Question about Logitech X-240 Computer Speakers
No sound I moved my pc, unhooked everything, no i have rehooked everything up.. I have no sound, i have unplugged, replugged, looked at the manual nothing..,,.what am i doing wrong, im so frustrated...''HELP''
  • kaulback157 Dec 31, 2008
    Yes, I have the same problem which is no sound
  • 91 Answers
Make sure the speakers are plugged into the GREEN port on your sound card many times people plug it into the linei n or mic jack by accident.
Posted on Dec 30, 2008
What could cause the instrument cluster to stop working?
you might go to dealer did you unhook the battery try unhooking it rehooking it up it up after20 seconds i look for relay instrument panel in engine compartment replace it
Sep 04, 2014 | 2001 BMW 325i
My HP A6400f pc has started to not want to turn on. It makes this wierd buzzing noise sometimes, monitor says video cable connected and then some times it wont even let me manually turn it of I end up...
Hi, mtmj8,
Can you tell whether the buzzing sound is coming from the power supply fan, the disk drive, or maybe an internal fan? I can't imagin it's the power supply fan, as the whole system would likely just cut out.
If it's an internal fan (CPU fan of graphics card), the system will come up to some random point before a component overheats, and usually the device will cut out in order to protect itself. You may be lucky and simply be able to replace the errant fan, or you may have to replace the component itself. Only if you feel confident enough, you may try to open the case and see if you can tell better which component is failing; take all precautions when operating a system with the case opened, and ensure that you do not touch any internal parts even while the power is switched off, as power supplies can retain a charge even when switched off and unplugged from the power supply.
If the buzzing sounds a bit "clunky", it may be your hard drive that's failing, in which case, the prospects for recovery are limited - you will probably have to replace it and reinstall the operating system and any software you have.
Peter.
Oct 21, 2010 | HP Pavilion A6400f Desktop PC, Refurbished
Problem with my hp photosmart C6280 printer...when paper is in...says out of paper...looks like something is wrong where paper feeds...
Try to reset the your printer by turning it off and unplug the power cord from he power outlet then unhook the printer cable and let the unit sit for 5 minutes and replug everything back in. If this would not work try to un-install then re-install the printer's software. If this would not work still call the printer's manufacturer for the unit to be warranted.
Sep 09, 2010 | Computers & Internet
I just started using the Belkin N150 after hooking it up it worked for several days than it stopped. I have reset it unhooked and rehooked all connections unplugged power and replugged it in and still...
With what you have mentioned, i will say the following:
Keep pressing the reset button for 3 full minutes by counting on a stop watch. You must see the security(Lock) light going OFF after this reset, else try again, press it tight. After this type reset, unplug the power cable after 1 minute and keep it unplugged for another 1 minute. Plug in back the power cable and check the connections as it was made when it worked. Insert the belkin CD on the primary/base computer and setting it up.
If still its an issue, mail me at:
shanky_arvind@yahoo.co.uk
I ll make sure that your issue is resolved at any cost. Please, do not worry. I ll provide you with service FREE of any charges.
Jan 22, 2010 | Belkin (F5D5231-4) Router
Fluidrower strap does not recoil.
Probably is the one way bearing broken. You can order one at your agent.
Regards,
First Degree Fitness
Dec 29, 2008 | Neptune First Degree Fitness Fluid Rower...
Dell dimension 5100 - no power
It seems that your SMPS power supply may be having some fault...try to replace it...
Dec 02, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Sub
change connection cable with new one-------- change sub location move it from corner if you put it there.
Aug 05, 2008 | Yamaha EQ-70 Home Equalizer
Logitech X-240 Computer Speakers Logo
220 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
