (like a projector), or 3-show an image on JUST an external display. NOTE: Sometimes, you have to turn on the projector FIRST, then immediately turn on the laptop so they boot together--just one of those strange things...(remember, **for example** first press of "alt" F4 will get you laptop and projector, second press of "alt F4 will get you JUST the projector, third press of the keys will bring you back to just the laptop)---Rick
Sep 07, 2009 | Panasonic PT LC75U Multimedia Projector
Connecting to laptop
Try changing the refresh rate on your graphics drivers to 60 or 70 hz on both your laptop screen and the projector. Do this at the desired resolutions as well.
Aug 07, 2008 | Acer PD523 Multimedia Projector
Can't get computer images to project
Hi, I have found out that you must have the laptop set to an external monitor, in the control panel, display area, click on 2, then you must have the projector turned on before you start the laptop so it can recognize that the projector is there. Also make certain that you allow the unit to cool off by turning the lamp off, leaving the fan on and open the door where the projection lens is located.
Jun 29, 2008 | Lightware VP 800 Plus Multimedia Projector
Can't get the projector to project an image from my laptop.
Yes you need to press something on your laptop ...maybe FN +F3 or FN+F4..but after you have image but your projector still turn of...then follow my next comment.
Takecare..
Apr 19, 2008 | Computers & Internet
NEC VT47 Multimedia Projector Logo
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
