Question about Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi
Bulldog Remote Starter On 92 Blazer-Cranks but no fuel pump
I just installed a bulldog Remote Starter system on my 1992 Blazer S10 Tahoe and once done everything went according to the steps and transmitter works and cranks but the the fuel pump doesn't activate. It works fine when using my key in ignition. Can you tell me which wire in steering column activates the fuel pump or maybe if you might know if I may have miswired the ACC connection?
  • 3 more comments
  • brauliojimen Dec 30, 2008
    I connected the ORG, the Pink, and a Purple one. There was no BRN. Which one controls the fuel pump because the starter does engage through the remote but never starts because the fuel pump does not engage.
    Yes everything works fine when using my key and yes I wired to the heavy AWG wires at the bottom of the column that go into 2 block type connectors. I only saw an ORG, Purple, and Pink which I wired ot per the instructions.
    I didn't connect any of the other accessories just the starter but button 4 does cancel the remote start process.
  • brauliojimen Dec 31, 2008
    Model # RS102/RS102E Thank you for your help with this. This one little minor thing is driving me crazy.
    I installed one of these a couple of years ago and it worked fine. I don't remember if I connected the 2 WHT wires with the yellow or not for the ignition connection (PINK). I believe this is the wire that controls the fuel pump correct?
Replaced battery in 2002 s10 now bulldog remote starts and shuts off also have 791 module instaled
Posted on Feb 28, 2010
  • 328 Answers
I've wired several of these and you have likely hooked up the wires wrong its not giving power to the right wires at the bottom of your steering column...........re check your connections
on your truck there are 3 wires that need power for the starter to work they are the orange,pink and brown
hope this helps!
Posted on Dec 30, 2008
  • 4 more comments
  • s60six Dec 30, 2008
    are you connecting to the wires that are at the bottom of your colum that plug into the switch with the rod that moves when you turn the key?
    do the other accessories work when you try to start it IE:heater fan
    with the bulldog starter i mean
    what is the model number of your starter i'll do a little more research on it
  • s60six Dec 31, 2008
    got your msg I'll get back to you in the morning about it after i get a chance to go over the wiring diagrams
    ok here's a solution to get it working,but youll need to find a piece of wire to go from the steering colum area to the fuel pump relay.........
    1:locate the fuel pump relay
    2:with relay removed test which of the wires has 12volts with the key on and 0volts with key off
    3:connect a wire from the yellow wire of the 18 pin harness to the wire in the fuel pump relay wiring with the 12v switched power you found in step2
    4 replace fuel pump relay
    this should tell the fuel pump relay to give the fuel pump the 12v needed to run the fuel pump and solve your issue!
    hope this helps.......pls keep me posted!
    just to be sure here is the info on wiring your starter to your truck check this over before doing the above steps this was obtained @ the bull dog website if you want to look at it there copy and paste this web address to the address bar on your web browser
    http://64.85.6.121/diagrams/printpage.as...
    CHEVROLET
    MODEL
    YEAR(S)
    S-10 BLAZER
    1991
    -1994
    KEY
    T-HARNESS
    IMMOBILIZER
    N/A
    GM-3
    N/A
    PART
    COLOR
    LOCATION
    12 VOLT
    CONSTANT
    RED (+)
    IGNITION SWITCH HARNESS
    STARTER
    YELLOW (+) or PURPLE (+)
    STARTER
    N/A
    IGNITION
    PINK (+)
    IGNITION
    N/A
    IGNITION
    N/A
    ACCESSORY/HEATER
    BLOWER 1
    ORANGE (+)
    ACCESSORY/HEATER
    BLOWER 2
    N/A
    KEYSENSE
    N/A
    PARKING
    LIGHTS ( - )
    N/A
    PARKING
    LIGHTS ( + )
    BROWN (+)
    @ HEADLIGHT SWITCH or in DRIVERS KICK PANEL
    POWER LOCK
    LIGHT BLUE (TYPE C) See NOTE *1
    IN DRIVERS KICK PANEL
    POWER UNLOCK
    BLACK/WHITE (TYPE C) See NOTE *1
    DOOR TRIGGER
    WHITE (-)
    @ UNDER DASH LIGHT
    DOMELIGHT
    SUPERVISION
    USE DOOR TRIGGER, Requires #775 Relay
    TRUNK RELEASE
    BLACK (+)
    @ RELAY UNDER LEFT SIDE OF DASH
    SLIDING
    POWER DOOR
    N/A
    HORN
    BLACK (-)
    @ STEERING COLUMN HARNESS
    TACH
    WHITE
    @ IGNITION MODULE
    WAIT TO
    START LIGHT
    N/A
    BRAKE
    WHITE (+)
    @ SWITCH ABOVE BRAKE PEDAL
    FACTORY
    ALARM DISARM
    N/A
    ANTI-THEFT
    N/A
    EXTRA
    INFORMATION
    NOTE
    *1 If vehicle is 2-Door it has a TYPE "C" DOOR LOCKING SYSTEM, if
    vehicle is a 4-Door it has a TYPE "A" DOOR LOCKING SYSTEM.
Can i get a t-harness for a 1997 s10 blazer
1997 blazer needs GM-1 harness
S10 blazer were only made until 1994 I think
Jan 15, 2010 | Bulldog Remote Starter & T-Harness Kit for...
I installed a prostart remote starter with a universal bypass transponder. it cranks but will not start.
put your key in the ignition hole and remote start it, if it starts you need to reposition the key in the box or the loop around the igntion switch
Jan 08, 2010 | Bulldog Remote Starter & T-Harness Kit for...
Fuel pump problems
because the fuel pump is built with better quality materal from a different company, the assemblly was probibly built with cheaper material
May 08, 2009 | Bulldog Remote Starter & T-Harness Kit for...
95 chevy blazer 4.3L fuel in anti freeze
your head gasket is about to go, which could possibly ruin your whole engine.
Jan 11, 2009 | Bulldog Remote Starter & T-Harness Kit for...
I installed a remote starter on my 1992 Blazer and need to know if it has any type of factory security on it that could be causing it to not start?
Not on Just the Remote Starter. Did you go to the Bulldog Website and get a Detailed Wiring Diagram for Your Truck? If not Get one and Retrace the Steps. You missed one Somewhere. Got it on my 95' Silverado and have had no Prob's
Dec 30, 2008 | Bulldog Remote Starter & T-Harness Kit for...
How can i get a new remote to replace the one i lost
The ONLY way to get a Replacement Remote is through the Bulldog Website www.BulldogSecurity.com They will tell you there how to Reprogram the Remotes
Dec 20, 2008 | Bulldog Remote Starter & T-Harness Kit for...
Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi Logo
885 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
John
John
baire
DROPNDEAL
DROPNDEAL
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
