Question about PANDIGITAL PAN 70-0 7.0" LCD Digital Picture Frame With Remote
Not all jpeg images will load on 7'' Pandigital Photo Frame
After transferring images on my computer to the 7'' Pandigital photo frame when I check on the frame some of them are fine but for others I get a message that says ''Format Not Supported''. All the images show up as being transferred when checking through the computer. On the frame itself, however some slides are dark and have the message stated above. All the images I've tried to transfer are JPEGs. I can't figure out why some images transfer and others do not. Thanks for any suggestions
  • stevewilson1 Dec 31, 2008
    Thanks. I'll play with the resolution although I don't think the ones that didn't load were way out of line. I did find the following Q&A on the Pandigital site. This may pose a solution but I can't figure out how to get to the "JPEG Options Dialogue Box", referred to in the answer. If anyone know how to do this, I'd appreciate hearing from you.
    I edited my pictures in Photoshop, saved them as a JPEG but they do not display on my Picture Frame.
    There are a few types of JPEG formats, therefore your pictures may have
    been saved in a incompatible format. The correct format to save images
    in when using Photoshop is: JPEG - Baseline Standard. When saving
    images in Photoshop:
    Click Save As, see Image 1. Click OK, you will open the JPEG Options
    Dialogue Box, See Image 2. Choose Baseline (“Standard”) from the Format
    Options sections and click OK. Your picture should now play on your
    Frame.
    Back to top
    Frame.
    Back to top
    Problem Solver:
  • 3 Answers
I was having a problem too with my Smartparts frame. All the pics were from the same camera but some of the vertical (portrait) orientation shots wouldn't show right. Just a bunch of thin colored lines. After some phone calls I did try to "resize" the photos to the "resolution" of my frame (had to look that up too). My frame is 640 width by 480 high. So I took a shot and changed all the goofy photos to 480 width (since they were vertical) and let Photoshop change the the other number. Low and behold the buggers are showing up fine now. Well on to my next problem - focusing with the new D90. I think that one is going to be more challenging yet. Hope this helps you out.
Posted on Dec 30, 2008
I received a 7" pandigital
If the photo frame has a slot for an SD card, you can drag and drop the images you want to the card and then insert it into the frame. Connecting the card to the computer can be accomplished by using a card reader or, if the computer has a built-in SD slot, just insert the card.
Jan 21, 2011 | Cameras
What version of Windows is required to run Pandigial 7
the PANDIGITAL Pandigital 7" Digital Photo Frame is not computer dependent. you simply put the images you want onto a memory card and put the memory card into the frame. in other words, you can use it with any version of windows, mac, or Linux.
Jan 15, 2011 | PANDIGITAL 7" Digital Photo Frame With...
Help i need to transfer music from my computer to my digital photo frame how do i do it
Are you having any problems with images? To get music on it, excatly like images but make sure it in a mp3 format, if it from itunes it normally in acc format etc
Dec 09, 2010 | PANDIGITAL 7" Digital Photo Frame With...
How do you add pictures to the photo fram:
Use PhotoFiltre free photo editor program to edit your pictures.
You may download it from the below link.
http://www.4shared.com/file/gqHN4jSz/pf-setup-en.html
1. Photos should be in .jpeg format.
2. It is better to scale your photos with the above editor to 800x600 pix.
3. Prepare your pictures in a PC using PhotoFiltre. Scale all the pictures.
4. Transfer your pictures from PC to a USB Flash Disk (Memory Bar)
5. Plug USB Flash Disk to your Photo Frame.
6. Probably your photo frame will ask to transfer your pictures from flash disk to internal memory. Accept this and by pressing enter/OK/Set (Any button that changes from one product to another.)
I think it helps.
Jun 15, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
How do i upload pics from my pc
I have a Mac and tried to drag and drop my photos as mentioned above. The results?
- Wiped all pictures off of the frame.
- When I tried to reload from my laptop it shows "format not supported" as a placeholder for the pictures. The images are in jpg format.
How can I fix this problem?
Mar 18, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
How do i get pics off computer to pandigital frame..keeps telling me to insert media card- do i have to really transfer to a flash drive to put on frame
Hi friend,
You need to purchase media card reader then you can transfer your photo. media card reader is device which is use as cable connect to computer ..t
Dec 20, 2009 | PANDIGITAL 7-Inch Digital Photo Frame with...
Pandigital Photo Frame - Slideshow leaves out Photos?
Size limit depends on exact model. Anything over 4GB will almost certainly not work consistently with any. model 1GB or less should work with any model. None of the images should be stored in folders, and all should be jpeg format (.jpg). If any of them have been edited, they may be saved as Progressive jpeg or something similar even if the extension (.jpg) remains the same. If you resave the missing photos in as JPEG in MS Paint, it should ensure they are compatible. You may have to format the memory card and re-add the photos to make sure it will work,
Sep 20, 2009 | PANDIGITAL 7" Digital Photo Frame With...
Transfer pictures
Plug the frame into the usb slot on your computer. Open up the folder with your pictures on it. Then open up my computer and look for the drive that is the frame. Drag your pictures right to the frame,s drive.,
Dec 13, 2008 | PANDIGITAL 7-Inch Digital Photo Frame with...
Card read error on the digital picture frame - brand new. I bought this 7" digital photo frame from argos and I insert the SD card whilst the device is turned off, when I turn it on the message reads...
Put the card back into the camera and off load/take off your pictures (Put them on the computer). Then, put the card back into the camera and go to your options menu. Find the format feature, and format the card. Take some new pictures and then try putting the card back into the picture frame. Does it work? If so, transfer the images from your computer back to the card. If it continues to work, then Great! If not, more than likely there is an improper or corrupt file among your photos.
Good Luck!
Dec 12, 2008 | PANDIGITAL 7" Digital Photo Frame With...
PANDIGITAL PAN 70-0 7.0" LCD Digital Picture Frame With Remote Logo
1,433 people viewed this question
Top PANDIGITAL Photography Experts
LP
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
