Question about Pantech Duo Smartphone
Can i set a ringtone to text messaging
I want to set a music ringtone as my text messaging alert?????
  • LILRAZGIRL Jan 05, 2009
    im having problems with setting ringtones for my text messages.can u please help me.step by step
  • LILRAZGIRL May 11, 2010
    do i have to have a usb cord or songs in my media player to do so
  • 127 Answers
Yes you can.
Just chose your fav music and select as a massage alert tone.
EnJoY....
Posted on Dec 31, 2008
My samsung monte slide makes a beep when i send a text, how do i stop this from happening
Choose settings for profiles info.png 1 Find "Profiles"
  • Press Menu.
  • Scroll to Settings and press the Navigation key.
  • Scroll to Profiles and press the Navigation key.
2 Select profile
  • Highlight the required profile and press Options.
  • Scroll to Edit and press the Navigation key.
3 info.png Select settings for incoming calls
  • Highlight one of the following options:
  • Call alert type, go to 3a.
  • Call ringtone, go to 3b.
  • Message alert type, go to 3c.
  • Message alert tone, go to 3d.
  • Keypad tone, go to 3e.
  • Volume, go to 3f.
  • Press the Navigation key.
3a "Call alert type"
  • Highlight the required incoming call alert and press the Navigation key.
3b "Call ringtone"
  • Highlight one of the following folders:
  • Default melodies
  • Sounds
  • Music
  • If you select Default melodies:
  • Highlight the required ring tone and press the Navigation key.
  • If you select Sounds or Music:
  • If required, highlight a folder and press the Navigation key.
  • Highlight the required ring tone and press Select.
3c "Message alert type"
  • Highlight the required message alert and press the Navigation key.
3d "Message alert tone"
  • Highlight the required message tone and press the Navigation key.
3e "Keypad tone"
  • Highlight Mute or the required key sound and press the Navigation key.
3f "Volume"
  • Highlight the required category and press Navigation key right or Navigation key left to select the required volume.
  • Press the Navigation key to save.
4 Exit
  • Press Disconnect to return to stand-by mode.
Jun 25, 2011 | Cell Phones
I have a samsung B2100 mobile phone... i just downloaded a new text message ringtone...and i have no idea how to get the tone into my text message tones now..can you help me please ?
Go to settings then profiles then press options on one of the profiles ie. Normal go to edit press right to go to message settings press down to select alert tone then select your tone from music or sounds Hope this helps
Nov 17, 2010 | Samsung B2100 Cell Phone
How can i change my message tone on my samsung f480 from the standard tones set on the phone
Instead of changing the ringtone settings, tap the message alert tab (in the top centre of the display).
A set of message alert settings appears . You can change the Message alert type, if you want to, by tapping the panel and choosing the appropriate option.
To change the Message alert tone, press the Message alert tone panel .
In the menu that appears, press Change.
Then choose one of the options Use effect tone (one of Samsung's pre-loaded effects) or Use my alert tone (allowing you to choose from your own sounds) .
In this example, press Use my alert tone.
Press the Sounds option. In a similar way as changing ringtones (above) you now have the choice of choosing from your Music files, Ringtones that are loaded onto the phone, or My voice clips .
In our example, we'll again choose a file from our Music folder.
Press the Music option. A list of suitable MP3 tracks appears.
Tap the one you want in order to highlight it.
Press Options, then tap on the Select menu option to install it as your message alert .
You are now taken back to the Normal profile settings, where the Message alert tone has changed .
To save this change, press Options and then Save .
Alternatively, press Back and you will be asked whether you want to Save? Press Yes
Jan 12, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
How can i change my text message tone on my samsung f480 thaks
Please Follow these steps to change
  1. From the standby screen, press Menu.
  2. In the main Menu, press Settings.
  3. In the Settings menu, select Phone profiles and press.
  4. You will be presented with a list of phone profiles for different situations and environments. The one you're currently using will be ticked. Highlight the one you want to use and press the Edit button at the bottom of the display.
  5. You are taken into the profile settings. At the top of the list you'll notice three tab icons - these represent (from left to right), ringtone, message alert, and keypad sounds. You can switch between settings for these by tapping one of the tabs.
  6. Tap the message alert tab (in the top centre of the display). A set of message alert settings appears. You can change the Message alert type, if you want to, by tapping the panel and choosing the appropriate option.
  7. To change the Message alert tone, press the Message alert tone panel. In the menu that appears, press Change. Then choose one of the options Use effect tone (one of Samsung's pre-loaded effects) or Use my alert tone (allowing you to choose from your own sounds). In this example, press Use my alert tone.
  8. Press the Sounds option (Figure 16). In a similar way as changing ringtones (above) you now have the choice of choosing from your Music files,Ringtones that are loaded onto the phone, or My voice clips. In our example, we'll again choose a file from our Music folder.
  9. Press the Music option. A list of suitable MP3 tracks appears. Tap the one you want in order to highlight it.
  10. Press Options, then tap on the Select menu option to install it as your message alert.
  11. You are now taken back to the Normal profile settings, where the Message alert tone has changed. To save this change, press Options and then Save. Alternatively, press Back and you will be asked whether you want to Save? Press Yes.
Thank you Sir, Have a nice day.
Sep 26, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Ringtone for incoming text??
Most samsung models dont let you use ringtones as txt alert. Soz.
May 21, 2009 | Samsung SYNC SGH-A707 Cellular Phone
How do I set a ringtone to my text alerts
Depending on your phone company you may or may not be able to do this. Go to settings, Sound Settings, Alert tones, Text Message, then choose. It may not be exactly like that, but if so then I hope I helped!!
Mar 18, 2009 | LG Vu CU920 Cellular Phone
Text message ringtone
u have to change the alert that you set as your ringtone, that's the only way to stop it. So try it and see if that works
Oct 30, 2008 | T-Mobile Dash Smartphone
Setting ringtones as you text message alert tones
You CAN set a song as your text alert tone. Here are the steps:
1- Go to: Settings> Profiles>
2- Select your options (e.g. normal, vibrate and ring, etc....)
3- select Options> Customize (2)>
4- Highlight "Message Sound" and select Options> Customize (2),
5- Then browse to the folder your song or sound is in (e.g. audio) and select the file you want to use and save it.
I noticed that the songs have to be under 30 seconds to use as any type of alert tone for calls or texts.
Hopefully this helps.
Aug 10, 2008 | LG Shine KE970 Cellular Phone
When a text msg comes in it plays a mp3 instead of the normal text sound.
yes there is just go back into the setup and look at what you have as your text msg alert and change it.
Feb 01, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Pantech Duo Smartphone Logo
122 people viewed this question
Top Pantech Computers & Internet Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Are you a Pantech Computer and Internet Expert? Answer questions, earn points and help others
