Question about Samsung BLUETOOTH? WEP210 MONO HEADSET AWEP210JBECXAR Wireless Headset
I own a g600 but it wont play music via wep210
I can pair my wep210 with g600 (blue light stays on) on 210,
when I connect to it 210 stays in flashing mode and phone says its connected to wep210 but if i try to use it to output to (say a music file) phone just says no bluetooth devices found. Can the 210 be used to receive music from phone?
SOURCE: can i pair WEP 210 with another phone
I had the same problem and solution 2fixed it, however to make the process a little bit more clearer i would add couple pf things: first turn turn ur headset off, then turn it back on and keep it held down untill u c a solid blue light and this blue light must be still and not flashing. now search the device on ur phone and u should be able to pair together and pin number will be 0000 for zero's
good luck
Posted on Mar 19, 2008
  • 10 Answers
SOURCE: Wireless headset pairing
With the Samsung WEP210 this is a common problem (which is actually just a user error)
This is what you do:
1. Of coarse make sure the headset is charged
2. Make sure the bluetooth headset if OFF
3. PRESS and HOLD the top/middle (on/off) button until the light stays on (it will blink then should stay on continuously). That means it is now in pairing mode.
4. Tell you phone to search for bluetooth devices.
5. It should find the headset, and by default type "0000" to pair your new headset**
**You can use whatever pin code you like......but I would recommend the default which is four zeros.
Posted on Dec 10, 2008
SOURCE: Samsung Bluetooth WEP210 and Blackberry
This worked, except you hold the bluetooth button down until it is a solid blue light on the wep210
Posted on Jan 19, 2009
CRTN
  • 716 Answers
SOURCE: Unable to pair my bluetooth with PS3
Is The Blue Tooth In Find Mode? To Inable Find Mode Hold The Power Button Until The Blue Tooth Stays Solid Lit Or Flashes. Then Search For It With Your Device And Once Completed Hit The Power Button Again And It Should Be Able To Pair Right Up.
Posted on Mar 04, 2009
ki6amd
  • 15 Answers
SOURCE: SAMSUNG BLUETOOTH WEP210 NEED TO KNOW HOW TO PAIR TO PHONE
Your manual can be found here... it should walk you through the connection process fairly easily.
Posted on Mar 23, 2009
I m unable to pair my wep210 headset with my samsung omnia i900 mobile
the wep210 multifunction button needs to be pressed till blue light flashes then stops on blue light continuious this is when you ask your phone to find bluetooth devices it will pick it up
Jan 28, 2010 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
SAMSUNG MOBILE CANT LOCATE THIS HANDSET
I have bluetooth samsung 210 and I just bought it todaty , ,my mobile does nit see it
Jan 06, 2010 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Pairing the Samsung WEP 210 headset to my Samsung Soul phone
Pairing Instructions
Pairing will create a unique and encrypted wireless link between two Bluetooth enabled devices, such as your Bluetooth phone and Bluetooth headset.
Ensure that the headset is off (see Turning the headset on/off).
Press and hold the Multi-Function button until the indicator light turns on in blue (approximately 8 seconds).
Set your Bluetooth phone to discover the headset by following your phone's guide. Typically, the steps involve going to a Setup, Connect, or Bluetooth menu on your phone and then selecting the option to discover Bluetooth devices.
Your phone will find the Samsung WEP210 headset and ask if you want to pair with it. Confirm this by pressing the Yes or OK key.
Enter a passkey or PIN, 0000 (4 zeros), then press the Yes or OK key.
Aug 21, 2017 | Samsung Bluetooth Headset WEP-210 B2700...
Mar 04, 2009 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
If you have lost the pairing on your Blackberry with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the Blackberry
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The Blackberry should search for any available Bluetooth devices and display what was found
5) Select the Samsung device and click add
6) You will be required to enter in a pass code which is standard ‘0000’. If not try '1234'.
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the Blackberry
Hope this helps
Chris (ziraffa)
Dec 15, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Can't conect headset
you need to hold down the button on your headset until the blue stays on instead of flashing, then the headset has been reset, then try pairing your phone with your headset, and type in 0000 as the password, this should solve your problem :)
Sep 07, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Jun 05, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Can i pair WEP 210 with another phone
good luck
Jan 20, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Samsung bluetooth wep-210
After charging hold the front button under the samsung name down until the blue light flashes.
caster44
Jan 04, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Samsung BLUETOOTH? WEP210 MONO HEADSET AWEP210JBECXAR Wireless Headset Logo
51 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
