Question about Philips Magnavox MS3652S 36" TV
TV picture was warped, no it is black, but the power light remains on...
I found a similar post for a different tv, but my Magnavox MS3652S Color television is doing the same thing. About a week ago when the television was turned on the picture did not come on the whole screen. There was a wiggly (asymetrical) line on the right side (when facing the tv) and a low volume, but high pitched noise (screech) could be heard, but eventually the picture would fill the whole screen. Changing the channel or calling up the cable guide (which mostly fills the bottom of the screen)seemed to get the picture to come in a few times. The problem became worse, as the TV started to turn itself off, and it took more and more tries to get the picture to come in. Now there is no picture at all, the screen is completely black, but the green power light will stay on. Now, when the tv is turned on it will either emit the low volume "screech" and display a concave ( >
  • Philips Master
  • 3,459 Answers
I had a similar problem. Started out with the video shrinking and expanding. Then just recently it just broke- the TV would power on but I had no audio or video.
Its now fixed
You can find a repair kit here.
http://www.magnavoxhelp.com
Posted on Jun 21, 2008
    Genius:
  • 1,074 Answers
The problem you are having is in the power supply you can go ahead and take your set to a repairman o look at your set good luck.
Posted on May 02, 2007
Tv says front in top left and shows no picture. Dont no if im on the right input for cable
The TV is telling you the front audio/video jacks are in use. In this case, do plug in your RCA jacks there.
Nov 30, 2010 | Philips Magnavox MS3652S 36" TV
Keeps shutting off till it warms up
Check for bad caps in the power supply
Aug 22, 2009 | Philips Magnavox MS3652S 36" TV
Turns off on its own after a few second clicks on and off for about 5 sec. until it turns itself off but the power light is still on
This is point to a fly back issue and a flyback fr this would run you $95 plus labor good luck with your TV
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 23, 2009 | Philips Magnavox MS3652S 36" TV
Tuner will not pick up cable box on channel 3, front and rear AV
In order for the TV to work with the cable box by using a piece of coax and tuning the TV to channel 3, you must make sure the TV is in "Cable" mode on the tuner and not "AIR or Antenna" the frequency maps are different between these types of service and channel 3 cable will not be the same as channel 3 on Air or UHF/VHF.
Often there is an auto program feature on TV's that will "scan" for all available channels, and this should select the proper input type.
Hope this helps!
Mar 29, 2009 | Philips Magnavox MS3652S 36" TV
No power, lost power while watching tv
after picture is lost, does the screen remain lighting?
Jan 13, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Just went black without warning. Now won't come on.
What does the power light do when you press power? Does it blink? Please respond to this same post and I will try to help you with the problem.
Jul 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
36 magnavox tv shuts off by itself
MAGNAVOX TV ONLY. 5-10 SECONDS AFTER TURN ON AUTO TURNS OFF-NO LIGHT STAYS ON-I AM FRUSTRATED BUT IT SEEMS LIKE THE OFF ON SWITCH JUST CLICKS BACK TO OFF-ALSO DOES SAME THING BY REMOTE
Jan 16, 2008 | Philips Magnavox MS3652S 36" TV
Shut off and won't turn back on
try unplugging the set from the wall for 1 min and then plug it and try power button
Nov 12, 2007 | Philips Magnavox MS3652S 36" TV
Need to know what's wrong with my tv
nailtek,
You may have filed this one in the wrong place. A maggie MS3652S is a 36" crt based model, with a L01.1UAC chassis. But you start off your explanation as if it were a projector TV. Check the model and series again and let me know if I can help...
William Rayburn, CET
Premium Technologies
premtech@willapabay.org
Nov 05, 2007 | Philips Magnavox MS3652S 36" TV
Philips Magnavox MS3652S 36" TV Logo
153 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
