Question about Canon ES900 Camcorder
I can't get the 8mm tape out of my Canon ES900 Camcorder
The camcorder powers up fine and I don't think we ever dropped or damaged it but sometime long ago it just started malfunctioning. Now when you power it up and press any button the eject notice begins flashes in the viewfinder. Meanwhile the camera won't do anything else
I was hoping, like a cdrom drive, there would be some way to overide the eject manually by inserting a paperclip into a small hole or something.
I would like to get the tape out to begin transferring the movies onto a DVD.
Any advice?
  • mwit465
    mwit465 Dec 31, 2008
    To manually remove the tape from the Canon ES900 video camera do the following after reading all below.
    1. Remove the two small screws from the tape door face.
    2. Look for the small metal peg on the left side, about 1” down from the top of the tape carriage. See pictures in the post I made as a guest for this problem.
    3. Using something small push down on the peg to release the tape door.
    4. Important Note: Most likely the tape will still be wrapped around the video head and held there by two capstans, (one on each side of the head)
    5. Carefully pull out the tape not damage it any more than necessary. Keep in mind this might cause the player to “eat” the tape at this area so smooth the tape here with your fingers (nothing metal) and wind the tape to begin playing past this area if possible.
    It seems this is a common problem with this unit; Canon should have put a better motor here in this critical area.
    Good luck, hope this helps everyone,
5 Suggested Answers
  • 5 Answers
SOURCE: Samsung Digital Camcorder VP-D351
hi..Please to pass on the remedy..I had this two weeks ago.. lcd ribbon is brocken.. breaks over time with being opened and closed.. Part available form partmaster.co.uk.. part no..SAMAD9706489A.. lcd fpc ***. easy to replce ..take you time and try yourself.. if i can help with instructions email..stefjanet@yahoo.co.uk.. cost of ribon £11.49.. GOOD LUCK STEF.
Posted on Oct 16, 2008
charcois
  • 763 Answers
SOURCE: how totransfer video from an 8mm camcorder to computer
i will give you a step by step on your camcorder.
  • connect your camcorder using your USB cable to your computer and be sure it is ON
  • Install the cd driver camed with your camcorder. if you didnt prompt on looking for a driver then go to the add hardware on the control panel and follow the procedure there.
  • after the installation you should see the icon on the my computer labeled scanners and cameras and indicating the model of your camcorder.
  • Install Ulead Power Producer or any editing movie that you have like Windows movie maker, nero movier maker etc.. i prefer to use Ulead because its so easy to use
  • after uploading and editing your videos using ULEAD save it on any various types of videos that you like. you should see it after you want to save it.
  • burn your videos on NERO software
Hope you understand my procedures. Good Luck!
CHARCOIS
Posted on Mar 25, 2009
cpt100
  • 154 Answers
SOURCE: canon es900 8mm camcorder won't allow tape insertion
Canon ES series camcorder was designed with 1000 hour capacitors on the processor boards. When the time comes these capaictors loose value and create problems for the main computer to communicate with other mechanical system in the camcorder. We were able to service well 7 years ago but the life of these component has aged too much to make it good anymore. I wish I have a better news for you but the success repair on 'ES model is very slim and if repaired, the labor charge may run many times over of the value of this camcorder. You can probably obtain a newer used camcorder at decent price and get all you tapes into DVD quick. Good luck -James
Posted on Mar 27, 2009
mannforever
  • 23 Answers
SOURCE: LCD screen not working on my Sony Hc 42 camcorder
Hi
The LCD cable is faulty. You need to replace the LCD cable from SONY authorised service center.
It's a common problem as this cable is bend each time when we open the LCD screen, so the cable become faulty.
Posted on Aug 11, 2009
Panasonic dvd video camcorder VDR-M55PP
system malfunction, put a soft reset on the camcorder.
Feb 24, 2008 | Panasonic NV-DS65 Mini DV Digital...
Auto power off
Link to user manual
No you can't turn off this feature
Nathan Petersen June 17th, 2005, 04:03 PM Is there away to turn the auto power off off. I dont think there is, just thought I'd ask, thanks. Don Palomaki June 17th, 2005, 08:47 PM Not on the original XL1. It will drop into STANDBY from PAUSE if there is a tape in the transport after around 5 minutes. If there is NOT a tape in the camcorder it will not not drop into STANDBY but will remain operating as a camera. Xander Christ June 17th, 2005, 09:25 PM Canon suggests that the only way to keep the XI from shutting off is to use the AC adapter as the power source, not the battery. I haven't tried it, so I don't know if it's true. Don Palomaki June 18th, 2005, 07:33 AM True - in that when using the battery, the camcorder will shut down when the battery runs out of available charge. However, using the A/C adapter does not prevent the XL1 from going into standby if a tape is in the camcorder. Nathan Petersen June 18th, 2005, 04:52 PM Canon suggests that the only way to keep the XI from shutting off is to use the AC adapter as the power source, not the battery. I haven't tried it, so I don't know if it's true.
No it still does it with the AC adapter, Im not even using the battery. It makes no sense to have the auto power off when shooting indoors while using the AC adapter, its just stupid. Don Palomaki June 19th, 2005, 05:59 AM Again, the key point is having a tape in the XL1. After about 5 minuts it goes into Standby mode (not the same as turning the power off with the dial). This is a carryover from pure consumer camcorders - to save battery and reduce damage to tape and head wear from a camcorder left in pause mode for a long time.
Pro users complained, so the XL1s had an option to disable this feature so that only the tape transport (VCR portion) is turned off after 5 minutes, the camera head continues to run. link to above thread
Dec 02, 2007 | Canon Optura Xi Mini DV Digital Camcorder
I have a 2003 Jeep Grand Cherokee 6 cyl. I am getting fault codes P0351,P0352 and P0353 which is defined as #1,#2 and#3 ignition coil circuit and code P0505 JEEP Idle Control System Malfunction and code...
I would check Cam Position Sensor as is directly related with ignition. Power loss is due to the ECU going on "limp mode" to prevent further damage.
I hope this helps!
Mar 26, 2013 | 2003 Jeep Grand Cherokee
I brought a lenovo idea pad z565 two weeks ago .the my kid drop a little toy on the left side of the cursor then it shuts inmediatley.Then i try to start up the system but it only blink the power, battery...
- you need to send the system to lenovo's depot in grapevine texas
- call lenovo and avail an ADP or accidental damage protection $69
- do not tell them what happen
- call lenovo after 3 days and tell them that system is not booting to windows
- they will advised you to send the system to depot
- if you don't have ADP this will cost you around $300
May 23, 2011 | Lenovo Z565 Notebook
Can you use hi 8 tape in the ES900 Analog Camcorder
I believe this camcorder is 8mm only, so you won't be able to use a Hi8 tape with it. They will not play right in your camcorder.
Sep 19, 2010 | Canon ES900 Camcorder
Sticky 8mm sony tape
need to go to an AUTHORIZED SONY REPAIR SHOP to get it fix , these camcorders are very delicate and needs to be tune and realign by a SONY EXPERT TECHNICIAN , thanks AJ
Jun 12, 2009 | Sony Handycam CCD-TR87 Camcorder
Canon es900 8mm camcorder won't allow tape insertion
Mar 27, 2009 | Canon ES900 Camcorder
AGP x1650 pro 256mb just stops working
you wont damage anything but get at least a 450-500w power supply. Nothing should be damaged
hope this helps
Jan 03, 2009 | Power Color 256MB PowerColor ATI RADEON...
Canon ES900 Camcorder Logo
459 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
